I recently updated the AirVPN client due to incompatibility with a windows 10 update and am now caught in a 'Checking DNS' loop. I have tried checking firewall, restarted DHCP client and resetting WINSOCK as instructed but no success. Has anyone had a similar issue that they resolved?
logs are as follows:
I 2016.04.22 07:44:27 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.04.22 07:44:27 - Reading options from C:\Users\user\AppData\Local\AirVPN\AirVPN.xml
. 2016.04.22 07:44:28 - Data Path: C:\Users\user\AppData\Local\AirVPN
. 2016.04.22 07:44:28 - App Path: C:\Program Files\AirVPN
. 2016.04.22 07:44:28 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.04.22 07:44:28 - Command line arguments (1): path="home"
. 2016.04.22 07:44:28 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.04.22 07:44:28 - Updating systems & servers data ...
I 2016.04.22 07:44:30 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.04.22 07:44:30 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.04.22 07:44:30 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.04.22 07:44:30 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.04.22 07:44:30 - Activation of Network Lock - Windows Firewall
. 2016.04.22 07:44:31 - Systems & servers data update completed
! 2016.04.22 07:44:34 - Ready
I 2016.04.22 07:44:42 - Checking login ...
! 2016.04.22 07:44:43 - Logged in.
I 2016.04.22 07:44:45 - Session starting.
I 2016.04.22 07:44:45 - IPv6 disabled.
I 2016.04.22 07:44:47 - Checking authorization ...
! 2016.04.22 07:44:48 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:44:48 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:44:48 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:44:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:44:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:44:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:44:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:44:49 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:44:49 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:44:49 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:44:49 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=244fb12e d44b9f1a
. 2016.04.22 07:44:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:44:50 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:44:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:44:50 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:44:50 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:44:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:44:50 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:44:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:44:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:44:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:44:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:44:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:44:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:44:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:44:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:44:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:44:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:44:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:44:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:44:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:44:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:44:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:44:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:44:56 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:44:56 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:44:56 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:44:56 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:44:56 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:44:56 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:45:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:45:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:45:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:45:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:45:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:45:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:45:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:45:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:45:02 - Starting Management Interface
. 2016.04.22 07:45:02 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:45:02 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:45:02 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:45:02 - Flushing DNS
I 2016.04.22 07:45:03 - Checking DNS
W 2016.04.22 07:46:07 - The operation has timed out
! 2016.04.22 07:46:07 - Disconnecting
. 2016.04.22 07:46:07 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:46:07 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:46:07 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:46:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:46:07 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.04.22 07:46:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:46:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:46:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:46:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:46:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:46:12 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:46:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:46:13 - Connection terminated.
I 2016.04.22 07:46:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:46:13 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:46:16 - Checking authorization ...
! 2016.04.22 07:46:17 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:46:17 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:46:17 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:46:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:46:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:46:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:46:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:46:18 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:46:18 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:46:18 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:46:20 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=31b5a96e f1c388b8
. 2016.04.22 07:46:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:46:21 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:46:21 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:46:21 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:46:21 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:46:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:46:21 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:46:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:46:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:46:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:46:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:46:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:46:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:46:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:46:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:46:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:46:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:46:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:46:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:46:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:46:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:46:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:46:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:46:36 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:46:36 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:46:36 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:46:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:46:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:46:36 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:46:41 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:46:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:46:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:46:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:46:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:46:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:46:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:46:41 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:46:41 - Starting Management Interface
. 2016.04.22 07:46:41 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:46:41 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:46:41 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:46:41 - Flushing DNS
I 2016.04.22 07:46:41 - Checking DNS
W 2016.04.22 07:47:44 - The operation has timed out
! 2016.04.22 07:47:45 - Disconnecting
. 2016.04.22 07:47:45 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:47:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:47:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:47:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:47:45 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.04.22 07:47:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:47:50 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:47:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:47:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:47:50 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:47:50 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:47:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:47:51 - Connection terminated.
I 2016.04.22 07:47:51 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:47:51 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:47:54 - Checking authorization ...
! 2016.04.22 07:47:55 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:47:55 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:47:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:47:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:47:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:47:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:47:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:47:56 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:47:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:47:56 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:47:56 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=9735c095 a359c91b
. 2016.04.22 07:47:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:47:56 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:47:56 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:47:56 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:47:56 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:47:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:47:56 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:47:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:48:02 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:48:02 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:48:02 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:48:02 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:48:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:48:02 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:48:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:48:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:48:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:48:04 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:48:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:48:04 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:48:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:48:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:48:04 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:48:04 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:48:04 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:48:04 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:48:04 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:48:04 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:48:04 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:48:10 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:48:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:48:10 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:48:10 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:48:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:48:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:48:10 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:48:10 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:48:10 - Starting Management Interface
. 2016.04.22 07:48:10 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:48:10 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:48:10 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:48:10 - Flushing DNS
I 2016.04.22 07:48:10 - Checking DNS
W 2016.04.22 07:49:13 - The operation has timed out
! 2016.04.22 07:49:14 - Disconnecting
. 2016.04.22 07:49:14 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:49:14 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:49:14 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:49:14 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:49:14 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.04.22 07:49:19 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:49:19 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:49:19 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:49:19 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:49:19 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:49:19 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:49:19 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:49:19 - Connection terminated.
