chucknorris
Can't connect with VPN with Android
Dear AirVpn Team,
today I tried to use open vpn in my library with WiFi.
So I first connected to the WiFi entered the password then I had to enter the browser and enter my library ID so I could use the WiFi.
OK WiFi works. Now I wanted to use use vpn.
So I opened OpenVPN and tried to connect to the European server. But it didn't work. I tried several times but without luck.
I can use OpenVPN with my WiFi at home.
So OpenVPN must be configured right.
Can someone help me.
I Posted the OpenVPN outcome below.
I am using a Sony Xperia Z with root Android version 5.1.1
Thanks in advance.
2015-12-17 15:46:56 offizielle Version 0.6.46 läuft auf Sony Xperia Z (MSM8960), Android 5.1.1 (LMY48Y) API 22, ABI armeabi-v7a, (Sony/C6603/C6603:5.1.1/10.7.A.0.222/1314554057:user/release-keys)
2015-12-17 15:46:56 Generiere OpenVPN Konfiguration…
2015-12-17 15:46:58 started Socket Thread
2015-12-17 15:46:58 P:Initializing Google Breakpad!
2015-12-17 15:46:58 Current Parameter Settings:
2015-12-17 15:46:58 config = '/data/data/de.blinkt.openvpn/cache/android.conf'
2015-12-17 15:46:58 mode = 0
2015-12-17 15:46:58 show_ciphers = DISABLED
2015-12-17 15:46:58 show_digests = DISABLED
2015-12-17 15:46:58 show_engines = DISABLED
2015-12-17 15:46:58 genkey = DISABLED
2015-12-17 15:46:58 key_pass_file = '[UNDEF]'
2015-12-17 15:46:58 show_tls_ciphers = DISABLED
2015-12-17 15:46:58 connect_retry_max = 5
2015-12-17 15:46:58 Connection profiles [0]:
2015-12-17 15:46:58 proto = udp
2015-12-17 15:46:58 local = '[UNDEF]'
2015-12-17 15:46:58 local_port = '[UNDEF]'
2015-12-17 15:46:58 remote = 'europe.vpn.airdns.org'
2015-12-17 15:46:58 remote_port = '443'
2015-12-17 15:46:58 remote_float = DISABLED
2015-12-17 15:46:58 bind_defined = DISABLED
2015-12-17 15:46:58 bind_local = DISABLED
2015-12-17 15:46:58 bind_ipv6_only = DISABLED
2015-12-17 15:46:58 connect_retry_seconds = 5
2015-12-17 15:46:58 connect_timeout = 120
2015-12-17 15:46:58 socks_proxy_server = '[UNDEF]'
2015-12-17 15:46:58 socks_proxy_port = '[UNDEF]'
2015-12-17 15:46:58 socks_proxy_retry = DISABLED
2015-12-17 15:46:58 tun_mtu = 1500
2015-12-17 15:46:58 tun_mtu_defined = ENABLED
2015-12-17 15:46:58 link_mtu = 1500
2015-12-17 15:46:58 link_mtu_defined = DISABLED
2015-12-17 15:46:58 tun_mtu_extra = 0
2015-12-17 15:46:58 tun_mtu_extra_defined = DISABLED
2015-12-17 15:46:58 mtu_discover_type = -1
2015-12-17 15:46:58 fragment = 0
2015-12-17 15:46:58 mssfix = 1450
2015-12-17 15:46:58 explicit_exit_notification = 5
2015-12-17 15:46:58 Connection profiles END
2015-12-17 15:46:58 remote_random = DISABLED
2015-12-17 15:46:58 dev = 'tun'
2015-12-17 15:46:58 dev_type = '[UNDEF]'
2015-12-17 15:46:58 dev_node = '[UNDEF]'
