EchoAndSilence
MAC OSX + AirVPN...Suddenly Will Not Connect
So....What the heck...I am getting increasingly frustrated with my AirVPN service.  I've used it for months without issue.  I set it up, it works great, speeds are fast, I port forwarded a couple ports so that Plex would work correctly remotely.  Now all of a sudden it disconnects everyday...and then it just runs in a loop trying to connect and disconnect without any resolution.  I don't understand and would appreciate help.  It either gets stuck on Checking Route or it just loops continuously disconnecting.
Here's some recent logs:
. 2016.03.07 19:51:49 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2016.03.07 19:51:49 - Command line arguments (0):
. 2016.03.07 19:51:49 - Updating systems & servers data ...
. 2016.03.07 19:51:49 - Operating System: Unix 15.0.0.0 - Darwin MacMini.home 15.0.0 Darwin Kernel Version 15.0.0: Sat Sep 19 15:53:46 PDT 2015; root:xnu-3247.10.11~1/RELEASE_X86_64 x86_64
I 2016.03.07 19:51:49 - OpenVPN Driver - Expected
I 2016.03.07 19:51:49 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2016.03.07 19:51:49 - SSH - Version: OpenSSH_6.9p1, LibreSSL 2.1.7 (/usr/bin/ssh)
I 2016.03.07 19:51:49 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
I 2016.03.07 19:51:49 - Session starting.
I 2016.03.07 19:51:49 - IPv6 disabled on network adapter (Ethernet)
I 2016.03.07 19:51:50 - IPv6 disabled on network adapter (FireWire)
. 2016.03.07 19:51:50 - Systems & servers data update completed
I 2016.03.07 19:51:50 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.07 19:51:50 - IPv6 disabled on network adapter (iPad USB)
I 2016.03.07 19:51:50 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.07 19:51:51 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.07 19:51:51 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.07 19:51:55 - Checking authorization ...
! 2016.03.07 19:51:55 - Connecting to Pavonis (United States, Chicago, Illinois)
. 2016.03.07 19:51:55 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:51:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:51:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:51:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:51:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:51:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:51:55 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.07 19:51:55 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.07 19:51:55 - OpenVPN > UDPv4 link remote: [AF_INET]149.255.33.154:443
. 2016.03.07 19:51:55 - OpenVPN > TLS: Initial packet from [AF_INET]149.255.33.154:443, sid=dd33058b 7e16674b
. 2016.03.07 19:51:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:51:56 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:51:56 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:51:56 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:51:56 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:51:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:51:56 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:51:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:51:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:51:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:51:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:51:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:51:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:51:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]149.255.33.154:443
. 2016.03.07 19:52:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:52:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.173 255.255.0.0'
. 2016.03.07 19:52:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:52:01 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:52:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:52:01 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:52:01 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:52:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:52:01 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:52:01 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:52:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:52:01 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:52:01 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:52:01 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:52:01 - OpenVPN > /sbin/ifconfig utun2 10.4.25.173 10.4.25.173 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:52:01 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.25.173 255.255.0.0
. 2016.03.07 19:52:01 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:52:01 - OpenVPN > add net 10.4.0.0: gateway 10.4.25.173: File exists
. 2016.03.07 19:52:01 - OpenVPN > /sbin/route add -net 149.255.33.154 192.168.1.1 255.255.255.255
. 2016.03.07 19:52:01 - OpenVPN > add net 149.255.33.154: gateway 192.168.1.1: File exists
. 2016.03.07 19:52:01 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.07 19:52:01 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.07 19:52:01 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.07 19:52:01 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.07 19:52:01 - Starting Management Interface
. 2016.03.07 19:52:01 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:52:01 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:52:01 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:52:01 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:52:02 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:52:02 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:52:02 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:52:02 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:52:02 - Flushing DNS
I 2016.03.07 19:52:02 - Checking route
W 2016.03.07 19:52:52 - The request timed out
! 2016.03.07 19:52:52 - Disconnecting
. 2016.03.07 19:52:52 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:52:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:52:52 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.07 19:52:52 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:52:52 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.03.07 19:52:57 - OpenVPN > /sbin/route delete -net 149.255.33.154 192.168.1.1 255.255.255.255
. 2016.03.07 19:52:57 - OpenVPN > delete net 149.255.33.154: gateway 192.168.1.1
. 2016.03.07 19:52:57 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.07 19:52:57 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.07 19:52:57 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.07 19:52:57 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.07 19:52:57 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:52:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.07 19:52:57 - Connection terminated.
I 2016.03.07 19:52:57 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:52:57 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:52:57 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:52:58 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:52:58 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:52:58 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:52:58 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:52:58 - Cancel requested.
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (Ethernet)
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (FireWire)
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (iPad USB)
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.07 19:52:58 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.07 19:52:58 - Session terminated.
I 2016.03.07 19:53:30 - Session starting.
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (Ethernet)
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (FireWire)
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (iPad USB)
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.07 19:53:30 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.07 19:53:31 - Checking authorization ...
! 2016.03.07 19:53:31 - Connecting to Pavonis (United States, Chicago, Illinois)
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/5eabbd2776ebf495fd967346c0474935006c634a57092b91547813d5145dd814.tmp.ssl
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[ui]: Configuration successful
. 2016.03.07 19:53:31 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:53:31 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:53:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:53:31 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:53:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:31 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:53:31 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:29979 [nonblock]
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49775
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[0]: s_connect: connecting 149.255.33.156:443
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[0]: s_connect: connected 149.255.33.156:443
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49776
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[0]: SNI: sending servername: 149.255.33.156
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:53:32 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:29979
. 2016.03.07 19:53:32 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:53:32 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:29979
. 2016.03.07 19:53:32 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:29979, sid=b3994361 d320a1ec
. 2016.03.07 19:53:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:53:32 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:53:32 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:53:32 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:53:32 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:53:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:53:32 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:53:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:53:33 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:53:33 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:33 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:53:33 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:53:33 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:29979
. 2016.03.07 19:53:35 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:53:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.3.88 255.255.0.0'
. 2016.03.07 19:53:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:53:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:53:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:53:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:53:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:53:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:53:36 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:53:36 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:53:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:53:36 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:53:36 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:53:36 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:53:36 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:53:36 - OpenVPN > /sbin/ifconfig utun2 10.50.3.88 10.50.3.88 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:53:36 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.3.88 255.255.0.0
. 2016.03.07 19:53:36 - OpenVPN > add net 10.50.0.0: gateway 10.50.3.88: File exists
. 2016.03.07 19:53:36 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:53:36 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:53:36 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:53:36 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:53:36 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:53:36 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:53:36 - OpenVPN > /sbin/route add -net 149.255.33.156 192.168.1.1 255.255.255.255
. 2016.03.07 19:53:36 - OpenVPN > add net 149.255.33.156: gateway 192.168.1.1: File exists
. 2016.03.07 19:53:36 - Starting Management Interface
. 2016.03.07 19:53:36 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:53:36 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:53:36 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:53:36 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:53:36 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:53:36 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:53:36 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:53:37 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:53:37 - Flushing DNS
I 2016.03.07 19:53:37 - Checking route
. 2016.03.07 19:53:41 - SSL > 2016.03.07 19:53:41 LOG6[0]: SSL closed (SSL_read)
. 2016.03.07 19:53:41 - SSL > 2016.03.07 19:53:41 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:53:41 - SSL > 2016.03.07 19:53:41 LOG5[0]: Connection closed: 5563 byte(s) sent to SSL, 6262 byte(s) sent to socket
I 2016.03.07 19:53:43 - Checking DNS
! 2016.03.07 19:53:43 - Connected.
