frankwit
Ubuntu 14 as a router..what am I doing wrong?
Hi All,
I seem to be doing something wrong, but I cannot figure out what..
Mac Mini 2 eth ports Ubuntu 14.04 desktop eth0 as WAN eth1 as LAN,  NO wifi
Airvpn working to the outside  world,
DHCP an DNS working on the internal side 172.xxx.xxx.xxx range
However the internal connected Raspberry gets it DHCP address  and the PI DOES  resolve ip-adresses but won't ping...
100% packet loss....
even when disconnected form Airvpn eth1 wil not ping outside of it's own range.
Any help Much appreciated !
ifconfig on the mac-mini
eth0      Link encap:Ethernet  HWaddr xxxxxxxxxxxx
          inet addr:192.168.1.11  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::426c:8fff:fe03:d9a8/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:676093 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1124729 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:177998285 (177.9 MB)  TX bytes:1566505397 (1.5 GB)
          Interrupt:16
eth1      Link encap:Ethernet  HWaddr 00:xxxxxxxxxxx
          inet addr:172.17.207.121  Bcast:172.17.207.255  Mask:255.255.255.0
          inet6 addr: fe80::2e0:4cff:fe36:1399/64 Scope:Link
          RX packets:4882 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2971 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:650373 (650.3 KB)  TX bytes:1196377 (1.1 MB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:28680 errors:0 dropped:0 overruns:0 frame:0
          TX packets:28680 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:71999461 (71.9 MB)  TX bytes:71999461 (71.9 MB)
tun0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.4.10.46  P-t-P:10.4.10.46  Mask:255.255.0.0
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:26 errors:0 dropped:0 overruns:0 frame:0
          TX packets:33 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:8383 (8.3 KB)  TX bytes:3713 (3.7 KB)
root@frank-Macmini:/home/frank/p2pool# ping google.com
PING google.com (216.58.210.78) 56(84) bytes of data.
64 bytes from lhr14s24-in-f14.1e100.net (216.58.210.78): icmp_seq=1 ttl=57 time=18.5 ms
64 bytes from lhr14s24-in-f14.1e100.net (216.58.210.78): icmp_seq=2 ttl=57 time=18.4 ms
64 bytes from lhr14s24-in-f14.1e100.net (216.58.210.78): icmp_seq=3 ttl=57 time=17.4 ms
64 bytes from lhr14s24-in-f14.1e100.net (216.58.210.78): icmp_seq=4 ttl=57 time=18.0 ms
^C
--- google.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 17.426/18.142/18.598/0.468 ms
and for the PI:
pi@raspberrypi ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:xxxxxxx
          inet addr:172.17.207.1  Bcast:172.17.207.255  Mask:255.255.255.0
          RX packets:8303 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10394 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2457180 (2.3 MiB)  TX bytes:1520422 (1.4 MiB)
          RX packets:34 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2652 (2.5 KiB)  TX bytes:2652 (2.5 KiB)
pi@raspberrypi ~ $ ping google.com
PING google.com (216.58.208.78) 56(84) bytes of data.
^C
12 packets transmitted, 0 received, 100% packet loss, time 11005ms
IPtables:
# Generated by iptables-save v1.4.21 on Tue Jan  5 13:58:24 2016
*filter
:INPUT ACCEPT [106256:16543662]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [26509:243970113]
-A FORWARD -i eth1 -j ACCEPT
-A FORWARD -i eth1 -o eth1 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i eth0 -o eth1 -j ACCEPT
COMMIT
*nat
:PREROUTING ACCEPT [500:30748]
:INPUT ACCEPT [58:3710]
:OUTPUT ACCEPT [87:6770]
:POSTROUTING ACCEPT [87:6770]
-A POSTROUTING -o eth0 -j MASQUERADE
COMMIT
# Completed on Tue Jan  5 13:58:24 2016
Make sure forwarding is on @ sysctl.conf
nano -w /etc/sysctl.conf
net.ipv4.ip_forward = 1
Reload sysctl if needed. sysctl -p
It May also need:
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
And:
-A FORWARD -i tun0 -o eth1 -j ACCEPT
-A FORWARD -i eth1 -o tun0 -j ACCEPT
If its not running a dhcp setup on the lan / eth1 then manual setup of the dns for the machines connecting to the router could be needed.
