nye_92
re connection every 30 seconds DNS failure
hi,
Air VPN keeps crashing disconnecting and reconnecting to a new network, runs fine for aprox. 30 seconds then automatically re-connects,
I have 'check if the tunnel uses AirVPN DNS' unchecked
logs posted below
I 2016.04.15 00:56:35 - Session starting.
I 2016.04.15 00:56:35 - IPv6 disabled.
I 2016.04.15 00:56:35 - Checking authorization ...
! 2016.04.15 00:56:35 - Connecting to Alchiba (Netherlands, Alblasserdam)
. 2016.04.15 00:56:35 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.15 00:56:35 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.15 00:56:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.15 00:56:35 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.15 00:56:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 00:56:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 00:56:35 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.15 00:56:35 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.15 00:56:35 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.180:443
. 2016.04.15 00:56:35 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.180:443, sid=d5c45d8b 8ccb6fb7
. 2016.04.15 00:56:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.15 00:56:36 - OpenVPN > Validating certificate key usage
. 2016.04.15 00:56:36 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.04.15 00:56:36 - OpenVPN > VERIFY KU OK
. 2016.04.15 00:56:36 - OpenVPN > Validating certificate extended key usage
. 2016.04.15 00:56:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.15 00:56:36 - OpenVPN > VERIFY EKU OK
. 2016.04.15 00:56:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.15 00:56:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.15 00:56:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 00:56:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.15 00:56:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 00:56:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.15 00:56:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.180:443
. 2016.04.15 00:56:38 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.15 00:56:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.58.171 255.255.0.0'
. 2016.04.15 00:56:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.15 00:56:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.15 00:56:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.15 00:56:38 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.15 00:56:38 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.15 00:56:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.15 00:56:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.15 00:56:38 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.15 00:56:38 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{F4D1CA03-2205-4564-8C5F-6B53018D6683}.tap
. 2016.04.15 00:56:38 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.15 00:56:38 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.58.171/255.255.0.0 [sUCCEEDED]
. 2016.04.15 00:56:38 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.58.171/255.255.0.0 on interface {F4D1CA03-2205-4564-8C5F-6B53018D6683} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.15 00:56:38 - OpenVPN > Successful ARP Flush on interface [10] {F4D1CA03-2205-4564-8C5F-6B53018D6683}
. 2016.04.15 00:56:43 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.15 00:56:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.180 MASK 255.255.255.255 192.168.1.254
. 2016.04.15 00:56:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.04.15 00:56:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.15 00:56:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.15 00:56:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.04.15 00:56:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.15 00:56:43 - Starting Management Interface
. 2016.04.15 00:56:43 - OpenVPN > Initialization Sequence Completed
I 2016.04.15 00:56:43 - DNS of a network adapter forced (Qualcomm Atheros QCA9377 Wireless Network Adapter)
I 2016.04.15 00:56:43 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.15 00:56:43 - Flushing DNS
I 2016.04.15 00:56:43 - Checking route
! 2016.04.15 00:56:43 - Connected.
. 2016.04.15 00:56:43 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.04.15 00:56:44 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2764 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2765 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2769 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2790 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2791 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2792 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2793 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2794 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2795 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2798 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2799 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2800 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2801 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2807 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2808 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2809 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2810 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2811 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2813 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2815 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2816 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2817 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2818 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2819 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2820 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2821 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2822 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2823 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2824 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2825 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2827 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2829 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2836 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2838 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2839 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:04 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2840 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6213 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6216 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6217 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6218 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6219 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6220 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6221 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6222 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6223 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6224 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6225 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6227 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6228 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6229 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6230 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6231 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6232 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6233 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6234 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6235 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6237 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6238 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6239 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6241 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6242 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6243 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6244 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6245 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6247 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6248 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6249 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6250 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6251 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6253 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6254 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6256 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6257 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6258 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6260 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13417 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13418 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13422 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13423 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13424 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13425 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13446 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13448 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13450 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13451 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13453 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13454 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13455 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13456 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13457 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13459 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13460 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13461 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13462 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13463 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13464 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13466 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13469 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13470 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13471 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13472 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13473 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13474 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13476 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13484 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13485 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13487 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13488 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13489 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13490 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13491 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13493 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13494 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13495 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13498 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13500 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15697 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15699 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15700 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15701 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15702 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15703 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15704 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15705 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15706 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15707 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15708 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15709 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15710 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15712 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15713 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15714 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15716 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15717 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15718 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15720 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15721 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15722 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15724 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15727 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15728 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15733 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15735 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15744 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15746 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15747 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15748 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15749 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15750 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15752 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15753 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 00:57:28 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15756 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2016.04.15 01:02:59 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.04.15 01:02:59 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.04.15 01:02:59 - OpenVPN > Restart pause, 2 second(s)
! 2016.04.15 01:02:59 - Disconnecting
. 2016.04.15 01:02:59 - Management - Send 'signal SIGTERM'
. 2016.04.15 01:02:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.15 01:02:59 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.04.15 01:02:59 - OpenVPN > Assertion failed at misc.c:779
. 2016.04.15 01:02:59 - OpenVPN > Exiting due to fatal error
. 2016.04.15 01:02:59 - Connection terminated.