. 2016.03.07 19:53:43 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:53:43 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
. 2016.03.07 19:53:43 - OpenVPN > Connection reset, restarting [0]
. 2016.03.07 19:53:43 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.03.07 19:53:43 - OpenVPN > Restart pause, 5 second(s)
! 2016.03.07 19:53:44 - Disconnecting
. 2016.03.07 19:53:44 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:53:44 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:53:44 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.03.07 19:53:44 - OpenVPN > Assertion failed at misc.c:779
. 2016.03.07 19:53:44 - OpenVPN > Exiting due to fatal error
. 2016.03.07 19:53:44 - Connection terminated.
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:53:44 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:53:47 - Checking authorization ...
! 2016.03.07 19:53:48 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/32363f85920d3a88f379cf9a23d00c86824b9eb97c83f6c8091e479b6a17fb84.tmp.ssl
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[ui]: Configuration successful
. 2016.03.07 19:53:48 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:53:48 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49804
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:53:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:53:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:53:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:53:48 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49805
. 2016.03.07 19:53:48 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:24339 [nonblock]
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:53:48 - SSL > 2016.03.07 19:53:48 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:53:49 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:24339
. 2016.03.07 19:53:49 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:53:49 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:24339
. 2016.03.07 19:53:49 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:24339, sid=bbc2aa1c 02be35b0
. 2016.03.07 19:53:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:53:49 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:53:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:53:49 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:53:49 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:53:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:53:49 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:53:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:53:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:53:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:53:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:53:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:24339
. 2016.03.07 19:53:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:53:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:53:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:53:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:53:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:53:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:53:52 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:53:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:53:52 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:53:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:53:52 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:53:52 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:53:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:53:52 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:53:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:53:52 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:53:52 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:53:52 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:53:52 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:53:52 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1: File exists
. 2016.03.07 19:53:52 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:53:52 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1: File exists
. 2016.03.07 19:53:52 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:53:52 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1: File exists
. 2016.03.07 19:53:52 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:53:52 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1: File exists
. 2016.03.07 19:53:52 - Starting Management Interface
. 2016.03.07 19:53:52 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:53:53 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:53:53 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:53:53 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:53:53 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:53:53 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:53:53 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:53:53 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:53:53 - Flushing DNS
I 2016.03.07 19:53:53 - Checking route
E 2016.03.07 19:53:53 - Routing checking failed.
. 2016.03.07 19:53:53 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:53:54 - Disconnecting
. 2016.03.07 19:53:54 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:53:54 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:53:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:53:54 - SSL > 2016.03.07 19:53:54 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:53:54 - SSL > 2016.03.07 19:53:54 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:53:54 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:53:54 - SSL > 2016.03.07 19:53:54 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:53:54 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:53:54 - SSL > 2016.03.07 19:53:54 LOG5[0]: Connection closed: 5682 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:53:54 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:53:54 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:53:54 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:53:54 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:53:54 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:53:54 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:53:54 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:53:54 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.03.07 19:53:54 - Connection terminated.
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:53:54 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:53:57 - Checking authorization ...
! 2016.03.07 19:53:58 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/ad95cab477b3be1a850061634b5130bf8dfbb649149c0cbb0635a2131ca1e640.tmp.ssl
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[ui]: Configuration successful
. 2016.03.07 19:53:58 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:53:58 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49820
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:53:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:53:58 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:53:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49821
. 2016.03.07 19:53:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:53:58 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:53:58 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:7862 [nonblock]
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:53:58 - SSL > 2016.03.07 19:53:58 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:53:59 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:7862
. 2016.03.07 19:53:59 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:53:59 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:7862
. 2016.03.07 19:53:59 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:7862, sid=012743de 52666be9
. 2016.03.07 19:53:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:53:59 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:53:59 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:53:59 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:53:59 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:53:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:53:59 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:53:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:53:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:53:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:53:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:53:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:54:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:7862
. 2016.03.07 19:54:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:54:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:54:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:54:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:54:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:54:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:54:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:54:02 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:54:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:54:02 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:54:02 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:54:02 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:54:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:54:02 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:54:02 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:54:02 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:54:02 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:54:02 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:54:02 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:02 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:02 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:02 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:02 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:02 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:02 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:02 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:02 - Starting Management Interface
. 2016.03.07 19:54:02 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:54:03 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:54:03 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:54:03 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:54:03 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:54:03 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:54:03 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:54:03 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:54:03 - Flushing DNS
I 2016.03.07 19:54:03 - Checking route
E 2016.03.07 19:54:03 - Routing checking failed.
. 2016.03.07 19:54:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:54:04 - Disconnecting
. 2016.03.07 19:54:04 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:54:04 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:54:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:54:04 - SSL > 2016.03.07 19:54:04 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:54:04 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:04 - SSL > 2016.03.07 19:54:04 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:54:04 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:04 - SSL > 2016.03.07 19:54:04 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:54:04 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:04 - SSL > 2016.03.07 19:54:04 LOG5[0]: Connection closed: 5563 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:54:04 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:04 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:04 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:04 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:04 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:04 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:54:04 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.03.07 19:54:04 - Connection terminated.
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:54:04 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:54:07 - Checking authorization ...
! 2016.03.07 19:54:08 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/8ec74afa7192cda2ce23e9f95f3f8d706801c77c155172fba7c5f1d8b4b91735.tmp.ssl
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[ui]: Configuration successful
. 2016.03.07 19:54:08 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:54:08 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49845
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:54:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:54:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:54:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49846
. 2016.03.07 19:54:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:54:08 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:54:08 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:18166 [nonblock]
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:54:08 - SSL > 2016.03.07 19:54:08 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:54:09 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:18166
. 2016.03.07 19:54:09 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:54:09 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:18166
. 2016.03.07 19:54:09 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:18166, sid=6b55ff13 9f1d195a
. 2016.03.07 19:54:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:54:09 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:54:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:54:09 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:54:09 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:54:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:54:09 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:54:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:54:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:54:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:18166
. 2016.03.07 19:54:12 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:54:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:54:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:54:12 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:54:12 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:54:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:54:12 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:54:12 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:54:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:54:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:54:12 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:54:12 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:54:12 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:54:12 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:54:12 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:54:12 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:54:12 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:54:12 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:54:12 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:12 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:12 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:12 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:12 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:12 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:12 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:12 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:12 - Starting Management Interface
. 2016.03.07 19:54:12 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:54:12 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:54:12 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:54:13 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:54:13 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:54:13 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:54:13 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:54:13 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:54:13 - Flushing DNS
I 2016.03.07 19:54:13 - Checking route
E 2016.03.07 19:54:13 - Routing checking failed.
. 2016.03.07 19:54:13 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:54:13 - Disconnecting
. 2016.03.07 19:54:13 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:54:13 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:54:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:54:13 - SSL > 2016.03.07 19:54:13 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:54:13 - SSL > 2016.03.07 19:54:13 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:54:13 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:13 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:13 - SSL > 2016.03.07 19:54:13 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:54:13 - SSL > 2016.03.07 19:54:13 LOG5[0]: Connection closed: 5563 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:54:13 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:13 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:13 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:13 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:13 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:13 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:13 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:54:13 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.03.07 19:54:14 - Connection terminated.
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:54:14 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:54:17 - Checking authorization ...
