GreyGold 1 Posted ... I'm trying to use my preferred DNS server (from OpenDNS) rather than the recommended AirVPN server. I've tried listing the IP addresses under Preferences -> Advanced -> DNS, with DNS Switch mode Disabled or Automatic and with "Check if the tunnel uses AirVPN DNS" selected or deselected. In every case, a connection is established, then immediately disconnected, after which the sequence repeats. How can I successfully use a non-AirVPN DNS server? Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... You could post logs here for us to understand the issue on a lower level. Use spoiler tags for this please. A how-to can be found in my signature. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
GreyGold 1 Posted ... Forgive me if I'm a little new to this. I understand how to use spoilers, and I thought I described my issue pretty clearly. Which logs would be helpful, and how do I generate them? Quote Share this post Link to post
GreyGold 1 Posted ... Maybe this will be helpful... ! 2016.04.03 11:55:36 - Disconnecting. 2016.04.03 11:55:36 - Management - Send 'signal SIGTERM'. 2016.04.03 11:55:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.04.03 11:55:37 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.04.03 11:55:41 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.39 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:55:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:55:41 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:55:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:55:41 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:55:41 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:55:41 - OpenVPN > Closing TUN/TAP interface. 2016.04.03 11:55:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.04.03 11:55:41 - Connection terminated.I 2016.04.03 11:55:41 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)I 2016.04.03 11:55:41 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.04.03 11:55:41 - IPv6 restored.! 2016.04.03 11:55:41 - Session terminated.I 2016.04.03 11:55:54 - Session starting.I 2016.04.03 11:55:54 - IPv6 disabled.I 2016.04.03 11:55:54 - Checking authorization ...! 2016.04.03 11:55:54 - Connecting to Alcyone (Netherlands, Alblasserdam). 2016.04.03 11:55:54 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.04.03 11:55:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.04.03 11:55:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.04.03 11:55:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.04.03 11:55:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:55:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:55:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.04.03 11:55:54 - OpenVPN > UDPv4 link local: [undef]. 2016.04.03 11:55:54 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443. 2016.04.03 11:55:54 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=7fed1af0 91c2771f. 2016.04.03 11:55:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.04.03 11:55:55 - OpenVPN > Validating certificate key usage. 2016.04.03 11:55:55 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.04.03 11:55:55 - OpenVPN > VERIFY KU OK. 2016.04.03 11:55:55 - OpenVPN > Validating certificate extended key usage. 2016.04.03 11:55:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.04.03 11:55:55 - OpenVPN > VERIFY EKU OK. 2016.04.03 11:55:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.04.03 11:55:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.04.03 11:55:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:55:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.04.03 11:55:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:55:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.04.03 11:55:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443. 2016.04.03 11:55:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.04.03 11:55:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.200 255.255.0.0'. 2016.04.03 11:55:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.04.03 11:55:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.04.03 11:55:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.04.03 11:55:58 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.04.03 11:55:58 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.04.03 11:55:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.04.03 11:55:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.04.03 11:55:58 - OpenVPN > open_tun, tt->ipv6=0. 2016.04.03 11:55:58 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{7FCB1523-0331-450D-B6B5-2D32AB106E76}.tap. 2016.04.03 11:55:58 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.04.03 11:55:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.200/255.255.0.0 [sUCCEEDED]. 2016.04.03 11:55:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.200/255.255.0.0 on interface {7FCB1523-0331-450D-B6B5-2D32AB106E76} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.04.03 11:55:58 - OpenVPN > Successful ARP Flush on interface [5] {7FCB1523-0331-450D-B6B5-2D32AB106E76}. 2016.04.03 11:56:03 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.04.03 11:56:03 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:56:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2016.04.03 11:56:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:03 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.04.03 11:56:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:03 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.04.03 11:56:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:03 - Starting Management Interface. 