Zaroad
No latencies on Eddie (openSUSE)
Hi, I've have a Suse tumbleweed installation on a computer but for any reason latencies and speed scores are not displayed on Eddie 2.10.3, it shows '.....' instead. I've already disabled the firewall and checked "Enable latency test" on Settings. Any ideas about what is happening here?
I can also ping servers on the command prompt without issues
i have the same problem on linux mint 17.3.
on startup, eddie counts down the latency tests for all available servers, but in the servers window latency values are shown for only a few or no servers at all.
sometimes some values are added some time later (might be hours), sometimes not.
this makes it hard to pick the best server.
Maybe you should try the experimental version, if unblocking AirVPN pings doesn't work :].