! 2016.03.07 19:54:17 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/1f3c45235dec0f54b6d59616a317f10b2309f995d7e1d9736c6853e7b4976ed9.tmp.ssl
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[ui]: Configuration successful
. 2016.03.07 19:54:17 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:54:17 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49864
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:54:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:54:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:54:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49865
. 2016.03.07 19:54:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:54:17 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:54:17 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:63304 [nonblock]
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:54:17 - SSL > 2016.03.07 19:54:17 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:54:18 - SSL > 2016.03.07 19:54:17 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:54:18 - SSL > 2016.03.07 19:54:17 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:54:18 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:63304
. 2016.03.07 19:54:18 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:54:18 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:63304
. 2016.03.07 19:54:18 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:63304, sid=62e05e4c 161ca9cf
. 2016.03.07 19:54:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:54:18 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:54:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:54:19 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:54:19 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:54:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:54:19 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:54:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:54:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:54:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:63304
. 2016.03.07 19:54:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:54:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:54:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:54:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:54:21 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:54:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:54:21 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:54:21 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:54:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:54:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:54:21 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:54:21 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:54:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:54:21 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:54:21 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:54:21 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:54:21 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:54:22 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:54:22 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:22 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:22 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:22 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:22 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:22 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:22 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:22 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:22 - Starting Management Interface
. 2016.03.07 19:54:22 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:54:22 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:54:22 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:54:22 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:54:22 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:54:22 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:54:22 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:54:22 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:54:23 - Flushing DNS
I 2016.03.07 19:54:23 - Checking route
E 2016.03.07 19:54:23 - Routing checking failed.
. 2016.03.07 19:54:23 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:54:23 - Disconnecting
. 2016.03.07 19:54:23 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:54:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:54:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:54:23 - SSL > 2016.03.07 19:54:23 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:54:23 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:23 - SSL > 2016.03.07 19:54:23 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:54:23 - SSL > 2016.03.07 19:54:23 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:54:23 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:23 - SSL > 2016.03.07 19:54:23 LOG5[0]: Connection closed: 5682 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:54:23 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:23 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:23 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:23 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:23 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:23 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:23 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:54:23 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.03.07 19:54:24 - Connection terminated.
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:54:24 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:54:27 - Checking authorization ...
! 2016.03.07 19:54:28 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/18844ca992e8762f5b0136c7b96d547eb904a7321bcbaaa3304401ba43109096.tmp.ssl
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[ui]: Configuration successful
. 2016.03.07 19:54:28 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:54:28 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49882
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:54:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:54:28 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:54:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:54:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49883
. 2016.03.07 19:54:28 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:54:28 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:19396 [nonblock]
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:54:28 - SSL > 2016.03.07 19:54:28 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:54:29 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:19396
. 2016.03.07 19:54:29 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:54:29 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:19396
. 2016.03.07 19:54:29 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:19396, sid=d1b97227 75016bd8
. 2016.03.07 19:54:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:54:29 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:54:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:54:29 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:54:29 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:54:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:54:29 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:54:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:54:29 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:29 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:29 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:29 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:54:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:19396
. 2016.03.07 19:54:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:54:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:54:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:54:32 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:54:32 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:54:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:54:32 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:54:32 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:54:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:54:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:54:32 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:54:32 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:54:32 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:54:32 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:54:32 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:54:32 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:54:32 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:54:32 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:54:32 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:32 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:32 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:32 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:32 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:32 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:32 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:32 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:32 - Starting Management Interface
. 2016.03.07 19:54:32 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:54:32 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:54:32 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:54:32 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:54:33 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:54:33 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:54:33 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:54:33 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:54:33 - Flushing DNS
I 2016.03.07 19:54:33 - Checking route
E 2016.03.07 19:54:33 - Routing checking failed.
. 2016.03.07 19:54:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:54:33 - Disconnecting
. 2016.03.07 19:54:33 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:54:33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:54:33 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:54:33 - SSL > 2016.03.07 19:54:33 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:54:33 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:33 - SSL > 2016.03.07 19:54:33 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:54:33 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:33 - SSL > 2016.03.07 19:54:33 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:54:33 - SSL > 2016.03.07 19:54:33 LOG5[0]: Connection closed: 5563 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:54:33 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:33 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:33 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:33 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:33 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:33 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:33 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:54:33 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2016.03.07 19:54:33 - Connection terminated.
I 2016.03.07 19:54:33 - DNS of a network adapter restored to original settings (Ethernet)
I 2016.03.07 19:54:33 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:54:34 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:54:34 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:54:34 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:54:34 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:54:34 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:54:37 - Checking authorization ...
! 2016.03.07 19:54:37 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/719a44e522e04f4a253b95d6e92ca7800e3d1cc8671535ae67b1e9b5171668e2.tmp.ssl
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:54:37 - SSL > 2016.03.07 19:54:37 LOG5[ui]: Configuration successful
. 2016.03.07 19:54:37 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:54:38 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:37 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49900
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:37 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:54:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:37 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:54:38 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:54:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49901
. 2016.03.07 19:54:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:54:38 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:54:38 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:16322 [nonblock]
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:54:38 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:16322
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:54:38 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:54:38 - SSL > 2016.03.07 19:54:38 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:54:38 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:16322
. 2016.03.07 19:54:38 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:16322, sid=1b0c33c6 ec8306cd
. 2016.03.07 19:54:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:54:38 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:54:38 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:54:38 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:54:38 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:54:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:54:38 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:54:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:54:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:54:39 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:16322
. 2016.03.07 19:54:41 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:54:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:54:41 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:54:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:54:41 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:54:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:54:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:54:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:54:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:54:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:54:42 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:54:42 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:54:42 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:54:42 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:54:42 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:54:42 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:54:42 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:54:42 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:54:42 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:42 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:42 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:42 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:42 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:42 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:42 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:42 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:42 - Starting Management Interface
. 2016.03.07 19:54:42 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:54:42 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:54:43 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:54:43 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:54:43 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:54:43 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:54:43 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:54:43 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:54:44 - Flushing DNS
I 2016.03.07 19:54:44 - Checking route
E 2016.03.07 19:54:44 - Routing checking failed.
. 2016.03.07 19:54:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:54:44 - Disconnecting
. 2016.03.07 19:54:44 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:54:44 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:54:44 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:54:44 - SSL > 2016.03.07 19:54:44 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:54:44 - SSL > 2016.03.07 19:54:44 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:54:44 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:44 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:44 - SSL > 2016.03.07 19:54:44 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:54:44 - SSL > 2016.03.07 19:54:44 LOG5[0]: Connection closed: 5563 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:54:44 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:44 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:44 - Connection terminated.
. 2016.03.07 19:54:44 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
I 2016.03.07 19:54:44 - DNS of a network adapter restored to original settings (Ethernet)
. 2016.03.07 19:54:45 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:45 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
I 2016.03.07 19:54:45 - DNS of a network adapter restored to original settings (FireWire)
. 2016.03.07 19:54:45 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
I 2016.03.07 19:54:45 - DNS of a network adapter restored to original settings (Wi-Fi)
. 2016.03.07 19:54:45 - OpenVPN > Closing TUN/TAP interface
I 2016.03.07 19:54:45 - DNS of a network adapter restored to original settings (iPad USB)
. 2016.03.07 19:54:45 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2016.03.07 19:54:45 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:54:45 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:54:45 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.07 19:54:49 - Checking authorization ...
