9dc
Waiting for TUN/TAP
when i want to connect to AirVPN im getting the error ". 2016.01.06 15:07:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up..."
i also get this error when i use vpn.sh so its a openVpn thing i think.
here is my complete log:
I 2016.01.06 15:06:29 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.01.06 15:06:30 - Reading options from C:\Users\Robin\AppData\Local\AirVPN\AirVPN.xml
. 2016.01.06 15:06:30 - Data Path: C:\Users\Robin\AppData\Local\AirVPN
. 2016.01.06 15:06:30 - App Path: C:\Program Files\AirVPN
. 2016.01.06 15:06:30 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.01.06 15:06:30 - Command line arguments (1): path="home"
. 2016.01.06 15:06:30 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.01.06 15:06:30 - Updating systems & servers data ...
I 2016.01.06 15:06:30 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.01.06 15:06:30 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.01.06 15:06:30 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.01.06 15:06:30 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.01.06 15:06:30 - Ready
. 2016.01.06 15:06:30 - Systems & servers data update completed
I 2016.01.06 15:06:31 - Session starting.
I 2016.01.06 15:06:31 - IPv6 disabled.
I 2016.01.06 15:06:36 - Checking authorization ...
! 2016.01.06 15:06:36 - Connecting to Anser (Netherlands, Alblasserdam)
. 2016.01.06 15:06:37 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015
. 2016.01.06 15:06:37 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.01.06 15:06:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.01.06 15:06:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.01.06 15:06:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.06 15:06:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.06 15:06:37 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.01.06 15:06:37 - OpenVPN > UDPv4 link local: [undef]
. 2016.01.06 15:06:37 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2016.01.06 15:06:37 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=f41e3466 1af6ebbf
. 2016.01.06 15:06:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.01.06 15:06:37 - OpenVPN > Validating certificate key usage
. 2016.01.06 15:06:37 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.01.06 15:06:37 - OpenVPN > VERIFY KU OK
. 2016.01.06 15:06:37 - OpenVPN > Validating certificate extended key usage
. 2016.01.06 15:06:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.01.06 15:06:37 - OpenVPN > VERIFY EKU OK
. 2016.01.06 15:06:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.01.06 15:06:40 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.01.06 15:06:40 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.06 15:06:40 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.01.06 15:06:40 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.06 15:06:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.01.06 15:06:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.169:443
. 2016.01.06 15:06:42 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.01.06 15:06:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.41.213 255.255.0.0'
. 2016.01.06 15:06:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.01.06 15:06:42 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.01.06 15:06:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.01.06 15:06:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.01.06 15:06:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.01.06 15:06:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.01.06 15:06:42 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.01.06 15:06:42 - OpenVPN > open_tun, tt->ipv6=0
. 2016.01.06 15:06:42 - OpenVPN > TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{832D8CA3-BE94-4406-BF89-8F70FF8D047E}.tap
. 2016.01.06 15:06:42 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.01.06 15:06:42 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.41.213/255.255.0.0 [SUCCEEDED]
. 2016.01.06 15:06:42 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.41.213/255.255.0.0 on interface {832D8CA3-BE94-4406-BF89-8F70FF8D047E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.01.06 15:06:42 - OpenVPN > Successful ARP Flush on interface [12] {832D8CA3-BE94-4406-BF89-8F70FF8D047E}
. 2016.01.06 15:06:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:48 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:52 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:53 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:54 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:56 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:57 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:58 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:06:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:06:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:06:59 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:00 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:02 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:03 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:04 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:05 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:06 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:07 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:09 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:10 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:11 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:12 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:13 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:14 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.01.06 15:07:15 - AirVPN Windows Interface Hack executed (LAN-Verbindung 2)
. 2016.01.06 15:07:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=6 ret=0 a=0 u/d=down
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.103.169 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.01.06 15:07:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 11
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.06 15:07:17 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.01.06 15:07:17 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.01.06 15:07:17 - OpenVPN > Route addition fallback to route.exe
