Not connected, Your IP: 216.73.216.15
Dusya
Logged in on OSX, logging in on OpenVPN on 2 iOS devices generates error
I am logged in with the AirVPN client for OSX, but when i try to log in through OpenVPN on either my iPhone and iPad it fails.
There seems to be an authentication issue, but that's as far as I get, no clue what could cause it - sorry, quite the newbie with VPNs.
I could not find any forum topic on authentication issues on iOS devices, hence a new topic.
Below the log, any help would be greatly appreciated.
best regards,
D.
_____________________
2016-03-15 23:23:56 LZO-ASYM init swap=0 asym=1
2016-03-15 23:23:56 Comp-stub init swap=0
2016-03-15 23:23:56 EVENT: RESOLVE
2016-03-15 23:23:56 Contacting 213.152.161.39:443 via UDP
2016-03-15 23:23:56 EVENT: WAIT
2016-03-15 23:23:56 SetTunnelSocket returned 1
2016-03-15 23:23:56 Connecting to nl.vpn.airdns.org:443 (213.152.161.39) via UDPv4
2016-03-15 23:23:56 EVENT: CONNECTING
2016-03-15 23:23:56 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
2016-03-15 23:23:56 Peer Info:
IV_GUI_VER=net.openvpn.connect.ios 1.0.5-177
IV_VER=3.0
IV_PLAT=ios
IV_NCP=1
IV_SNAPPY=1
IV_LZO=1
IV_LZO_SWAP=1
IV_LZ4=1
IV_COMP_STUB=1
2016-03-15 23:23:56 VERIFY OK: depth=1
cert. version : 3
serial number : 8C:D8:43:EF:E4:5F:20:03
issuer name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
issued on : 2014-04-11 10:15:45
expires on : 2024-04-08 10:15:45
signed using : RSA with SHA1
RSA key size : 4096 bits
basic constraints : CA=true
2016-03-15 23:23:56 VERIFY OK: depth=0
cert. version : 3
serial number : B0
subject name : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
issued on : 2015-06-13 19:24:59
expires on : 2025-06-10 19:24:59
basic constraints : CA=false
cert. type : SSL Server
key usage : Digital Signature, Key Encipherment
ext key usage : TLS Web Server Authentication
2016-03-15 23:23:57 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-CBC-SHA
2016-03-15 23:23:57 Session is ACTIVE
2016-03-15 23:23:57 EVENT: GET_CONFIG
2016-03-15 23:23:57 Sending PUSH_REQUEST to server...
2016-03-15 23:23:57 AUTH_FAILED
2016-03-15 23:23:57 EVENT: AUTH_FAILED [ERR]
2016-03-15 23:23:57 EVENT: DISCONNECTED
2016-03-15 23:23:57 Raw stats on disconnect:
BYTES_IN : 4524
BYTES_OUT : 4003
PACKETS_IN : 12
PACKETS_OUT : 12
AUTH_FAILED : 1
2016-03-15 23:23:57 Performance stats on disconnect:
CPU usage (microseconds): 1323250
Network bytes per CPU second: 6443
Tunnel bytes per CPU second: 0
2016-03-15 23:23:57 EVENT: DISCONNECT_PENDING
2016-03-15 23:23:57 ----- OpenVPN Stop -----
2016-03-15 23:24:20 ----- OpenVPN Start -----
OpenVPN core 3.0 ios arm64 64-bit
2016-03-15 23:24:20 UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
6 [persist-key]
7 [persist-tun]
11 [verb] [3]
12 [explicit-exit-notify] [5]
2016-03-15 23:24:20 LZO-ASYM init swap=0 asym=1
2016-03-15 23:24:20 Comp-stub init swap=0
2016-03-15 23:24:20 EVENT: RESOLVE
2016-03-15 23:24:22 Contacting 199.241.146.162:443 via UDP
2016-03-15 23:24:22 EVENT: WAIT
2016-03-15 23:24:22 SetTunnelSocket returned 1
2016-03-15 23:24:22 Connecting to us.vpn.airdns.org:443 (199.241.146.162) via UDPv4
2016-03-15 23:24:22 EVENT: CONNECTING
2016-03-15 23:24:22 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
2016-03-15 23:24:22 Peer Info:
IV_VER=3.0
IV_PLAT=ios
IV_NCP=1
IV_SNAPPY=1
IV_LZO=1
IV_LZO_SWAP=1
IV_LZ4=1
IV_COMP_STUB=1
2016-03-15 23:24:22 VERIFY OK: depth=1
cert. version : 3
2016-03-15 23:24:22 VERIFY OK: depth=0
cert. version : 3
serial number : 7E
issued on : 2015-03-20 01:08:24
expires on : 2025-03-17 01:08:24
2016-03-15 23:24:24 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-CBC-SHA
2016-03-15 23:24:24 Session is ACTIVE
2016-03-15 23:24:24 EVENT: GET_CONFIG
2016-03-15 23:24:24 Sending PUSH_REQUEST to server...
