Not connected, Your IP: 216.73.216.23
JacksonLee
PFSense advanced setup Question
I use pfsense to connect to VPN providers.
I got a Multi Gateway Setup (One Lan - 6 WAN). 5 Of these 5 WAN adapters are VPN connections to a different VPN Provider and I use rules on the Firewall to route traffic to these Connections.
They use the typical 10.x.0.1 Gateway, with a 255.255.255.0 Subnet Mask. This all works as expected.
Now I created another VPN Connection with AirVPN to this setup. I'm connected and this seems to be no Problem.
I also get a 10.x.0.1 Gateways but with a subnet mask of 255.255.0.0.
So If I want to route traffic trough the AirVPN client, it's a ) slow and b ) does not work as expected. ( I guess that A is because of B )
If I check my IP using one of the normal websites and refresh the website, I see that it rotates between all !!! VPN Connections. This is strange.
I checked my setup multiple times and don't see a reason why this happens. (I'm not using routing groups here)
Again, this only happens if I use the AirVPN Gateway for this traffic. If I use one of my other VPN Gateways, I permanently use this VPN connection.
ANY idea ?
I'd start by checking your routing table when you have multiple vpns connected.  If any of them have the same IP/gateway then it's only going to cause problems.  I always have at least 2 vpn connections running (all Air), but I connect each one to a different port on the Air server, which ensures that each connection gets a different IP (10.4.x, 10.6.x, 10.30.x).  If two interfaces have the same gateway then the appearance of round robin routing, even though not your intention, is a possibility, I would think.
Thanks @SirJohnEh,
routing Table looks fine to me:
IPv4
Destination     Gateway     Flags     Use     Mtu     Netif     Expire
default     192.168.1.1     UGS     57877627     1500     bfe0
10.4.0.0/16     10.4.14.227     UGS     0     1500     ovpnc7
10.4.0.1     link#14     UH     0     1500     ovpnc7
10.4.0.1/32     10.4.0.1     UGS     0     1500     ovpnc7
10.4.14.227     link#14     UHS     0     16384     lo0
10.8.0.0/16     10.8.0.2     UGS     0     1500     ovpnc1
10.8.0.1     link#9     UH     152613     1500     ovpnc1
10.8.0.1/32     10.8.0.1     UGS     0     1500     ovpnc1
10.8.0.2     link#9     UHS     0     16384     lo0
10.9.0.0/16     10.9.0.2     UGS     0     1500     ovpnc5
10.9.0.1     link#13     UH     152613     1500     ovpnc5
10.9.0.1/32     10.9.0.1     UGS     0     1500     ovpnc5
10.9.0.2     link#13     UHS     0     16384     lo0
10.10.0.0/16     10.10.0.2     UGS     0     1500     ovpnc2
10.10.0.1     link#10     UH     152377     1500     ovpnc2
10.10.0.1/32     10.10.0.1     UGS     0     1500     ovpnc2
10.10.0.2     link#10     UHS     0     16384     lo0
10.11.0.0/16     10.11.0.2     UGS     0     1500     ovpnc3
10.11.0.1     link#11     UH     152377     1500     ovpnc3
10.11.0.1/32     10.11.0.1     UGS     0     1500     ovpnc3
10.11.0.2     link#11     UHS     0     16384     lo0
10.44.10.0/24     10.44.10.2     UGS     0     1500     ovpns6
10.44.10.1     link#8     UHS     0     16384     lo0
10.44.10.2     link#8     UH     0     1500     ovpns6
10.114.0.0/16     10.114.0.16     UGS     0     1500     ovpnc4
10.114.0.1     link#12     UH     118062     1500     ovpnc4
10.114.0.1/32     10.114.0.1     UGS     0     1500     ovpnc4
10.114.0.16     link#12     UHS     0     16384     lo0
127.0.0.1     link#6     UH     687     16384     lo0
192.168.1.0/24     link#3     U     152654     1500     bfe0
192.168.1.50     link#3     UHS     0     16384     lo0
192.168.178.0/24     link#2     U     55745313     1500     re1
192.168.178.1     link#2     UHS     0     16384     lo0
I tried disabling all other VPN connections one by one, but it was still doing round robin till the last VPN connection was closed and only the AirVPN connection was open.
I don't understand why this is happening, any help is much appreciated.
Are you sure you don't have a routing group setup and policy based routing configured in your fw rules?  Because based on that routing table, nothing should be going thru the vpn by default based on the configured default gateway.  As far as I can see, anything that is going thru a tunnel must be doing so based on policy based routing rules in your fw and assuming that's the case, I'd just double check to make sure you didn't actually create a routing group.  If you've checked that and there is definitely no group with round robin configured then I'm not really sure what would be causing the behaviour you're seeing.
I don't understand this. I connect simultaneously to multiple AirVPN servers each of which gives a gateway address of 10.4.0.1. I use a different "IPv4 Tunnel Network" when I set up each OpenVPN client. I use firewall rules to specify which tunnel to use. This seems to work fine?
I've never tried to set it up that way, but I suppose that would work just as well.  For me, it just seemed easier/more logical to connect to a different port on each server, which then saved me having to configure extra settings like that manually.
can you briefly explain how you configured this ?
I checked and there is definitely no policy based routing or so. I'm puzzled
Set up an OpenVPN client as normal apart from in
/VPN/OpenVPN Client edit
specify a different value for each client in "IPv4 Tunnel Network" say 10.0.1.0/24, 10.0.2.0/24, 10.0.3.0/24... etc.
As for set up Nat/Routing using firewall rules follow pfSenseFan's guide.
Bearing in mind you can set the LAN firewall rule created from the NAT rule up for a LAN IP address as source and not just separate interfaces as pfSenseFan uses.
Hi, this did not help. It's still using all VPN Connection rather then just one.
No idea why this happens, well I guess its just as it is
