Gamix
Kat.cr in netherlands servers!
Hello all members here in Airvpn,
I have one issue today with Rarbg, the tracker block our ip, i try the https://unblocked.pe/, and work fine.
But when i go to kat.cr in normal link, take so long to go, and with that proxy, go fast. Ant problem with Kat.cr too?
Only a staff member from any of those trackers can tell you exactly what IP ranges are blocked.
So if you decide to use them, better to do it with a proxy service like the one you mentioned.
This way you will avoid blocks on both ends, if they occur.
Thanks Zhang888 for your answer. But its strange about Kat going fast with the proxy and slow with the server :/
Thanks again!