! 2016.03.07 19:54:49 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[ui]: stunnel 5.17 on x86_64-apple-darwin14.3.0 platform
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[ui]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[ui]: Reading configuration from file /Users/aaronsnow/.airvpn/44e01c75c213a3f84abc8fa1d6603861e225fce1c322e2991faad116b533a588.tmp.ssl
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[ui]: UTF-8 byte order mark not detected
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[ui]: Initializing service [openvpn]
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[ui]: Configuration successful
. 2016.03.07 19:54:49 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.07 19:54:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49923
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[0]: Failover strategy: round-robin
. 2016.03.07 19:54:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3103
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[0]: s_connect: connecting 104.254.90.252:443
. 2016.03.07 19:54:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.07 19:54:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[0]: s_connect: connected 104.254.90.252:443
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.7:49924
. 2016.03.07 19:54:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[0]: SNI: sending servername: 104.254.90.252
. 2016.03.07 19:54:49 - OpenVPN > Socket Buffers: R=[131072->131072] S=[131072->131072]
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[0]: CERT: Locally installed certificate matched
. 2016.03.07 19:54:49 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:35968 [nonblock]
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[0]: SSL connected: new session negotiated
. 2016.03.07 19:54:49 - SSL > 2016.03.07 19:54:49 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2016.03.07 19:54:50 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:35968
. 2016.03.07 19:54:50 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.03.07 19:54:50 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:35968
. 2016.03.07 19:54:50 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:35968, sid=3de791ea 460720e6
. 2016.03.07 19:54:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.07 19:54:50 - OpenVPN > Validating certificate key usage
. 2016.03.07 19:54:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.07 19:54:50 - OpenVPN > VERIFY KU OK
. 2016.03.07 19:54:50 - OpenVPN > Validating certificate extended key usage
. 2016.03.07 19:54:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.07 19:54:50 - OpenVPN > VERIFY EKU OK
. 2016.03.07 19:54:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.07 19:54:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.07 19:54:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.07 19:54:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.07 19:54:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:35968
. 2016.03.07 19:54:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.07 19:54:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.89 255.255.0.0'
. 2016.03.07 19:54:53 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.07 19:54:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.07 19:54:53 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.07 19:54:54 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.07 19:54:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.07 19:54:54 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.07 19:54:54 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.07 19:54:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.07 19:54:55 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.07 19:54:55 - OpenVPN > Opened utun device utun2
. 2016.03.07 19:54:55 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.07 19:54:55 - OpenVPN > /sbin/ifconfig utun2 delete
. 2016.03.07 19:54:55 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.07 19:54:55 - OpenVPN > /sbin/ifconfig utun2 10.50.4.89 10.50.4.89 netmask 255.255.0.0 mtu 1500 up
. 2016.03.07 19:54:55 - OpenVPN > /sbin/route add -net 10.50.0.0 10.50.4.89 255.255.0.0
. 2016.03.07 19:54:55 - OpenVPN > add net 10.50.0.0: gateway 10.50.4.89: File exists
. 2016.03.07 19:54:55 - OpenVPN > /sbin/route add -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:55 - OpenVPN > add net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:55 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:55 - OpenVPN > add net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:55 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:55 - OpenVPN > add net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:55 - OpenVPN > /sbin/route add -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:55 - OpenVPN > add net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:55 - Starting Management Interface
. 2016.03.07 19:54:55 - OpenVPN > Initialization Sequence Completed
I 2016.03.07 19:54:55 - DNS of a network adapter forced (Ethernet)
I 2016.03.07 19:54:55 - DNS of a network adapter forced (FireWire)
I 2016.03.07 19:54:56 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.07 19:54:56 - DNS of a network adapter forced (iPad USB)
I 2016.03.07 19:54:56 - DNS of a network adapter forced (iPhone USB)
I 2016.03.07 19:54:56 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.07 19:54:56 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.07 19:54:56 - Flushing DNS
I 2016.03.07 19:54:56 - Checking route
E 2016.03.07 19:54:57 - Routing checking failed.
. 2016.03.07 19:54:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3103
! 2016.03.07 19:54:57 - Disconnecting
. 2016.03.07 19:54:57 - Management - Send 'signal SIGTERM'
. 2016.03.07 19:54:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.07 19:54:57 - SSL > 2016.03.07 19:54:57 LOG6[0]: Read socket closed (readsocket)
. 2016.03.07 19:54:57 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.07 19:54:57 - SSL > 2016.03.07 19:54:57 LOG6[0]: SSL_shutdown successfully sent close_notify alert
. 2016.03.07 19:54:57 - OpenVPN > /sbin/route delete -net 104.254.90.252 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:57 - SSL > 2016.03.07 19:54:57 LOG3[0]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2016.03.07 19:54:57 - OpenVPN > delete net 104.254.90.252: gateway 192.168.1.1
. 2016.03.07 19:54:57 - SSL > 2016.03.07 19:54:57 LOG5[0]: Connection closed: 5682 byte(s) sent to SSL, 6263 byte(s) sent to socket
. 2016.03.07 19:54:57 - OpenVPN > /sbin/route delete -net 127.0.0.1 192.168.1.1 255.255.255.255
. 2016.03.07 19:54:57 - OpenVPN > delete net 127.0.0.1: gateway 192.168.1.1
. 2016.03.07 19:54:57 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:57 - OpenVPN > delete net 0.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:57 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.0.1 128.0.0.0
. 2016.03.07 19:54:57 - Connection terminated.
I 2016.03.07 19:54:57 - DNS of a network adapter restored to original settings (Ethernet)
. 2016.03.07 19:54:57 - OpenVPN > delete net 128.0.0.0: gateway 10.50.0.1
. 2016.03.07 19:54:57 - OpenVPN > Closing TUN/TAP interface
. 2016.03.07 19:54:57 - OpenVPN > SIGTERM[hard,] received, process exiting
I 2016.03.07 19:54:57 - DNS of a network adapter restored to original settings (FireWire)
I 2016.03.07 19:54:57 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.07 19:54:57 - DNS of a network adapter restored to original settings (iPad USB)
I 2016.03.07 19:54:58 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.07 19:54:58 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.07 19:54:58 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I've been having the same problem today. Neither couldn't connect through Germany nor through Netherlands/Lithuania (closest countries to mine). Yesterday everything was working fine, but today - no cigar. Restarting didn't help. Tried to use the service on 2 different WiFi's, but couldn't connect. Example log:
. 2016.03.21 12:43:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 12:43:55 - OpenVPN > Validating certificate key usage
. 2016.03.21 12:43:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 12:43:55 - OpenVPN > VERIFY KU OK
. 2016.03.21 12:43:55 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 12:43:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 12:43:55 - OpenVPN > VERIFY EKU OK
. 2016.03.21 12:43:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 12:43:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 12:43:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 12:43:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 12:43:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 12:43:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 12:43:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.148:443
. 2016.03.21 12:44:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 12:44:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.59.195 255.255.0.0'
. 2016.03.21 12:44:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 12:44:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 12:44:02 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 12:44:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 12:44:02 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 12:44:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 12:44:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 12:44:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 12:44:02 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 12:44:02 - OpenVPN > Opened utun device utun1
. 2016.03.21 12:44:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 12:44:02 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 12:44:02 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 12:44:02 - OpenVPN > /sbin/ifconfig utun1 10.4.59.195 10.4.59.195 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 12:44:02 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.59.195 255.255.0.0
. 2016.03.21 12:44:02 - OpenVPN > add net 10.4.0.0: gateway 10.4.59.195: File exists
. 2016.03.21 12:44:02 - OpenVPN > /sbin/route add -net 109.232.227.148 10.60.21.1 255.255.255.255
. 2016.03.21 12:44:02 - OpenVPN > add net 109.232.227.148: gateway 10.60.21.1
. 2016.03.21 12:44:02 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:44:02 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:44:02 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:44:02 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:44:02 - Starting Management Interface
. 2016.03.21 12:44:02 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 12:44:02 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 12:44:02 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 12:44:02 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 12:44:02 - DNS of a network adapter forced (TomTom)
I 2016.03.21 12:44:02 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 12:44:02 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 12:44:03 - Flushing DNS
I 2016.03.21 12:44:03 - Checking route
W 2016.03.21 12:44:53 - The request timed out
! 2016.03.21 12:44:53 - Disconnecting
. 2016.03.21 12:44:53 - Management - Send 'signal SIGTERM'
. 2016.03.21 12:44:53 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 12:44:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 12:44:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 12:44:58 - OpenVPN > /sbin/route delete -net 109.232.227.148 10.60.21.1 255.255.255.255
. 2016.03.21 12:44:58 - OpenVPN > delete net 109.232.227.148: gateway 10.60.21.1
. 2016.03.21 12:44:58 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:44:58 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:44:58 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:44:58 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:44:58 - Connection terminated.
