ogi
Can't connect to Virginis (CH)
Eddie
! 2016.01.21 01:55:54 - Connecting to Virginis (Switzerland, Bern)
. 2016.01.21 01:55:54 - OpenVPN > OpenVPN 2.3.7 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [iPv6] built on Jul  8 2015
. 2016.01.21 01:55:54 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.01.21 01:55:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.01.21 01:55:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.01.21 01:55:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.21 01:55:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.21 01:55:54 - OpenVPN > Socket Buffers: R=[212992->425984] S=[212992->425984]
. 2016.01.21 01:55:54 - OpenVPN > UDPv4 link local: [undef]
. 2016.01.21 01:55:54 - OpenVPN > UDPv4 link remote: [AF_INET]46.19.137.114:443
. 2016.01.21 01:56:26 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.01.21 01:56:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.01.21 01:56:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.01.21 01:56:31 - Disconnecting
. 2016.01.21 01:56:31 - Connection terminated.
Router
Jan 21 02:27:37  openvpn[34914]: write UDPv4: Operation not permitted (code=1)
Jan 21 02:27:29  openvpn[34914]: write UDPv4: Operation not permitted (code=1)
Jan 21 02:27:25  openvpn[34914]: write UDPv4: Operation not permitted (code=1)
Jan 21 02:27:23  openvpn[34914]: write UDPv4: Operation not permitted (code=1)
Jan 21 02:27:23  openvpn[34914]: UDPv4 link remote: [AF_INET]46.19.137.114:80
Jan 21 02:27:23  openvpn[34914]: UDPv4 link local (bound): my ip
Jan 21 02:27:23  openvpn[34914]: Socket Buffers: R=[42080->65536] S=[57344->65536]
Jan 21 02:27:23  openvpn[34914]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
When I go to the airvpn.org status page it shows that Virginis is running and has connected users...
Can you establish new connections or is the server down?
Thanks for your help.
regards,
*** ok, seems to work again, tanks ***
