Not connected, Your IP: 18.217.171.249
YDWX7uYwz6v6t
AirVPN Client Lose Most of Its GUI
I was connected to Saiph a few minutes ago.  I went to disconnect and when I brought the AirVPN client up, only the window frame was visible.  I wasn't able to shut it down and had to resort to a system reboot.
Here's a screenshot:
Log file after reboot is attached.
System:  Debian Unstable
AirVPN Client version:  2.10.3
airvpn_log_20160330_224643.txt
This is most likely due to a bug in your window manager that allows "maximizing" of any X window to stretch it
on top of the screen. The Eddie client cannot force it not to do this.
Resizing issues happen alot on Windows apps that you run with Wine for example.
Sometimes the solution is minimizing and opening it again, or playing with the window borders.
