billf1 1 Posted ... I am having major speed issues when downloading torrents. It seems kind of hit or miss, sometimes they run fun, and I am getting acceptable speeds (1.5 Mbps +) and all of my other browsing is normal. But lately, the last few days, when I have torrents trying to download, I will get speeds only ~ 10kbps, when this happens, I also cannot access anything on the internet - pages just say they failed to load (so I cannot run a speed test wile this is going on. If I pause ALL torrents, the internet seems to be able to load some simple pages but very slowly, if I STOP the torrents, my internet speeds jump right back up to normal (~13.25 Mbps down 4 Mbps up). When I first start a torrent after having been stopped, I will normally get about 30 seconds of decent download speeds, and this issues re-arises. I have my uTorrent port static and specified as a forwarded port per the other conversations I have seen. Thanks in advance for any help you can offer. I have downloaded other torrents when not connected to AirVPN and I do not see this issue, only when connected to the VPN. Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... We miss your logs in spoiler tags, therefore, we miss all the software info of your setup (OS, client) and all the hints to solve your problem. See my signature for a How-To. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
billf1 1 Posted ... [spoiler]I 2016.03.05 07:06:51 - Session starting.. 2016.03.05 07:06:51 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 47 msI 2016.03.05 07:06:51 - IPv6 disabled.I 2016.03.05 07:06:51 - Checking authorization ...! 2016.03.05 07:06:52 - Connecting to Enif (Canada, Toronto, Ontario). 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: Reading configuration from file C:\Users\Bill\AppData\Local\AirVPN\c995fec69bae3be549182a903c425dd3088e8dcc82f0062890a2621f544600ae.tmp.ssl. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: UTF-8 byte order mark not detected. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[ui]: Initializing service [openvpn]. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: Configuration successful. 2016.03.05 07:06:52 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.03.05 07:06:52 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.03.05 07:06:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.03.05 07:06:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.03.05 07:06:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:15410. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[0]: Failover strategy: round-robin. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[0]: s_connect: connecting 104.254.90.244:443. 2016.03.05 07:06:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.05 07:06:52 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]. 2016.03.05 07:06:52 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:65267 [nonblock]. 2016.03.05 07:06:52 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:65267. 2016.03.05 07:06:52 - OpenVPN > TCPv4_CLIENT link local: [undef]. 2016.03.05 07:06:52 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:65267. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[0]: s_connect: connected 104.254.90.244:443. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.67:15411. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[0]: SNI: sending servername: 104.254.90.244. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[0]: CERT: Locally installed certificate matched. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[0]: Certificate accepted at depth=0: C=IT, ST=Italy, L=Perugia, O=AirVPN, OU=stunnel, CN=stunnel.airvpn.org, emailAddress=info@airvpn.org. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[0]: SSL connected: new session negotiated. 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption). 2016.03.05 07:06:52 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:65267, sid=c9e3b54a c91f3376. 2016.03.05 07:06:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.03.05 07:06:53 - OpenVPN > Validating certificate key usage. 2016.03.05 07:06:53 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.03.05 07:06:53 - OpenVPN > VERIFY KU OK. 2016.03.05 07:06:53 - OpenVPN > Validating certificate extended key usage. 2016.03.05 07:06:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.03.05 07:06:53 - OpenVPN > VERIFY EKU OK. 2016.03.05 07:06:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.03.05 07:06:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.05 07:06:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.05 07:06:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.05 07:06:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.05 07:06:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.03.05 07:06:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:65267. 2016.03.05 07:06:55 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.03.05 07:06:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.84 255.255.0.0'. 2016.03.05 07:06:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.03.05 07:06:55 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.03.05 07:06:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.03.05 07:06:55 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.03.05 07:06:55 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.03.05 07:06:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.03.05 07:06:55 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.03.05 07:06:55 - OpenVPN > open_tun, tt->ipv6=0. 2016.03.05 07:06:56 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{79732CB0-DABF-4791-8E02-C8A6376FE812}.tap. 2016.03.05 07:06:56 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.03.05 07:06:56 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.4.84/255.255.0.0 [sUCCEEDED]. 2016.03.05 07:06:56 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.4.84/255.255.0.0 on interface {79732CB0-DABF-4791-8E02-C8A6376FE812} [DHCP-serv: 10.50.255.254, lease-time: 31536000]. 2016.03.05 07:06:56 - OpenVPN > Successful ARP Flush on interface [15] {79732CB0-DABF-4791-8E02-C8A6376FE812}. 2016.03.05 07:07:01 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up. 2016.03.05 07:07:01 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.1. 2016.03.05 07:07:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.03.05 07:07:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.05 07:07:01 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 14. 2016.03.05 07:07:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.03.05 07:07:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.05 07:07:01 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1. 2016.03.05 07:07:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.03.05 07:07:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.05 07:07:01 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1. 2016.03.05 07:07:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.03.05 07:07:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.03.05 07:07:01 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.244 MASK 255.255.255.255 192.168.1.1. 2016.03.05 07:07:01 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=14]. 2016.03.05 07:07:01 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.03.05 07:07:01 - OpenVPN > Route addition fallback to route.exe. 2016.03.05 07:07:01 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.03.05 07:07:01 - Starting Management Interface. 2016.03.05 07:07:01 - OpenVPN > Initialization Sequence CompletedI 2016.03.05 07:07:01 - DNS of a network adapter forced (TP-LINK 300Mbps Wireless N Adapter)I 2016.03.05 07:07:01 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.03.05 07:07:01 - Flushing DNS. 2016.03.05 07:07:01 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 31 msI 2016.03.05 07:07:01 - Checking routeI 2016.03.05 07:07:01 - Checking DNS! 2016.03.05 07:07:02 - Connected.. 2016.03.05 07:07:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.03.05 07:07:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info[/spoiler] Quote Share this post Link to post
zhang888 1067 Posted ... if I STOP the torrents, my internet speeds jump right back up to normal Just a sign that you might want to switch to a sane BT client, such as qBittorrent. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Tech Jedi Alex 1499 Posted ... Your spoilers don't work. Try upgrading your browser. Helped one user in the past. . 2016.03.05 07:06:52 - SSL > 2016.03.05 07:06:52 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform In Eddie, go to Settings > Protocols and select Protocol UDP, port 443. SSL can impact performance of OpenVPN.If the issue still persists: . 2016.03.05 07:06:56 - OpenVPN > TAP-Windows Driver Version 9.21 There are many users reporting performance issues with TAP 9.21 on Windows, especially with torrent clients. You could try a downgrade, How-To is, as always, in my signature. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
billf1 1 Posted ... It is early yet, but the TAP downgrade seems to have worked. I tried the UDP 443 switch first, that did not do the trick (it did seem to take a little bit longer for my connection speed to crash, but it did still crash eventually). This seems to be doing the trick. I am now limited by the peers. Thank you for the help. I had not seen TAP mentioned on the other threads, and I would have not figured that out on my own for sure. 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... the TAP downgrade seems to have worked Aaaaand one more report. Welcome to the club. Enjoy! Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
