temo1993 0 Posted ... Hi, First ,I want to thank "airvpn" moderators and staff for the hard-work they put, in order to keep me and others enjoying this software. I use" airvpn" for long time and most of it hadn't face any problem in terms of speed ,stability and connectivity ,Just had this one annoying issue ,when I'm not connected to "airvpn" i sometimes have to troubleshoot my network "many times" to fix this issue (Default Gateway is not available) ..... & I'm sure that "airvpn" cause this problem , Any help would be appreciated. Best regards!! Here is the log: I 2016.03.30 19:05:57 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.03.30 19:05:57 - Reading options from C:\Users\tamer\AppData\Local\AirVPN\AirVPN.xml. 2016.03.30 19:05:58 - Data Path: C:\Users\tamer\AppData\Local\AirVPN. 2016.03.30 19:05:58 - App Path: C:\Program Files\AirVPN. 2016.03.30 19:05:58 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.03.30 19:05:58 - Command line arguments (1): path="home". 2016.03.30 19:05:58 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.03.30 19:05:58 - Updating systems & servers data ...I 2016.03.30 19:05:59 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2016.03.30 19:05:59 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.03.30 19:05:59 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.03.30 19:05:59 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.03.30 19:05:59 - Ready! 2016.03.30 19:06:02 - Activation of Network Lock - Windows Firewall. 2016.03.30 19:06:02 - Systems & servers data update completedI 2016.03.30 19:06:11 - Session starting.I 2016.03.30 19:06:12 - IPv6 disabled.I 2016.03.30 19:06:12 - Checking authorization ...! 2016.03.30 19:06:14 - Connecting to Nash (Netherlands, Alblasserdam). 2016.03.30 19:06:14 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.03.30 19:06:14 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.03.30 19:06:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.03.30 19:06:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.03.30 19:06:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.30 19:06:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.30 19:06:14 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.03.30 19:06:14 - OpenVPN > UDPv4 link local: [undef]. 2016.03.30 19:06:14 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.24:443. 2016.03.30 19:06:14 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.24:443, sid=20d07900 f9757dc9. 2016.03.30 19:06:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.03.30 19:06:15 - OpenVPN > Validating certificate key usage. 2016.03.30 19:06:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.03.30 19:06:15 - OpenVPN > VERIFY KU OK. 2016.03.30 19:06:15 - OpenVPN > Validating certificate extended key usage. 2016.03.30 19:06:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.03.30 19:06:15 - OpenVPN > VERIFY EKU OK. 2016.03.30 19:06:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.03.30 19:06:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.30 19:06:16 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.30 19:06:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.30 19:06:16 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.30 19:06:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.03.30 19:06:16 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.24:443. 2016.03.30 19:06:18 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.03.30 19:06:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.74 255.255.0.0'. 2016.03.30 19:06:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.03.30 19:06:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.03.30 19:06:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.03.30 19:06:19 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.03.30 19:06:19 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.03.30 19:06:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.03.30 19:06:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.03.30 19:06:19 - OpenVPN > open_tun, tt->ipv6=0. 2016.03.30 19:06:19 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{9CEDD702-4A4A-4479-8B8C-F5BC55C6CFA2}.tap. 2016.03.30 19:06:19 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.03.30 19:06:19 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.74/255.255.0.0 [sUCCEEDED]. 2016.03.30 19:06:19 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.74/255.255.0.0 on interface {9CEDD702-4A4A-4479-8B8C-F5BC55C6CFA2} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.03.30 19:06:19 - OpenVPN > Successful ARP Flush on interface [8] {9CEDD702-4A4A-4479-8B8C-F5BC55C6CFA2}. 2016.03.30 19:06:24 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2016.03.30 19:06:24 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.24 MASK 255.255.255.255 192.168.1.1. 2016.03.30 19:06:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2016.03.30 19:06:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.30 19:06:24 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 3. 2016.03.30 19:06:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2016.03.30 19:06:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.30 19:06:24 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.03.30 19:06:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.03.30 19:06:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.30 19:06:24 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.03.30 19:06:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.03.30 19:06:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.30 19:06:24 - Starting Management Interface. 2016.03.30 19:06:24 - OpenVPN > Initialization Sequence CompletedI 2016.03.30 19:06:25 - DNS of a network adapter forced (Intel® Wireless-N 7260)I 2016.03.30 19:06:25 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.03.30 19:06:25 - Flushing DNSI 2016.03.30 19:06:25 - Checking routeI 2016.03.30 19:06:27 - Checking DNS! 2016.03.30 19:06:27 - Connected.. 2016.03.30 19:06:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.03.30 19:06:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.03.30 19:35:59 - Updating systems & servers data .... 2016.03.30 19:36:02 - Systems & servers data update completed. 2016.03.30 20:06:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.03.30 20:06:16 - OpenVPN > Validating certificate key usage. 2016.03.30 20:06:16 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.03.30 20:06:16 - OpenVPN > VERIFY KU OK. 2016.03.30 20:06:16 - OpenVPN > Validating certificate extended key usage. 2016.03.30 20:06:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.03.30 20:06:16 - OpenVPN > VERIFY EKU OK. 2016.03.30 20:06:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.03.30 20:06:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.30 20:06:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.30 20:06:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.30 20:06:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.30 20:06:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.03.30 20:06:38 - Updating systems & servers data .... 2016.03.30 20:06:40 - Systems & servers data update completed. 2016.03.30 20:37:35 - Updating systems & servers data .... 2016.03.30 20:37:36 - Systems & servers data update completed Quote Share this post Link to post
LZ1 678 Posted ... Hello ! Please do attach your logs, which you can find in the AirVPN client. Use spoiler tags too, if you can. You can try go into your network IPv4 adapter settings and set everything to "Obtain automatically". Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
me.moo@posteo.me 80 Posted ... Use spoiler tags too, You are doing a great job LZ1, I'm sure giganerd would not mind if you copied his how to link 2 Tech Jedi Alex and LZ1 reacted to this Quote Share this post Link to post
LZ1 678 Posted ... Use spoiler tags too, You are doing a great job LZ1, I'm sure giganerd would not mind if you copied his how to linkHaha, thank you x 2, it is done !If only I knew as much as you guys, then I'd be able to help out more ^^. 1 Tech Jedi Alex reacted to this Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
zhang888 1067 Posted ... There is nothing wrong in the logs you posted.What exactly did you experience from 19:06 to 20:06? Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
temo1993 0 Posted ... Hi sir! I think my problem is similar to "vpn loses connection during high network demand" topic, this what happen in my case ,my internet disconnect for about 5 min ,then when i troubleshoot it -this message show "Default Gateway is not available" ...Fixed , Maybe i can give TAP 9.9 a shot ? Quote Share this post Link to post
temo1993 0 Posted ... I tried to install TAP 9.9 , but seems it doesn't support windows 8.1 ? because i encounter an error during the install . Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... I tried to install TAP 9.9 , but seems it doesn't support windows 8.1 ? because i encounter an error during the install . Install 9.9.2 3.exe. Should work on Windows 8.1. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