. 2016.03.21 12:44:58 - OpenVPN > Closing TUN/TAP interface
I 2016.03.21 12:44:58 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2016.03.21 12:44:58 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2016.03.21 12:44:58 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 12:44:58 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 12:44:58 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 12:44:58 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 12:44:58 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 12:44:59 - Cancel requested.
I 2016.03.21 12:44:59 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 12:44:59 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 12:44:59 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 12:44:59 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 12:44:59 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 12:44:59 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 12:44:59 - Session terminated.
I 2016.03.21 12:45:26 - Session starting.
I 2016.03.21 12:45:26 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.03.21 12:45:26 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.21 12:45:26 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.21 12:45:26 - IPv6 disabled on network adapter (TomTom)
I 2016.03.21 12:45:27 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.21 12:45:27 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.21 12:45:27 - Checking authorization ...
! 2016.03.21 12:45:27 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2016.03.21 12:45:27 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 12:45:27 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 12:45:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 12:45:27 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 12:45:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 12:45:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 12:45:27 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 12:45:27 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 12:45:27 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.132:443
. 2016.03.21 12:45:27 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.132:443, sid=65a7b565 dc49e7ad
. 2016.03.21 12:45:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 12:45:27 - OpenVPN > Validating certificate key usage
. 2016.03.21 12:45:27 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 12:45:27 - OpenVPN > VERIFY KU OK
. 2016.03.21 12:45:27 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 12:45:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 12:45:27 - OpenVPN > VERIFY EKU OK
. 2016.03.21 12:45:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 12:45:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 12:45:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 12:45:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 12:45:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 12:45:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 12:45:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.132:443
. 2016.03.21 12:45:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 12:45:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.8 255.255.0.0'
. 2016.03.21 12:45:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 12:45:32 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 12:45:32 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 12:45:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 12:45:32 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 12:45:32 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 12:45:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 12:45:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 12:45:32 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 12:45:32 - OpenVPN > Opened utun device utun1
. 2016.03.21 12:45:32 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 12:45:32 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 12:45:32 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 12:45:32 - OpenVPN > /sbin/ifconfig utun1 10.4.53.8 10.4.53.8 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 12:45:32 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.8 255.255.0.0
. 2016.03.21 12:45:32 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.8: File exists
. 2016.03.21 12:45:32 - OpenVPN > /sbin/route add -net 213.152.161.132 10.60.21.1 255.255.255.255
. 2016.03.21 12:45:32 - OpenVPN > add net 213.152.161.132: gateway 10.60.21.1
. 2016.03.21 12:45:32 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:45:32 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:45:32 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:45:32 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:45:32 - Starting Management Interface
. 2016.03.21 12:45:32 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 12:45:32 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 12:45:32 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 12:45:32 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 12:45:33 - DNS of a network adapter forced (TomTom)
I 2016.03.21 12:45:33 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 12:45:33 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 12:45:33 - Flushing DNS
I 2016.03.21 12:45:33 - Checking route
W 2016.03.21 12:46:23 - The request timed out
! 2016.03.21 12:46:23 - Disconnecting
. 2016.03.21 12:46:23 - Management - Send 'signal SIGTERM'
. 2016.03.21 12:46:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 12:46:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 12:46:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 12:46:28 - OpenVPN > /sbin/route delete -net 213.152.161.132 10.60.21.1 255.255.255.255
. 2016.03.21 12:46:28 - OpenVPN > delete net 213.152.161.132: gateway 10.60.21.1
. 2016.03.21 12:46:28 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:46:28 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:46:28 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 12:46:28 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 12:46:28 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 12:46:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 12:46:28 - Connection terminated.
I 2016.03.21 12:46:28 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 12:46:28 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 12:46:28 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 12:46:28 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 12:46:28 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 12:46:28 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 12:46:28 - Cancel requested.
I 2016.03.21 12:46:28 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 12:46:28 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 12:46:28 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 12:46:28 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 12:46:28 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 12:46:28 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 12:46:28 - Session terminated.
! 2016.03.21 12:46:29 - Deactivation of Network Lock
. 2016.03.21 13:06:48 - Updating systems & servers data ...
. 2016.03.21 13:06:49 - Systems & servers data update completed
. 2016.03.21 13:37:37 - Updating systems & servers data ...
. 2016.03.21 13:37:38 - Systems & servers data update completed
. 2016.03.21 14:08:27 - Updating systems & servers data ...
. 2016.03.21 14:08:27 - Systems & servers data update completed
. 2016.03.21 14:39:20 - Updating systems & servers data ...
. 2016.03.21 14:39:21 - Systems & servers data update completed
. 2016.03.21 15:10:22 - Updating systems & servers data ...
. 2016.03.21 15:10:23 - Systems & servers data update completed
. 2016.03.21 15:41:13 - Updating systems & servers data ...
. 2016.03.21 15:41:14 - Systems & servers data update completed
. 2016.03.21 18:56:51 - Updating systems & servers data ...
. 2016.03.21 18:56:51 - Systems & servers data update completed
. 2016.03.21 21:20:19 - Updating systems & servers data ...
. 2016.03.21 21:20:20 - Systems & servers data update completed
! 2016.03.21 21:20:56 - Activation of Network Lock - OS X - PF
. 2016.03.21 21:20:56 - OS X - PF rules updated, reloading
I 2016.03.21 21:21:04 - Session starting.
I 2016.03.21 21:21:04 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.03.21 21:21:05 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.21 21:21:05 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.21 21:21:05 - IPv6 disabled on network adapter (TomTom)
I 2016.03.21 21:21:05 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.21 21:21:05 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.21 21:21:05 - Checking authorization ...
! 2016.03.21 21:21:05 - Connecting to Talitha (Netherlands, Alblasserdam)
. 2016.03.21 21:21:05 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:21:05 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:21:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:21:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:21:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:21:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:21:05 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:21:05 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:21:05 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.137:443
. 2016.03.21 21:21:05 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.137:443, sid=3d64a411 7d5e226a
. 2016.03.21 21:21:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:21:06 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:21:06 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:21:06 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:21:06 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:21:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:21:06 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:21:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:21:09 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:21:09 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:21:09 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:21:09 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:21:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:21:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.137:443
. 2016.03.21 21:21:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:21:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.252 255.255.0.0'
. 2016.03.21 21:21:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:21:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:21:11 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:21:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:21:11 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:21:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:21:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:21:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:21:12 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:21:12 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:21:12 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:21:12 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:21:12 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:21:12 - OpenVPN > /sbin/ifconfig utun1 10.4.53.252 10.4.53.252 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:21:12 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.252 255.255.0.0
. 2016.03.21 21:21:12 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.252: File exists
. 2016.03.21 21:21:12 - OpenVPN > /sbin/route add -net 213.152.161.137 192.168.0.1 255.255.255.255
. 2016.03.21 21:21:12 - OpenVPN > add net 213.152.161.137: gateway 192.168.0.1
. 2016.03.21 21:21:12 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:21:12 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:21:12 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:21:12 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:21:12 - Starting Management Interface
. 2016.03.21 21:21:12 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:21:12 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:21:12 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:21:12 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:21:12 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:21:12 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:21:12 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:21:12 - Flushing DNS
I 2016.03.21 21:21:12 - Checking route
W 2016.03.21 21:22:02 - The request timed out
! 2016.03.21 21:22:03 - Disconnecting
. 2016.03.21 21:22:03 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:22:03 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:22:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:22:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:22:08 - OpenVPN > /sbin/route delete -net 213.152.161.137 192.168.0.1 255.255.255.255
. 2016.03.21 21:22:08 - OpenVPN > delete net 213.152.161.137: gateway 192.168.0.1
. 2016.03.21 21:22:08 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:22:08 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:22:08 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:22:08 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:22:08 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:22:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:22:08 - Connection terminated.
