Eddie wont start on Lubuntu 64 Bit
Eddit just wont start on Lubuntu 64 Bit. Does not matter if I try to start the installed, portable, with/with out mono version.
Error Log:I 2016.01.15 01:19:58 - AirVPN client version: 2.10.3 / x64, System: Linux, Name: Ubuntu 15.10 \n \l / x64
. 2016.01.15 01:19:58 - Reading options from /home/lubu/.airvpn/AirVPN.xml
. 2016.01.15 01:19:58 - Profile options not found, using defaults.
Unhandled Exception:
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
  at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0
  at System.Drawing.Bitmap..ctor (Int32 width, Int32 height, PixelFormat format) [0x00000] in <filename unknown>:0
  at System.Drawing.Bitmap..ctor (System.Drawing.Image original, Int32 width, Int32 height) [0x00000] in <filename unknown>:0
  at System.Drawing.Bitmap..ctor (System.Drawing.Image original, Size newSize) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap:.ctor (System.Drawing.Image,System.Drawing.Size)
  at System.Windows.Forms.XplatUIX11.DefineCursor (System.Drawing.Bitmap bitmap, System.Drawing.Bitmap mask, Color cursor_pixel, Color mask_pixel, Int32 xHotSpot, Int32 yHotSpot) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.XplatUI.DefineCursor (System.Drawing.Bitmap bitmap, System.Drawing.Bitmap mask, Color cursor_pixel, Color mask_pixel, Int32 xHotSpot, Int32 yHotSpot) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Cursor.CreateCursor (System.IO.Stream stream) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Cursor..ctor (System.Type type, System.String resource) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Cursors.get_SizeNWSE () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.SizeGrip..ctor (System.Windows.Forms.Control CapturedControl) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.SizeGrip:.ctor (System.Windows.Forms.Control)
  at System.Windows.Forms.ScrollableControl.CreateScrollbars () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ScrollableControl..ctor () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ContainerControl..ctor () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Form..ctor () [0x00000] in <filename unknown>:0
  at AirVPN.Gui.Form..ctor () [0x00000] in <filename unknown>:0
  at AirVPN.Gui.Forms.Main..ctor () [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) AirVPN.Gui.Forms.Main:.ctor ()
  at AirVPN.UI.Linux.Program.Main () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
I already updated (apt-get update and upgrade) the dependencies. Would be awesome if you could help me.
Greets