. 2016.01.06 15:07:17 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 104.18.36.219 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 104.18.37.219 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 141.101.121.218 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 141.101.121.217 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 104.23.128.83 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > C:\Windows\system32\route.exe ADD 104.23.132.82 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:17 - OpenVPN > SYSTEM ROUTING TABLE
. 2016.01.06 15:07:17 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.2.1 p=0 i=11 t=4 pr=3 a=242959 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=11 t=4 pr=3 a=71998 h=0 m=21/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 10.8.0.16 255.255.255.252 10.8.0.18 p=0 i=12 t=3 pr=3 a=2027 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 10.8.0.18 255.255.255.255 10.8.0.18 p=0 i=12 t=3 pr=3 a=2027 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 10.8.0.19 255.255.255.255 10.8.0.18 p=0 i=12 t=3 pr=3 a=2027 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 91.121.154.201 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=71998 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 104.18.36.219 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 104.18.37.219 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 104.23.128.83 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 104.23.132.82 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 109.202.103.169 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=242970 h=0 m=306/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=242970 h=0 m=306/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=242970 h=0 m=306/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=11 t=4 pr=3 a=71998 h=0 m=21/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 141.101.121.217 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 141.101.121.218 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 192.168.2.0 255.255.255.0 192.168.2.69 p=0 i=11 t=3 pr=3 a=242959 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 192.168.2.1 255.255.255.255 192.168.2.1 p=0 i=11 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 192.168.2.69 255.255.255.255 192.168.2.69 p=0 i=11 t=3 pr=3 a=242959 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 192.168.2.255 255.255.255.255 192.168.2.69 p=0 i=11 t=3 pr=3 a=242959 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=242970 h=0 m=306/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.2.69 p=0 i=11 t=3 pr=3 a=242967 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 224.0.0.0 240.0.0.0 10.8.0.18 p=0 i=12 t=3 pr=3 a=242909 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=242970 h=0 m=306/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.2.69 p=0 i=11 t=3 pr=3 a=242967 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > 255.255.255.255 255.255.255.255 10.8.0.18 p=0 i=12 t=3 pr=3 a=242909 h=0 m=276/0/0/0/0
. 2016.01.06 15:07:17 - OpenVPN > SYSTEM ADAPTER LIST
. 2016.01.06 15:07:17 - OpenVPN > TAP-Windows Adapter V9
. 2016.01.06 15:07:17 - OpenVPN >   Index = 12
. 2016.01.06 15:07:17 - OpenVPN >   GUID = {832D8CA3-BE94-4406-BF89-8F70FF8D047E}
. 2016.01.06 15:07:17 - OpenVPN >   IP = 10.8.0.18/255.255.255.252
. 2016.01.06 15:07:17 - OpenVPN >   MAC = 00:ff:83:2d:8c:a3
. 2016.01.06 15:07:17 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2016.01.06 15:07:17 - OpenVPN >   DHCP SERV = 10.8.0.17/255.255.255.255
. 2016.01.06 15:07:17 - OpenVPN >   DHCP LEASE OBTAINED = Wed Jan 06 14:33:29 2016
. 2016.01.06 15:07:17 - OpenVPN >   DHCP LEASE EXPIRES  = Thu Jan 05 14:33:29 2017
. 2016.01.06 15:07:17 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2016.01.06 15:07:17 - OpenVPN > Realtek PCIe GBE Family Controller
. 2016.01.06 15:07:17 - OpenVPN >   Index = 11
. 2016.01.06 15:07:17 - OpenVPN >   GUID = {79D9ED6D-0C54-43A3-B33E-CBD9BC6D8796}
. 2016.01.06 15:07:17 - OpenVPN >   IP = 192.168.2.69/255.255.255.0
. 2016.01.06 15:07:17 - OpenVPN >   MAC = 50:46:5d:54:84:4d
. 2016.01.06 15:07:17 - OpenVPN >   GATEWAY = 192.168.2.1/255.255.255.255
. 2016.01.06 15:07:17 - OpenVPN >   DHCP SERV = 192.168.2.1/255.255.255.255
. 2016.01.06 15:07:17 - OpenVPN >   DHCP LEASE OBTAINED = Wed Jan 06 15:06:15 2016
. 2016.01.06 15:07:17 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Jan 20 15:06:15 2016
. 2016.01.06 15:07:17 - OpenVPN >   DNS SERV = 192.168.2.1/255.255.255.255
. 2016.01.06 15:07:17 - Starting Management Interface
. 2016.01.06 15:07:17 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2016.01.06 15:07:17 - Disconnecting
. 2016.01.06 15:07:17 - Management - Send 'signal SIGTERM'
. 2016.01.06 15:07:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.01.06 15:07:17 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.01.06 15:07:17 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.01.06 15:07:17 - Flushing DNS
. 2016.01.06 15:07:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.01.06 15:07:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.01.06 15:07:17 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 104.23.132.82 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 104.23.128.83 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 141.101.121.217 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 141.101.121.218 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 104.18.37.219 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 104.18.36.219 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.06 15:07:22 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2016.01.06 15:07:22 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.01.06 15:07:22 - OpenVPN > Route deletion fallback to route.exe
. 2016.01.06 15:07:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.01.06 15:07:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.06 15:07:22 - OpenVPN > Closing TUN/TAP interface
. 2016.01.06 15:07:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.01.06 15:07:22 - Connection terminated.
I 2016.01.06 15:07:22 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.01.06 15:07:25 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.01.06 15:07:25 - Cancel requested.
I 2016.01.06 15:07:25 - IPv6 restored.
! 2016.01.06 15:07:25 - Session terminated.
What are all those static routes to external IPs in your routing table?
what do you mean?
i only disabled the vpn for some websites that dont allow vpn connections