I 2016.03.21 21:22:08 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:22:08 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:22:08 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:22:08 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:22:09 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:22:09 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:22:09 - Cancel requested.
I 2016.03.21 21:22:09 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 21:22:09 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 21:22:09 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 21:22:09 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 21:22:09 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 21:22:09 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 21:22:09 - Session terminated.
I 2016.03.21 21:22:11 - Session starting.
I 2016.03.21 21:22:11 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.03.21 21:22:11 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.21 21:22:11 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.21 21:22:11 - IPv6 disabled on network adapter (TomTom)
I 2016.03.21 21:22:11 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.21 21:22:12 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.21 21:22:12 - Checking authorization ...
! 2016.03.21 21:22:12 - Connecting to Aquilae (Germany, Frankfurt)
. 2016.03.21 21:22:12 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:22:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:22:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:22:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:22:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:22:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:22:12 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:22:12 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:22:12 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.70:443
. 2016.03.21 21:22:12 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.70:443, sid=55b099ad 347fe1c9
. 2016.03.21 21:22:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:22:12 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:22:12 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:22:12 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:22:12 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:22:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:22:12 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:22:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:22:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:22:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:22:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:22:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:22:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:22:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.70:443
. 2016.03.21 21:22:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:22:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.16.165 255.255.0.0'
. 2016.03.21 21:22:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:22:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:22:20 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:22:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:22:20 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:22:20 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:22:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:22:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:22:20 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:22:20 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:22:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:22:20 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:22:20 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:22:20 - OpenVPN > /sbin/ifconfig utun1 10.4.16.165 10.4.16.165 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:22:20 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.16.165 255.255.0.0
. 2016.03.21 21:22:20 - OpenVPN > add net 10.4.0.0: gateway 10.4.16.165: File exists
. 2016.03.21 21:22:20 - OpenVPN > /sbin/route add -net 46.165.208.70 192.168.0.1 255.255.255.255
. 2016.03.21 21:22:20 - OpenVPN > add net 46.165.208.70: gateway 192.168.0.1
. 2016.03.21 21:22:20 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:22:20 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:22:20 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:22:20 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:22:20 - Starting Management Interface
. 2016.03.21 21:22:20 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:22:21 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:22:21 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:22:21 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:22:21 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:22:21 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:22:21 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:22:21 - Flushing DNS
I 2016.03.21 21:22:21 - Checking route
W 2016.03.21 21:23:11 - The request timed out
! 2016.03.21 21:23:11 - Disconnecting
. 2016.03.21 21:23:11 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:23:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:23:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:23:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:23:16 - OpenVPN > /sbin/route delete -net 46.165.208.70 192.168.0.1 255.255.255.255
. 2016.03.21 21:23:16 - OpenVPN > delete net 46.165.208.70: gateway 192.168.0.1
. 2016.03.21 21:23:16 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:23:16 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:23:16 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:23:16 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:23:16 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:23:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:23:16 - Connection terminated.
I 2016.03.21 21:23:16 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:23:17 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:23:17 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:23:17 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:23:17 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:23:17 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:23:17 - Cancel requested.
I 2016.03.21 21:23:17 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 21:23:17 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 21:23:17 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 21:23:17 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 21:23:17 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 21:23:17 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 21:23:17 - Session terminated.
. 2016.03.21 21:24:06 - Updating systems & servers data ...
. 2016.03.21 21:24:07 - Systems & servers data update completed
I 2016.03.21 21:24:38 - Session starting.
I 2016.03.21 21:24:39 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.03.21 21:24:39 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.21 21:24:39 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.21 21:24:39 - IPv6 disabled on network adapter (TomTom)
I 2016.03.21 21:24:39 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.21 21:24:39 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.21 21:24:39 - Checking authorization ...
! 2016.03.21 21:24:39 - Connecting to Merga (Netherlands, Alblasserdam)
. 2016.03.21 21:24:39 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:24:39 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:24:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:24:39 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:24:39 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:24:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:24:40 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:24:40 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:24:40 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443
. 2016.03.21 21:24:40 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=f613d9b6 a6241779
. 2016.03.21 21:24:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:24:40 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:24:40 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:24:40 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:24:40 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:24:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:24:40 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:24:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:24:40 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:24:40 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:24:40 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:24:40 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:24:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:24:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443
. 2016.03.21 21:24:42 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:24:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.167 255.255.0.0'
. 2016.03.21 21:24:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:24:42 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:24:42 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:24:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:24:42 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:24:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:24:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:24:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:24:42 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:24:42 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:24:42 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:24:42 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:24:42 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:24:42 - OpenVPN > /sbin/ifconfig utun1 10.4.53.167 10.4.53.167 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:24:42 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.167 255.255.0.0
. 2016.03.21 21:24:42 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.167: File exists
. 2016.03.21 21:24:43 - OpenVPN > /sbin/route add -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:24:43 - OpenVPN > add net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:24:43 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:24:43 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:24:43 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:24:43 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:24:43 - Starting Management Interface
. 2016.03.21 21:24:43 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:24:43 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:24:43 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:24:43 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:24:43 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:24:43 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:24:43 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:24:43 - Flushing DNS
I 2016.03.21 21:24:43 - Checking route
W 2016.03.21 21:25:33 - The request timed out
! 2016.03.21 21:25:33 - Disconnecting
. 2016.03.21 21:25:33 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:25:33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:25:33 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:25:33 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:25:38 - OpenVPN > /sbin/route delete -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:25:38 - OpenVPN > delete net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:25:38 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:25:38 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:25:38 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:25:38 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:25:38 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:25:38 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:25:38 - Connection terminated.
I 2016.03.21 21:25:38 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:25:38 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:25:38 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:25:38 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:25:38 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:25:38 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:25:42 - Checking authorization ...
! 2016.03.21 21:25:42 - Connecting to Merga (Netherlands, Alblasserdam)
. 2016.03.21 21:25:42 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:25:42 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:25:42 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:25:42 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:25:42 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:25:42 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:25:42 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:25:42 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:25:42 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443
. 2016.03.21 21:25:42 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=7eb17801 889d72ce
. 2016.03.21 21:25:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:25:42 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:25:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:25:42 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:25:42 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:25:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:25:42 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:25:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:25:43 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:25:43 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:25:43 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:25:43 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:25:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:25:43 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443
. 2016.03.21 21:25:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:25:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.167 255.255.0.0'
. 2016.03.21 21:25:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:25:45 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:25:45 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:25:45 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:25:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:25:45 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:25:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:25:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:25:45 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:25:45 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:25:45 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:25:45 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:25:45 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:25:45 - OpenVPN > /sbin/ifconfig utun1 10.4.53.167 10.4.53.167 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:25:45 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.167 255.255.0.0
. 2016.03.21 21:25:45 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.167: File exists
. 2016.03.21 21:25:45 - OpenVPN > /sbin/route add -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:25:45 - OpenVPN > add net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:25:45 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:25:45 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:25:45 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:25:45 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:25:45 - Starting Management Interface
. 2016.03.21 21:25:45 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:25:45 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:25:45 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:25:45 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:25:46 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:25:46 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:25:46 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:25:46 - Flushing DNS
I 2016.03.21 21:25:46 - Checking route
W 2016.03.21 21:26:36 - The request timed out
! 2016.03.21 21:26:36 - Disconnecting
. 2016.03.21 21:26:36 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:26:36 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:26:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:26:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:26:41 - OpenVPN > /sbin/route delete -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:26:41 - OpenVPN > delete net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:26:41 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:26:41 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:26:41 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:26:41 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:26:41 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:26:41 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:26:41 - Connection terminated.