I 2016.04.22 07:49:19 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:49:20 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:49:23 - Checking authorization ...
! 2016.04.22 07:49:24 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:49:24 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:49:24 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:49:24 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:49:24 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:49:24 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:49:24 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:49:24 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:49:24 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:49:24 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:49:25 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=4be6c1cd e79de183
. 2016.04.22 07:49:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:49:25 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:49:25 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:49:25 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:49:25 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:49:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:49:25 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:49:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:49:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:49:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:49:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:49:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:49:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:49:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:49:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:49:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:49:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:49:29 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:49:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:49:29 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:49:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:49:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:49:29 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:49:29 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:49:30 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:49:30 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:49:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:49:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:49:30 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:49:35 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:49:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:49:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:49:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:49:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:49:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:49:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:49:35 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:49:35 - Starting Management Interface
. 2016.04.22 07:49:35 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:49:36 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:49:36 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:49:36 - Flushing DNS
I 2016.04.22 07:49:36 - Checking DNS
W 2016.04.22 07:50:41 - The operation has timed out
! 2016.04.22 07:50:41 - Disconnecting
. 2016.04.22 07:50:41 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:50:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:50:41 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:50:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:50:41 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.04.22 07:50:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:50:47 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:50:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:50:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:50:47 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:50:47 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:50:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:50:47 - Connection terminated.
I 2016.04.22 07:50:47 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:50:47 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:50:50 - Checking authorization ...
! 2016.04.22 07:50:51 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:50:51 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:50:51 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:50:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:50:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:50:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:50:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:50:52 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:50:52 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:50:52 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:50:52 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=493fb40b 5f7da64a
. 2016.04.22 07:50:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:50:52 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:50:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:50:52 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:50:52 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:50:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:50:52 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:50:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:50:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:50:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:50:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:50:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:50:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:50:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:51:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:51:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:51:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:51:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:51:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:51:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:51:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:51:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:51:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:51:02 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:51:02 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:51:02 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:51:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:51:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:51:02 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:51:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:51:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:51:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:51:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:51:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:51:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:51:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:51:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:51:07 - Starting Management Interface
. 2016.04.22 07:51:07 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:51:07 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:51:07 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:51:07 - Flushing DNS
I 2016.04.22 07:51:07 - Checking DNS
W 2016.04.22 07:52:11 - The operation has timed out
! 2016.04.22 07:52:11 - Disconnecting
. 2016.04.22 07:52:11 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:52:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:52:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:52:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:52:11 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.04.22 07:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:52:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:52:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:52:17 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:52:17 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:52:17 - Connection terminated.
I 2016.04.22 07:52:17 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:52:17 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:52:20 - Checking authorization ...
! 2016.04.22 07:52:21 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:52:21 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:52:21 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:52:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:52:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:52:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:52:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:52:22 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:52:22 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:52:22 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:52:22 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=7d716aea b0e65614
. 2016.04.22 07:52:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:52:22 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:52:22 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:52:22 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:52:22 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:52:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:52:22 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:52:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:52:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:52:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:52:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:52:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:52:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:52:24 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:52:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:52:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:52:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:52:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:52:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:52:26 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:52:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:52:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:52:27 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:52:27 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:52:27 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:52:27 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:52:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:52:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:52:27 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:52:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:52:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:52:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:52:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:52:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:52:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:52:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:52:32 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:52:32 - Starting Management Interface
. 2016.04.22 07:52:32 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:52:32 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:52:32 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:52:32 - Flushing DNS
I 2016.04.22 07:52:33 - Checking DNS
W 2016.04.22 07:53:36 - The operation has timed out
! 2016.04.22 07:53:36 - Disconnecting
. 2016.04.22 07:53:36 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:53:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:53:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:53:36 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:53:36 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.04.22 07:53:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:53:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:53:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:53:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:53:41 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:53:41 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:53:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:53:41 - Connection terminated.
I 2016.04.22 07:53:42 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:53:43 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:53:46 - Checking authorization ...