I 2016.04.15 01:03:00 - DNS of a network adapter restored to original settings (Qualcomm Atheros QCA9377 Wireless Network Adapter)
I 2016.04.15 01:03:00 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.15 01:03:03 - Checking authorization ...
! 2016.04.15 01:03:03 - Connecting to Alchiba (Netherlands, Alblasserdam)
. 2016.04.15 01:03:03 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.15 01:03:03 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.15 01:03:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.15 01:03:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.15 01:03:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 01:03:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 01:03:03 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.04.15 01:03:03 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.15 01:03:03 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.180:443
. 2016.04.15 01:03:03 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.180:443, sid=d154b979 0b55498b
. 2016.04.15 01:03:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.15 01:03:03 - OpenVPN > Validating certificate key usage
. 2016.04.15 01:03:03 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.04.15 01:03:03 - OpenVPN > VERIFY KU OK
. 2016.04.15 01:03:03 - OpenVPN > Validating certificate extended key usage
. 2016.04.15 01:03:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.15 01:03:03 - OpenVPN > VERIFY EKU OK
. 2016.04.15 01:03:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.15 01:03:06 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.15 01:03:06 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 01:03:06 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.15 01:03:06 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.15 01:03:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.15 01:03:06 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.180:443
. 2016.04.15 01:03:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.15 01:03:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.58.171 255.255.0.0'
. 2016.04.15 01:03:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.15 01:03:09 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.15 01:03:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.15 01:03:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.15 01:03:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.15 01:03:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.15 01:03:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.15 01:03:09 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.15 01:03:09 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{F4D1CA03-2205-4564-8C5F-6B53018D6683}.tap
. 2016.04.15 01:03:09 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.15 01:03:09 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.58.171/255.255.0.0 [sUCCEEDED]
. 2016.04.15 01:03:09 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.58.171/255.255.0.0 on interface {F4D1CA03-2205-4564-8C5F-6B53018D6683} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.04.15 01:03:09 - OpenVPN > Successful ARP Flush on interface [10] {F4D1CA03-2205-4564-8C5F-6B53018D6683}
. 2016.04.15 01:03:14 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.15 01:03:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.180 MASK 255.255.255.255 192.168.1.254
. 2016.04.15 01:03:14 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=8]
. 2016.04.15 01:03:14 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.04.15 01:03:14 - OpenVPN > Route addition fallback to route.exe
. 2016.04.15 01:03:14 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.04.15 01:03:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 8
. 2016.04.15 01:03:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.04.15 01:03:14 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.15 01:03:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.15 01:03:14 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=10]
. 2016.04.15 01:03:14 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.15 01:03:14 - Starting Management Interface
. 2016.04.15 01:03:14 - OpenVPN > Initialization Sequence Completed
I 2016.04.15 01:03:14 - DNS of a network adapter forced (Qualcomm Atheros QCA9377 Wireless Network Adapter)
I 2016.04.15 01:03:14 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.04.15 01:03:14 - Flushing DNS
I 2016.04.15 01:03:14 - Checking route
! 2016.04.15 01:03:14 - Connected.
. 2016.04.15 01:03:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.04.15 01:03:14 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.04.15 01:05:21 - Disconnecting
. 2016.04.15 01:05:21 - Management - Send 'signal SIGTERM'
. 2016.04.15 01:05:21 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.04.15 01:05:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.04.15 01:05:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.180 MASK 255.255.255.255 192.168.1.254
. 2016.04.15 01:05:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.04.15 01:05:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2016.04.15 01:05:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.15 01:05:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.04.15 01:05:26 - OpenVPN > Closing TUN/TAP interface
. 2016.04.15 01:05:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.04.15 01:05:26 - Connection terminated.
I 2016.04.15 01:05:26 - DNS of a network adapter restored to original settings (Qualcomm Atheros QCA9377 Wireless Network Adapter)
I 2016.04.15 01:05:26 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.04.15 01:05:26 - IPv6 restored.
! 2016.04.15 01:05:26 - Session terminated.
any help greatly appreciated
Actually, the problem is this combination of log entries. Have a look at Weird log entries.