I 2016.03.21 21:26:41 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:26:41 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:26:41 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:26:41 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:26:41 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:26:41 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:26:44 - Checking authorization ...
! 2016.03.21 21:26:45 - Connecting to Merga (Netherlands, Alblasserdam)
. 2016.03.21 21:26:45 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:26:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:26:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:26:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:26:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:26:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:26:45 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:26:45 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:26:45 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443
. 2016.03.21 21:26:45 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=041dfa77 83203fb7
. 2016.03.21 21:26:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:26:45 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:26:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:26:45 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:26:45 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:26:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:26:45 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:26:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:26:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:26:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:26:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:26:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:26:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:26:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443
. 2016.03.21 21:26:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:26:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.167 255.255.0.0'
. 2016.03.21 21:26:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:26:48 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:26:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:26:48 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:26:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:26:48 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:26:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:26:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:26:48 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:26:48 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:26:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:26:48 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:26:48 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:26:48 - OpenVPN > /sbin/ifconfig utun1 10.4.53.167 10.4.53.167 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:26:48 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.167 255.255.0.0
. 2016.03.21 21:26:48 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.167: File exists
. 2016.03.21 21:26:48 - OpenVPN > /sbin/route add -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:26:48 - OpenVPN > add net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:26:48 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:26:48 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:26:48 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:26:48 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:26:48 - Starting Management Interface
. 2016.03.21 21:26:48 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:26:48 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:26:48 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:26:48 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:26:49 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:26:49 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:26:49 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:26:49 - Flushing DNS
I 2016.03.21 21:26:49 - Checking route
W 2016.03.21 21:27:39 - The request timed out
! 2016.03.21 21:27:39 - Disconnecting
. 2016.03.21 21:27:39 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:27:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:27:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:27:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:27:44 - OpenVPN > /sbin/route delete -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:27:44 - OpenVPN > delete net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:27:44 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:27:44 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:27:44 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:27:44 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:27:44 - Connection terminated.
I 2016.03.21 21:27:45 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2016.03.21 21:27:45 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:27:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2016.03.21 21:27:45 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:27:45 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:27:45 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:27:45 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:27:45 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:27:48 - Checking authorization ...
! 2016.03.21 21:27:48 - Connecting to Merga (Netherlands, Alblasserdam)
. 2016.03.21 21:27:48 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:27:48 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:27:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:27:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:27:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:27:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:27:49 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:27:49 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:27:49 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443
. 2016.03.21 21:27:49 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=a9bf5ef2 68784e59
. 2016.03.21 21:27:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:27:49 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:27:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:27:49 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:27:49 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:27:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:27:49 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:27:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:27:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:27:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:27:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:27:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:27:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:27:49 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443
. 2016.03.21 21:27:51 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:27:51 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.167 255.255.0.0'
. 2016.03.21 21:27:51 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:27:51 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:27:51 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:27:51 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:27:51 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:27:51 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:27:51 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:27:51 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:27:51 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:27:51 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:27:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:27:52 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:27:52 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:27:52 - OpenVPN > /sbin/ifconfig utun1 10.4.53.167 10.4.53.167 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:27:52 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.167 255.255.0.0
. 2016.03.21 21:27:52 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.167: File exists
. 2016.03.21 21:27:52 - OpenVPN > /sbin/route add -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:27:52 - OpenVPN > add net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:27:52 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:27:52 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:27:52 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:27:52 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:27:52 - Starting Management Interface
. 2016.03.21 21:27:52 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:27:52 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:27:52 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:27:52 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:27:52 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:27:52 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:27:52 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:27:53 - Flushing DNS
I 2016.03.21 21:27:53 - Checking route
W 2016.03.21 21:28:43 - The request timed out
! 2016.03.21 21:28:43 - Disconnecting
. 2016.03.21 21:28:43 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:28:43 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:28:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:28:43 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:28:48 - OpenVPN > /sbin/route delete -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:28:48 - OpenVPN > delete net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:28:48 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:28:48 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:28:48 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:28:48 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:28:48 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:28:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:28:48 - Connection terminated.
I 2016.03.21 21:28:48 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:28:48 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:28:48 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:28:48 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:28:48 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:28:48 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:28:48 - Cancel requested.
I 2016.03.21 21:28:48 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 21:28:49 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 21:28:49 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 21:28:49 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 21:28:49 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 21:28:49 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 21:28:49 - Session terminated.
I 2016.03.21 21:28:49 - Session starting.
I 2016.03.21 21:28:49 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.03.21 21:28:49 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.21 21:28:49 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.21 21:28:49 - IPv6 disabled on network adapter (TomTom)
I 2016.03.21 21:28:50 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.21 21:28:50 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.21 21:28:50 - Checking authorization ...
! 2016.03.21 21:28:50 - Connecting to Zibal (Netherlands, Alblasserdam)
. 2016.03.21 21:28:50 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:28:50 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:28:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:28:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:28:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:28:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:28:50 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:28:50 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:28:50 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.148:443
. 2016.03.21 21:28:50 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.148:443, sid=9af10cba f16dc905
. 2016.03.21 21:28:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:28:55 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:28:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:28:55 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:28:55 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:28:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:28:55 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:28:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:28:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:28:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:28:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:28:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:28:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:28:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.148:443
. 2016.03.21 21:28:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:29:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.148 255.255.0.0'
. 2016.03.21 21:29:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:29:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:29:00 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:29:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:29:00 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:29:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:29:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:29:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:29:00 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:29:00 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:29:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:29:00 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:29:00 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:29:00 - OpenVPN > /sbin/ifconfig utun1 10.4.52.148 10.4.52.148 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:29:00 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.52.148 255.255.0.0
. 2016.03.21 21:29:00 - OpenVPN > add net 10.4.0.0: gateway 10.4.52.148: File exists
. 2016.03.21 21:29:00 - OpenVPN > /sbin/route add -net 213.152.161.148 192.168.0.1 255.255.255.255
. 2016.03.21 21:29:00 - OpenVPN > add net 213.152.161.148: gateway 192.168.0.1
. 2016.03.21 21:29:00 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:29:00 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:29:00 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:29:00 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:29:00 - Starting Management Interface
. 2016.03.21 21:29:00 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:29:00 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:29:00 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:29:00 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:29:00 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:29:00 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:29:01 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:29:01 - Flushing DNS
I 2016.03.21 21:29:01 - Checking route
W 2016.03.21 21:29:51 - The request timed out
! 2016.03.21 21:29:51 - Disconnecting
. 2016.03.21 21:29:51 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:29:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:29:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:29:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:29:56 - OpenVPN > /sbin/route delete -net 213.152.161.148 192.168.0.1 255.255.255.255
. 2016.03.21 21:29:56 - OpenVPN > delete net 213.152.161.148: gateway 192.168.0.1
. 2016.03.21 21:29:56 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:29:56 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:29:56 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:29:56 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:29:56 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:29:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:29:56 - Connection terminated.
I 2016.03.21 21:29:56 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:29:56 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:29:56 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:29:56 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:29:56 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:29:56 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:29:59 - Checking authorization ...
