Not connected, Your IP: 216.73.216.190
squ1bby
Filejoker.net not working via Bellatrix
Morning,
Connected via Bellatrix (UK) and unable to access the filejoker.net website.  Get a 520 error from Cloudflare.
When I disconnect and route normally via my ISP, the website loads fine.
Regards,
S.
Many file hosting services and FileJoker restrict VPN usage. On the Cloudflare side, they have implemented certain settings that specifically block VPN connections. Unfortunately, this issue is very difficult to bypass. In most cases, users need to either switch to a residential IP or connect without a VPN, since data center IP ranges are often flagged and blocked automatically.
