xyus
openvpn client in openvz
i got some problem when running openvpn client in openvz ( yes i use vps from vps provider )
here's the log
Thu Feb  4 02:32:03 2016 OpenVPN 2.3.4 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [iPv6] built on Dec  1 2014
Thu Feb  4 02:32:03 2016 library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
Thu Feb  4 02:32:03 2016 Control Channel Authentication: tls-auth using INLINE static key file
Thu Feb  4 02:32:03 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb  4 02:32:03 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb  4 02:32:03 2016 Socket Buffers: R=[133120->131072] S=[133120->131072]
Thu Feb  4 02:32:03 2016 UDPv4 link local: [undef]
Thu Feb  4 02:32:03 2016 UDPv4 link remote: [AF_INET]103.254.153.68:443
Thu Feb  4 02:32:03 2016 TLS: Initial packet from [AF_INET]103.254.153.68:443, sid=f873aa7a 9298d072
Thu Feb  4 02:32:05 2016 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Thu Feb  4 02:32:05 2016 Validating certificate key usage
Thu Feb  4 02:32:05 2016 ++ Certificate has key usage  00a0, expects 00a0
Thu Feb  4 02:32:05 2016 VERIFY KU OK
Thu Feb  4 02:32:05 2016 Validating certificate extended key usage
Thu Feb  4 02:32:05 2016 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Feb  4 02:32:05 2016 VERIFY EKU OK
Thu Feb  4 02:32:05 2016 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Thu Feb  4 02:32:09 2016 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Feb  4 02:32:09 2016 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb  4 02:32:09 2016 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Feb  4 02:32:09 2016 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Feb  4 02:32:09 2016 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Thu Feb  4 02:32:09 2016 [server] Peer Connection Initiated with [AF_INET]103.254.153.68:443
Thu Feb  4 02:32:11 2016 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Feb  4 02:32:11 2016 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.231 255.255.0.0'
Thu Feb  4 02:32:11 2016 OPTIONS IMPORT: timers and/or timeouts modified
Thu Feb  4 02:32:11 2016 OPTIONS IMPORT: LZO parms modified
Thu Feb  4 02:32:11 2016 OPTIONS IMPORT: --ifconfig/up options modified
Thu Feb  4 02:32:11 2016 OPTIONS IMPORT: route options modified
Thu Feb  4 02:32:11 2016 OPTIONS IMPORT: route-related options modified
Thu Feb  4 02:32:11 2016 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Feb  4 02:32:11 2016 ROUTE_GATEWAY ON_LINK IFACE=venet0 HWADDR=00:00:00:00:00:00
Thu Feb  4 02:32:11 2016 TUN/TAP device tun0 opened
Thu Feb  4 02:32:11 2016 TUN/TAP TX queue length set to 100
Thu Feb  4 02:32:11 2016 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Feb  4 02:32:11 2016 /sbin/ip link set dev tun0 up mtu 1500
Thu Feb  4 02:32:11 2016 /sbin/ip addr add dev tun0 10.4.18.231/16 broadcast 10.4.255.255
Thu Feb  4 02:32:17 2016 /sbin/ip route add 103.254.153.68/32 via 0.0.0.0
RTNETLINK answers: No such device
Thu Feb  4 02:32:17 2016 ERROR: Linux route add command failed: external program exited with error status: 2
Thu Feb  4 02:32:17 2016 /sbin/ip route add 0.0.0.0/1 via 10.4.0.1
Thu Feb  4 02:32:17 2016 /sbin/ip route add 128.0.0.0/1 via 10.4.0.1
Thu Feb  4 02:32:17 2016 Initialization Sequence Completed
Thu Feb  4 02:33:11 2016 [server] Inactivity timeout (--ping-restart), restarting
Thu Feb  4 02:33:11 2016 SIGUSR1[soft,ping-restart] received, process restarting
and result for if config and route -e
ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:3478743 errors:0 dropped:0 overruns:0 frame:0
TX packets:3478743 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:27925379432 (26.0 GiB) TX bytes:27925379432 (26.0 GiB)
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.4.18.231 P-t-P:10.4.18.231 Mask:255.255.0.0
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1593242 errors:0 dropped:1591364 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:0 (0.0 TX bytes:2388504630 (2.2 GiB)
venet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:127.0.0.2 P-t-P:127.0.0.2 Bcast:0.0.0.0 Mask:255.255.255.255
UP BROADCAST POINTOPOINT RUNNING NOARP MTU:1500 Metric:1
RX packets:566926339 errors:0 dropped:0 overruns:0 frame:0
TX packets:745983612 errors:0 dropped:535 overruns:0 carrier:0
RX bytes:418499861274 (389.7 GiB) TX bytes:875112015177 (815.0 GiB)
venet0:0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:185.69.xx.xxx P-t-P:185.69.xx.xxx Bcast:185.69.xx.xxx Mask:255.255.255.255
Destination Gateway Genmask Flags MSS Window irtt Iface
10.4.0.0        *                           255.255.0.0     U         0              0          0 tun0
default         10.4.0.1                128.0.0.0         UG      0              0          0 tun0
128.0.0.0       10.4.0.1             128.0.0.0          UG     0              0          0 tun0
default         *                             0.0.0.0              U        0              0          0 venet0
