Not connected, Your IP: 216.73.216.23
I'm not sure if my setup works correctly, hopefully someone can "translate" my log.
I've setup my router according to the instructions for dd-wrt routers.
On the website, the airvpn.org page states that I'm connected successfully.
In the log on my router it seems that the router is constantly disconnecting and reconnecting (nearly every second) - see log below.
Anyone can "translate" the log?
Thanks!
Cheers,
sm11
20151223 17:59:38 D MANAGEMENT: CMD 'state'
20151223 17:59:38 MANAGEMENT: Client disconnected
20151223 17:59:38 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20151223 17:59:38 D MANAGEMENT: CMD 'status 2'
20151223 17:59:38 D MANAGEMENT: CMD 'log 500'
20151223 17:59:39 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20151223 17:59:39 D MANAGEMENT: CMD 'status 2'
20151223 17:59:39 MANAGEMENT: Client disconnected
20151223 17:59:39 D MANAGEMENT: CMD 'log 500'
20151223 17:59:39 D MANAGEMENT: CMD 'state'
I seem to have the same problem, but I can't get anything out through my VPN.
I was having TLS issues reported with connection problems,now I'm not getting them but I have the same lag entries as the original poster.
There are also some options on the DD-WRT VPN setup screens that do not match the instructions, so I'm not sure if that is related, I just left them at defaults if they were something new....
Maybe the DD-WRT docs can be updated for the current release ?
I'm running v24-sp2 (02/04/15) std - build 26138
Thanks!