2016.04.03 11:56:03 - OpenVPN > Initialization Sequence CompletedI 2016.04.03 11:56:03 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)I 2016.04.03 11:56:03 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.04.03 11:56:03 - Flushing DNSI 2016.04.03 11:56:03 - Checking routeW 2016.04.03 11:56:03 - The remote name could not be resolved: 'alcyone_exit.airservers.org'! 2016.04.03 11:56:03 - Disconnecting. 2016.04.03 11:56:03 - Management - Send 'signal SIGTERM'. 2016.04.03 11:56:03 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.04.03 11:56:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.04.03 11:56:03 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.04.03 11:56:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.116 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:56:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:08 - OpenVPN > Closing TUN/TAP interface. 2016.04.03 11:56:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.04.03 11:56:08 - Connection terminated.I 2016.04.03 11:56:08 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)I 2016.04.03 11:56:08 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.04.03 11:56:11 - Checking authorization ...! 2016.04.03 11:56:12 - Connecting to Alcyone (Netherlands, Alblasserdam). 2016.04.03 11:56:12 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.04.03 11:56:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.04.03 11:56:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.04.03 11:56:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.04.03 11:56:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:12 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.04.03 11:56:12 - OpenVPN > UDPv4 link local: [undef]. 2016.04.03 11:56:12 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443. 2016.04.03 11:56:12 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=1ba43ee1 fbbc0d13. 2016.04.03 11:56:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.04.03 11:56:12 - OpenVPN > Validating certificate key usage. 2016.04.03 11:56:12 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.04.03 11:56:12 - OpenVPN > VERIFY KU OK. 2016.04.03 11:56:12 - OpenVPN > Validating certificate extended key usage. 2016.04.03 11:56:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.04.03 11:56:12 - OpenVPN > VERIFY EKU OK. 2016.04.03 11:56:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.04.03 11:56:13 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.04.03 11:56:13 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:13 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.04.03 11:56:13 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.04.03 11:56:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443. 2016.04.03 11:56:15 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.04.03 11:56:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.200 255.255.0.0'. 2016.04.03 11:56:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.04.03 11:56:15 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.04.03 11:56:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.04.03 11:56:15 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.04.03 11:56:15 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.04.03 11:56:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.04.03 11:56:15 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.04.03 11:56:15 - OpenVPN > open_tun, tt->ipv6=0. 2016.04.03 11:56:16 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{7FCB1523-0331-450D-B6B5-2D32AB106E76}.tap. 2016.04.03 11:56:16 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.04.03 11:56:16 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.200/255.255.0.0 [sUCCEEDED]. 2016.04.03 11:56:16 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.200/255.255.0.0 on interface {7FCB1523-0331-450D-B6B5-2D32AB106E76} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.04.03 11:56:16 - OpenVPN > Successful ARP Flush on interface [5] {7FCB1523-0331-450D-B6B5-2D32AB106E76}. 2016.04.03 11:56:20 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.04.03 11:56:20 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:56:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2016.04.03 11:56:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:20 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.04.03 11:56:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:20 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.04.03 11:56:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:20 - Starting Management Interface. 2016.04.03 11:56:20 - OpenVPN > Initialization Sequence CompletedI 2016.04.03 11:56:20 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)I 2016.04.03 11:56:20 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.04.03 11:56:20 - Flushing DNSI 2016.04.03 11:56:20 - Checking routeW 2016.04.03 11:56:20 - The remote name could not be resolved: 'alcyone_exit.airservers.org'! 2016.04.03 11:56:20 - Disconnecting. 2016.04.03 11:56:20 - Management - Send 'signal SIGTERM'. 2016.04.03 11:56:20 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.04.03 11:56:20 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.04.03 11:56:20 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.04.03 11:56:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.116 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:56:25 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:25 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:25 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:25 - OpenVPN > Closing TUN/TAP interface. 2016.04.03 11:56:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.04.03 11:56:25 - Connection terminated.I 2016.04.03 11:56:25 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)I 2016.04.03 11:56:25 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.04.03 11:56:28 - Checking authorization ...! 