2016-03-15 23:24:25 AUTH_FAILED
2016-03-15 23:24:25 EVENT: AUTH_FAILED [ERR]
2016-03-15 23:24:25 EVENT: DISCONNECTED
2016-03-15 23:24:25 Raw stats on disconnect:
BYTES_IN : 4523
BYTES_OUT : 4003
PACKETS_IN : 12
PACKETS_OUT : 12
AUTH_FAILED : 1
2016-03-15 23:24:25 Performance stats on disconnect:
CPU usage (microseconds): 1370021
Network bytes per CPU second: 6223
2016-03-15 23:24:25 EVENT: DISCONNECT_PENDING
2016-03-15 23:24:25 ----- OpenVPN Stop -----
2016-03-15 23:24:51 ----- OpenVPN Start -----
2016-03-15 23:24:51 UNUSED OPTIONS
5 [nobind]
6 [persist-key]
7 [persist-tun]
11 [verb] [3]
2016-03-15 23:24:51 LZO-ASYM init swap=0 asym=1
2016-03-15 23:24:51 Comp-stub init swap=0
2016-03-15 23:24:51 EVENT: RESOLVE
2016-03-15 23:24:51 Contacting 199.241.146.162:443 via UDP
2016-03-15 23:24:51 EVENT: WAIT
2016-03-15 23:24:51 SetTunnelSocket returned 1
2016-03-15 23:24:51 Connecting to us.vpn.airdns.org:443 (199.241.146.162) via UDPv4
2016-03-15 23:24:51 EVENT: CONNECTING
2016-03-15 23:24:51 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
2016-03-15 23:24:51 Peer Info:
IV_VER=3.0
IV_PLAT=ios
IV_NCP=1
IV_SNAPPY=1
IV_LZO=1
IV_LZO_SWAP=1
IV_LZ4=1
IV_COMP_STUB=1
2016-03-15 23:24:51 VERIFY OK: depth=1
cert. version : 3
2016-03-15 23:24:51 VERIFY OK: depth=0
cert. version : 3
serial number : 7E
2016-03-15 23:24:53 SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-CBC-SHA
2016-03-15 23:24:53 Session is ACTIVE
2016-03-15 23:24:53 EVENT: GET_CONFIG
2016-03-15 23:24:53 Sending PUSH_REQUEST to server...
2016-03-15 23:24:54 AUTH_FAILED
2016-03-15 23:24:54 EVENT: AUTH_FAILED [ERR]
2016-03-15 23:24:54 EVENT: DISCONNECTED
2016-03-15 23:24:54 Raw stats on disconnect:
BYTES_IN : 4523
BYTES_OUT : 4003
PACKETS_IN : 12
PACKETS_OUT : 12
AUTH_FAILED : 1
2016-03-15 23:24:54 Performance stats on disconnect:
CPU usage (microseconds): 1362241
Network bytes per CPU second: 6258
2016-03-15 23:24:54 EVENT: DISCONNECT_PENDING
2016-03-15 23:24:54 ----- OpenVPN Stop -----
