HeskeyKing 1 Posted ... Hi, I am running airvpn through windows 8.1 64bit. And use it for Tor browser. I have successfully set it up with tor correctly. And have used it many times this was. However recently, I will connect to a recommended server. The speeds will be fine, go up down and then after about 30 seconds of established time. Drop to 0 upload and download. This has become to be a problem and I'm not sure if I'm safe to browse. If anyone knows of any fixes I would really appreciate it: thanks a lot. Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... Please post your logs into spoiler tags. See my signature for a How-To. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
HeskeyKing 1 Posted ... I 2016.02.27 19:36:07 - Checking login ...! 2016.02.27 19:36:08 - Logged in.I 2016.02.27 19:36:10 - Session starting.I 2016.02.27 19:36:12 - Checking authorization ...! 2016.02.27 19:36:13 - Connecting to Hyadum (Netherlands, Alblasserdam). 2016.02.27 19:36:16 - Tor Control authentication method: Cookie, from C:\Users\Keir\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\control_auth_cookie. 2016.02.27 19:36:18 - Tor Control Guard IP detected: 95.141.83.146 (551BD8CB473FAED1AF2483F69DC671DD2BE76000). 2016.02.27 19:36:18 - Tor Control Guard IP detected: 62.210.124.124 (2EBD117806EE43C3CC885A8F1E4DC60F207E7D3E). 2016.02.27 19:36:18 - Tor Control Guard IP detected: 195.154.81.108 (4BFCFF2EAB2C5C49110E33A22A9FB5DA7A9CD0B6). 2016.02.27 19:36:19 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.02.27 19:36:19 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.02.27 19:36:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.02.27 19:36:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.02.27 19:36:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.02.27 19:36:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.02.27 19:36:19 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.02.27 19:36:19 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150 [nonblock]. 2016.02.27 19:36:19 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:9150. 2016.02.27 19:36:20 - OpenVPN > TCPv4_CLIENT link local: [undef]. 2016.02.27 19:36:20 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9150. 2016.02.27 19:36:20 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:9150, sid=025e8912 185aa9ae. 2016.02.27 19:36:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.02.27 19:36:20 - OpenVPN > Validating certificate key usage. 2016.02.27 19:36:20 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.02.27 19:36:20 - OpenVPN > VERIFY KU OK. 2016.02.27 19:36:20 - OpenVPN > Validating certificate extended key usage. 2016.02.27 19:36:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.02.27 19:36:20 - OpenVPN > VERIFY EKU OK. 2016.02.27 19:36:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.02.27 19:36:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.02.27 19:36:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.02.27 19:36:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.02.27 19:36:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.02.27 19:36:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.02.27 19:36:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9150. 2016.02.27 19:36:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.02.27 19:36:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.4.146 255.255.0.0'. 2016.02.27 19:36:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.02.27 19:36:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.02.27 19:36:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.02.27 19:36:26 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.02.27 19:36:26 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.02.27 19:36:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.02.27 19:36:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.02.27 19:36:26 - OpenVPN > open_tun, tt->ipv6=0. 2016.02.27 19:36:26 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{72E8A917-1AEE-4398-B515-3A1EB3EDDAEA}.tap. 2016.02.27 19:36:26 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.02.27 19:36:26 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.4.146/255.255.0.0 [sUCCEEDED]. 2016.02.27 19:36:26 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.4.146/255.255.0.0 on interface {72E8A917-1AEE-4398-B515-3A1EB3EDDAEA} [DHCP-serv: 10.50.255.254, lease-time: 31536000]. 2016.02.27 19:36:26 - OpenVPN > Successful ARP Flush on interface [9] {72E8A917-1AEE-4398-B515-3A1EB3EDDAEA}. 2016.02.27 19:36:31 - OpenVPN > TEST ROUTES: 4/4 succeeded len=3 ret=1 a=0 u/d=up. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 100.72.152.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 77.244.128.25 MASK 255.255.255.255 100.72.152.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 95.141.83.146 MASK 255.255.255.255 100.72.152.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 62.210.124.124 MASK 255.255.255.255 100.72.152.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 195.154.81.108 MASK 255.255.255.255 100.72.152.1. 2016.02.27 19:36:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.02.27 19:36:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.02.27 19:36:31 - Starting Management Interface. 2016.02.27 19:36:31 - OpenVPN > Initialization Sequence CompletedI 2016.02.27 19:36:32 - DNS of a network adapter forced (Ralink RT5390R 802.11bgn Wi-Fi Adapter)I 2016.02.27 19:36:32 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.02.27 19:36:33 - Flushing DNSI 2016.02.27 19:36:33 - Checking routeI 2016.02.27 19:36:39 - Checking DNS! 2016.02.27 19:36:41 - Connected.. 2016.02.27 19:36:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.02.27 19:36:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... . 2016.02.27 19:36:26 - OpenVPN > TAP-Windows Driver Version 9.21 Many people reported such odd speeds behavior with TAP 9.21. Try a downgrade, and, as always, a How-To can be found in my signature. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
HeskeyKing 1 Posted ... . 2016.02.27 19:36:26 - OpenVPN > TAP-Windows Driver Version 9.21 Many people reported such odd speeds behavior with TAP 9.21. Try a downgrade, and, as always, a How-To can be found in my signature. Hi, Im having trouble. I follow the steps in your signature but I cant seem to download TAP. 9.9.1 every time I do it, get the same 'an error has occurred when installing' message. Just wondering if you could help? Thanks Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... . 2016.02.27 19:36:26 - OpenVPN > TAP-Windows Driver Version 9.21 Many people reported such odd speeds behavior with TAP 9.21. Try a downgrade, and, as always, a How-To can be found in my signature. Hi, Im having trouble. I follow the steps in your signature but I cant seem to download TAP. 9.9.1 every time I do it, get the same 'an error has occurred when installing' message. Just wondering if you could help? Thanks Go to the device manager and delete TAP, with drivers. Then reboot and try again. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
HeskeyKing 1 Posted ... . 2016.02.27 19:36:26 - OpenVPN > TAP-Windows Driver Version 9.21 Many people reported such odd speeds behavior with TAP 9.21. Try a downgrade, and, as always, a How-To can be found in my signature. Hi, Im having trouble. I follow the steps in your signature but I cant seem to download TAP. 9.9.1 every time I do it, get the same 'an error has occurred when installing' message. Just wondering if you could help? Thanks Go to the device manager and delete TAP, with drivers. Then reboot and try again. I've tried this, I followed your steps correctly and didnt seem to let me download the older version of TAP. Are there any other alternatives? Also I can still run Tor and all the pages load as they would normally, even when the Download and Upload bounce down to 0kb/s for 5 seconds or so. Is it still safe to use? Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... didnt seem to let me download the older version of TAP. [...] Also I can still run Tor and all the pages load as they would normally, even when the Download and Upload bounce down to 0kb/s for 5 seconds or so Download? Here's a direct link, then. And download it without TOR. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
