trajan
Extratorrent.cc
Hi
This morning, whenever i log into extratorrent.cc with Airvpn, i get a standard   message from my isp that the website has been blocked by isp.
This is wierd as never happened before. Only time i would see this message is when i would attempt to visit the site without airvpn.  I have tried both network lock and unlock modes. connecting via netherlands as always (recommended server).
You need to make sure you do these three things:
1. Turn of any location services your device or browser may be using.
2. Plug that WebRTC leak.
3. Plug any DNS leaks.
4.  Disable IPv6 on your adapter.
For location services:
In the URL bar, type about:config
Type geo.enabled
Double click on the geo.enabled preference
Location-Aware Browsing is now disabled
For WebRTC, make sure you do this:
Enter "about:config" in the address bar and press enter
Press the button "I'll be careful, I promise!"
Type in "media.peerconnection.enabled" in the search bar (there should be only one entry)
Right-click the entry choose "Toggle", the column "Value" should now be "false"
For DNS leak protection, you need to either make sure the DNS options of eddie are enabled, use network lock, and ensure that the TAP adapter's DNS server is set to 10.4.0.1.