! 2016.03.21 21:30:00 - Connecting to Merga (Netherlands, Alblasserdam)
. 2016.03.21 21:30:00 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:30:00 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:30:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:30:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:30:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:30:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:30:00 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:30:00 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:30:00 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443
. 2016.03.21 21:30:00 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=aa3ee5c6 5cb66d95
. 2016.03.21 21:30:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:30:00 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:30:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:30:00 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:30:00 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:30:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:30:00 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:30:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:30:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:30:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:30:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:30:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:30:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:30:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443
. 2016.03.21 21:30:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:30:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.167 255.255.0.0'
. 2016.03.21 21:30:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:30:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:30:03 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:30:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:30:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:30:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:30:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:30:03 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:30:03 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:30:03 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:30:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:30:03 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:30:03 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:30:03 - OpenVPN > /sbin/ifconfig utun1 10.4.53.167 10.4.53.167 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:30:03 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.167 255.255.0.0
. 2016.03.21 21:30:03 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.167: File exists
. 2016.03.21 21:30:03 - OpenVPN > /sbin/route add -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:30:03 - OpenVPN > add net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:30:03 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:30:03 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:30:03 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:30:03 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:30:03 - Starting Management Interface
. 2016.03.21 21:30:03 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:30:03 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:30:03 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:30:03 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:30:03 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:30:03 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:30:03 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:30:03 - Flushing DNS
I 2016.03.21 21:30:04 - Checking route
W 2016.03.21 21:30:54 - The request timed out
! 2016.03.21 21:30:54 - Disconnecting
. 2016.03.21 21:30:54 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:30:54 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:30:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:30:54 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:30:59 - OpenVPN > /sbin/route delete -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:30:59 - OpenVPN > delete net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:30:59 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:30:59 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:30:59 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:30:59 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:30:59 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:30:59 - Connection terminated.
I 2016.03.21 21:30:59 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2016.03.21 21:30:59 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2016.03.21 21:30:59 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:30:59 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:30:59 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:30:59 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:30:59 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:30:59 - Cancel requested.
I 2016.03.21 21:30:59 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 21:30:59 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 21:30:59 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 21:30:59 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 21:30:59 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 21:30:59 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 21:30:59 - Session terminated.
! 2016.03.21 21:31:00 - Deactivation of Network Lock
I 2016.03.21 21:35:37 - Session starting.
I 2016.03.21 21:35:38 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2016.03.21 21:35:38 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.03.21 21:35:38 - IPv6 disabled on network adapter (iPhone USB)
I 2016.03.21 21:35:38 - IPv6 disabled on network adapter (TomTom)
I 2016.03.21 21:35:38 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.03.21 21:35:38 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.03.21 21:35:38 - Checking authorization ...
! 2016.03.21 21:35:38 - Connecting to Merga (Netherlands, Alblasserdam)
. 2016.03.21 21:35:38 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2016.03.21 21:35:38 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.03.21 21:35:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2016.03.21 21:35:38 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.03.21 21:35:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:35:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:35:38 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.03.21 21:35:38 - OpenVPN > UDPv4 link local: [undef]
. 2016.03.21 21:35:38 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.29:443
. 2016.03.21 21:35:38 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.29:443, sid=4c35fa51 47e5b78a
. 2016.03.21 21:35:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.03.21 21:35:38 - OpenVPN > Validating certificate key usage
. 2016.03.21 21:35:38 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.03.21 21:35:39 - OpenVPN > VERIFY KU OK
. 2016.03.21 21:35:39 - OpenVPN > Validating certificate extended key usage
. 2016.03.21 21:35:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.03.21 21:35:39 - OpenVPN > VERIFY EKU OK
. 2016.03.21 21:35:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.03.21 21:35:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:35:39 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:35:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.03.21 21:35:39 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.03.21 21:35:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.03.21 21:35:39 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.29:443
. 2016.03.21 21:35:42 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.03.21 21:35:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.53.167 255.255.0.0'
. 2016.03.21 21:35:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.03.21 21:35:42 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.03.21 21:35:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.03.21 21:35:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.03.21 21:35:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.03.21 21:35:42 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.03.21 21:35:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.03.21 21:35:42 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.03.21 21:35:42 - OpenVPN > Opened utun device utun1
. 2016.03.21 21:35:42 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.03.21 21:35:42 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.03.21 21:35:42 - OpenVPN > route: writing to routing socket: File exists
. 2016.03.21 21:35:42 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.03.21 21:35:42 - OpenVPN > /sbin/ifconfig utun1 10.4.53.167 10.4.53.167 netmask 255.255.0.0 mtu 1500 up
. 2016.03.21 21:35:42 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.53.167 255.255.0.0
. 2016.03.21 21:35:42 - OpenVPN > add net 10.4.0.0: gateway 10.4.53.167: File exists
. 2016.03.21 21:35:42 - OpenVPN > /sbin/route add -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:35:42 - OpenVPN > add net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:35:42 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:35:42 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:35:42 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:35:42 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:35:42 - Starting Management Interface
. 2016.03.21 21:35:42 - OpenVPN > Initialization Sequence Completed
I 2016.03.21 21:35:42 - DNS of a network adapter forced (Bluetooth DUN)
I 2016.03.21 21:35:42 - DNS of a network adapter forced (Wi-Fi)
I 2016.03.21 21:35:42 - DNS of a network adapter forced (iPhone USB)
I 2016.03.21 21:35:42 - DNS of a network adapter forced (TomTom)
I 2016.03.21 21:35:42 - DNS of a network adapter forced (Bluetooth PAN)
I 2016.03.21 21:35:42 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2016.03.21 21:35:42 - Flushing DNS
I 2016.03.21 21:35:42 - Checking route
W 2016.03.21 21:36:32 - The request timed out
! 2016.03.21 21:36:32 - Disconnecting
. 2016.03.21 21:36:32 - Management - Send 'signal SIGTERM'
. 2016.03.21 21:36:32 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.03.21 21:36:32 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.03.21 21:36:32 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.03.21 21:36:37 - OpenVPN > /sbin/route delete -net 213.152.161.29 192.168.0.1 255.255.255.255
. 2016.03.21 21:36:37 - OpenVPN > delete net 213.152.161.29: gateway 192.168.0.1
. 2016.03.21 21:36:37 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:36:37 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:36:37 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.03.21 21:36:37 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2016.03.21 21:36:37 - OpenVPN > Closing TUN/TAP interface
. 2016.03.21 21:36:37 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.03.21 21:36:37 - Connection terminated.
I 2016.03.21 21:36:37 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2016.03.21 21:36:37 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2016.03.21 21:36:37 - DNS of a network adapter restored to original settings (iPhone USB)
I 2016.03.21 21:36:37 - DNS of a network adapter restored to original settings (TomTom)
I 2016.03.21 21:36:37 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2016.03.21 21:36:37 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2016.03.21 21:36:37 - Cancel requested.
I 2016.03.21 21:36:37 - IPv6 restored on network adapter (Bluetooth DUN)
I 2016.03.21 21:36:37 - IPv6 restored on network adapter (Wi-Fi)
I 2016.03.21 21:36:37 - IPv6 restored on network adapter (iPhone USB)
I 2016.03.21 21:36:37 - IPv6 restored on network adapter (TomTom)
I 2016.03.21 21:36:37 - IPv6 restored on network adapter (Bluetooth PAN)
I 2016.03.21 21:36:38 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2016.03.21 21:36:38 - Session terminated.
Mr. gmabber, please don't "steal" threads from other users.
If you've got an issue, present it in a separate thread in the future. No matter how similar the problem seems to be, we always talk of different systems. You're just making it more difficult to help both of you.
To both of you, please edit your posts and engulf your logs in spoiler tags (How-To in my signature) so that one can access the bottom faster if he/she doesn't want to read your logs.
You both have similar errors.
. 2016.03.07 19:51:55 - OpenVPN > UDPv4 link remote: [AF_INET]149.255.33.154:443
I 2016.03.07 19:52:02 - Checking route
W 2016.03.07 19:52:52 - The request timed out
. 2016.03.07 19:53:31 - SSL > 2016.03.07 19:53:31 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49775
I 2016.03.07 19:54:03 - Checking route
E 2016.03.07 19:54:03 - Routing checking failed.
Depending on the protocol used to connect, route checks after the connection either time out or fail.
  1. For the timeouts, try diabling the routing check. (@EchoandSilence)
  2. For the fails, check the two topics I linked in thread Routing checking failed. (@both)