2016.04.03 11:56:28 - Connecting to Alcyone (Netherlands, Alblasserdam). 2016.04.03 11:56:28 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.04.03 11:56:28 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.04.03 11:56:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.04.03 11:56:28 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.04.03 11:56:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:28 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.04.03 11:56:28 - OpenVPN > UDPv4 link local: [undef]. 2016.04.03 11:56:28 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443. 2016.04.03 11:56:28 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=f4b7cd20 74d6f98a. 2016.04.03 11:56:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.04.03 11:56:29 - OpenVPN > Validating certificate key usage. 2016.04.03 11:56:29 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.04.03 11:56:29 - OpenVPN > VERIFY KU OK. 2016.04.03 11:56:29 - OpenVPN > Validating certificate extended key usage. 2016.04.03 11:56:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.04.03 11:56:29 - OpenVPN > VERIFY EKU OK. 2016.04.03 11:56:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.04.03 11:56:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.04.03 11:56:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.04.03 11:56:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.04.03 11:56:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.04.03 11:56:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443. 2016.04.03 11:56:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.04.03 11:56:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.200 255.255.0.0'. 2016.04.03 11:56:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.04.03 11:56:32 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.04.03 11:56:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.04.03 11:56:32 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.04.03 11:56:32 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.04.03 11:56:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.04.03 11:56:32 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.04.03 11:56:32 - OpenVPN > open_tun, tt->ipv6=0. 2016.04.03 11:56:32 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{7FCB1523-0331-450D-B6B5-2D32AB106E76}.tap. 2016.04.03 11:56:32 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.04.03 11:56:32 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.200/255.255.0.0 [sUCCEEDED]. 2016.04.03 11:56:32 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.200/255.255.0.0 on interface {7FCB1523-0331-450D-B6B5-2D32AB106E76} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.04.03 11:56:32 - OpenVPN > Successful ARP Flush on interface [5] {7FCB1523-0331-450D-B6B5-2D32AB106E76}. 2016.04.03 11:56:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.04.03 11:56:38 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:56:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2016.04.03 11:56:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.04.03 11:56:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.04.03 11:56:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.04.03 11:56:38 - Starting Management Interface. 2016.04.03 11:56:38 - OpenVPN > Initialization Sequence CompletedI 2016.04.03 11:56:38 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)I 2016.04.03 11:56:38 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.04.03 11:56:38 - Flushing DNSI 2016.04.03 11:56:38 - Checking routeW 2016.04.03 11:56:38 - The remote name could not be resolved: 'alcyone_exit.airservers.org'! 2016.04.03 11:56:38 - Disconnecting. 2016.04.03 11:56:38 - Management - Send 'signal SIGTERM'. 2016.04.03 11:56:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.04.03 11:56:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.04.03 11:56:38 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.04.03 11:56:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.116 MASK 255.255.255.255 192.168.2.1. 2016.04.03 11:56:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.04.03 11:56:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.04.03 11:56:43 - OpenVPN > Closing TUN/TAP interface. 2016.04.03 11:56:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.04.03 11:56:43 - Connection terminated.I 2016.04.03 11:56:43 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)I 2016.04.03 11:56:43 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.04.03 11:56:43 - Cancel requested.I 2016.04.03 11:56:43 - IPv6 restored.! 2016.04.03 11:56:43 - Session terminated. Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... W 2016.04.03 11:56:03 - The remote name could not be resolved: 'alcyone_exit.airservers.org' I've seen that a few times. Have a look at Cannot log on to any servers. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
GreyGold 1 Posted ... Thanks for the insightful reference. After re-configuring AirVPN to reproduce the issue - you guessed it - I was successfully connected, so I'll just have to wait and see if it recurs. While I'm glad the problem has disappeared, I'm exasperated that it could be lurking in the background. Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... Thanks for the insightful reference. After re-configuring AirVPN to reproduce the issue - you guessed it - I was successfully connected, so I'll just have to wait and see if it recurs. While I'm glad the problem has disappeared, I'm exasperated that it could be lurking in the background. Just come back here if the problem comes back or you can tag it as resolved. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