! 2016.04.22 07:53:47 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:53:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:53:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:53:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:53:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:53:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:53:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:53:48 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:53:48 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:53:48 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:53:48 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=10161db4 82e9b416
. 2016.04.22 07:53:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:53:48 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:53:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:53:48 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:53:48 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:53:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:53:48 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:53:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:53:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:53:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:53:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:53:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:53:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:53:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:53:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:53:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:53:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:53:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:53:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:53:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:53:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:53:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:53:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:53:58 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:53:58 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:53:58 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:53:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:53:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:53:58 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:54:03 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:54:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:54:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:54:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:54:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:54:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:54:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:54:03 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:54:03 - Starting Management Interface
. 2016.04.22 07:54:03 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:54:03 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:54:03 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:54:03 - Flushing DNS
I 2016.04.22 07:54:03 - Checking DNS
W 2016.04.22 07:55:07 - The operation has timed out
! 2016.04.22 07:55:08 - Disconnecting
. 2016.04.22 07:55:08 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:55:08 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:55:08 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:55:08 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:55:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:55:13 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:55:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:55:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:55:13 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:55:13 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:55:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:55:13 - Connection terminated.
I 2016.04.22 07:55:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:55:13 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:55:17 - Checking authorization ...
! 2016.04.22 07:55:18 - Connecting to Gemma (Canada, Vancouver)
. 2016.04.22 07:55:18 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.22 07:55:18 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.22 07:55:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.22 07:55:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.22 07:55:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:55:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:55:18 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.22 07:55:18 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.22 07:55:18 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.113:443
. 2016.04.22 07:55:18 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.113:443, sid=036bc46f f31831eb
. 2016.04.22 07:55:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.22 07:55:19 - OpenVPN > Validating certificate key usage
. 2016.04.22 07:55:19 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.22 07:55:19 - OpenVPN > VERIFY KU OK
. 2016.04.22 07:55:19 - OpenVPN > Validating certificate extended key usage
. 2016.04.22 07:55:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.22 07:55:19 - OpenVPN > VERIFY EKU OK
. 2016.04.22 07:55:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.22 07:55:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:55:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:55:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.22 07:55:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.22 07:55:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.22 07:55:20 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.113:443
. 2016.04.22 07:55:23 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.22 07:55:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.1 255.255.0.0'
. 2016.04.22 07:55:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.22 07:55:23 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.22 07:55:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.22 07:55:23 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.22 07:55:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.22 07:55:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.22 07:55:23 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.22 07:55:23 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.22 07:55:23 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{949DF2DC-2675-421F-ADFD-66C1FBD912A9}.tap
. 2016.04.22 07:55:23 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.22 07:55:23 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.1/255.255.0.0 [sUCCEEDED]
. 2016.04.22 07:55:23 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.1/255.255.0.0 on interface {949DF2DC-2675-421F-ADFD-66C1FBD912A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.22 07:55:23 - OpenVPN > Successful ARP Flush on interface [8] {949DF2DC-2675-421F-ADFD-66C1FBD912A9}
. 2016.04.22 07:55:28 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.22 07:55:28 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:55:28 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.22 07:55:28 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.22 07:55:28 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.04.22 07:55:28 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:55:28 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.22 07:55:28 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:55:28 - Starting Management Interface
. 2016.04.22 07:55:28 - OpenVPN > Initialization Sequence Completed
I 2016.04.22 07:55:28 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.22 07:55:28 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:55:28 - Flushing DNS
I 2016.04.22 07:55:28 - Checking DNS
W 2016.04.22 07:56:31 - The operation has timed out
! 2016.04.22 07:56:31 - Disconnecting
. 2016.04.22 07:56:31 - Management - Send 'signal SIGTERM'
. 2016.04.22 07:56:31 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.22 07:56:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.22 07:56:31 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.22 07:56:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 71.19.252.113 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:56:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.22 07:56:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.04.22 07:56:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:56:36 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.22 07:56:36 - OpenVPN > Closing TUN/TAP interface
. 2016.04.22 07:56:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.22 07:56:36 - Connection terminated.
I 2016.04.22 07:56:36 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.22 07:56:36 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.04.22 07:56:36 - Cancel requested.
I 2016.04.22 07:56:36 - IPv6 restored.
! 2016.04.22 07:56:37 - Session terminated.
! 2016.04.22 07:56:39 - Deactivation of Network Lock
Hello !
Please edit your post and post your logs in spoiler tags.
Well as I really don't like windows 10 I also don't know much about the use of it. However looking through your logs I see this
Several times when you try to connect everything else seems to be fine so when it tries to set the DNS something must be malfunctioning now I don't really know how the DNS settings in W10 works but try to reset your DNS manually and reinstall the TAP driver and see if your network card needs an update.