2015-12-17 15:46:58 lladdr = '[UNDEF]'
2015-12-17 15:46:58 topology = 1
2015-12-17 15:46:58 tun_ipv6 = DISABLED
2015-12-17 15:46:58 ifconfig_local = '[UNDEF]'
2015-12-17 15:46:58 ifconfig_remote_netmask = '[UNDEF]'
2015-12-17 15:46:58 ifconfig_noexec = DISABLED
2015-12-17 15:46:58 ifconfig_nowarn = ENABLED
2015-12-17 15:46:58 ifconfig_ipv6_local = '[UNDEF]'
2015-12-17 15:46:58 ifconfig_ipv6_netbits = 0
2015-12-17 15:46:58 ifconfig_ipv6_remote = '[UNDEF]'
2015-12-17 15:46:58 shaper = 0
2015-12-17 15:46:58 mtu_test = 0
2015-12-17 15:46:58 mlock = DISABLED
2015-12-17 15:46:58 keepalive_ping = 0
2015-12-17 15:46:58 keepalive_timeout = 0
2015-12-17 15:46:58 inactivity_timeout = 0
2015-12-17 15:46:58 ping_send_timeout = 0
2015-12-17 15:46:58 ping_rec_timeout = 0
2015-12-17 15:46:58 ping_rec_timeout_action = 0
2015-12-17 15:46:58 ping_timer_remote = DISABLED
2015-12-17 15:46:58 remap_sigusr1 = 0
2015-12-17 15:46:58 persist_tun = ENABLED
2015-12-17 15:46:58 persist_local_ip = DISABLED
2015-12-17 15:46:58 persist_remote_ip = DISABLED
2015-12-17 15:46:58 persist_key = DISABLED
2015-12-17 15:46:58 passtos = DISABLED
2015-12-17 15:46:58 resolve_retry_seconds = 1000000000
2015-12-17 15:46:58 resolve_in_advance = ENABLED
2015-12-17 15:46:58 username = '[UNDEF]'
2015-12-17 15:46:58 groupname = '[UNDEF]'
2015-12-17 15:46:58 chroot_dir = '[UNDEF]'
2015-12-17 15:46:58 cd_dir = '[UNDEF]'
2015-12-17 15:46:58 writepid = '[UNDEF]'
2015-12-17 15:46:58 up_script = '[UNDEF]'
2015-12-17 15:46:58 down_script = '[UNDEF]'
2015-12-17 15:46:58 down_pre = DISABLED
2015-12-17 15:46:58 up_restart = DISABLED
2015-12-17 15:46:58 up_delay = DISABLED
2015-12-17 15:46:58 daemon = DISABLED
2015-12-17 15:46:58 inetd = 0
2015-12-17 15:46:58 log = DISABLED
2015-12-17 15:46:59 suppress_timestamps = DISABLED
2015-12-17 15:46:59 machine_readable_output = ENABLED
2015-12-17 15:46:59 nice = 0
2015-12-17 15:46:59 verbosity = 4
2015-12-17 15:46:59 mute = 0
2015-12-17 15:46:59 gremlin = 0
2015-12-17 15:46:59 status_file = '[UNDEF]'
2015-12-17 15:46:59 status_file_version = 1
2015-12-17 15:46:59 status_file_update_freq = 60
2015-12-17 15:46:59 occ = ENABLED
2015-12-17 15:46:59 rcvbuf = 0
2015-12-17 15:46:59 sndbuf = 0
2015-12-17 15:46:59 sockflags = 0
2015-12-17 15:46:59 fast_io = DISABLED
2015-12-17 15:46:59 comp.alg = 2
2015-12-17 15:46:59 comp.flags = 1
2015-12-17 15:46:59 route_script = '[UNDEF]'
2015-12-17 15:46:59 route_default_gateway = '[UNDEF]'
2015-12-17 15:46:59 route_default_metric = 0
2015-12-17 15:46:59 route_noexec = DISABLED
2015-12-17 15:46:59 route_delay = 0
2015-12-17 15:46:59 route_delay_window = 30
2015-12-17 15:46:59 route_delay_defined = DISABLED
2015-12-17 15:46:59 route_nopull = DISABLED
2015-12-17 15:46:59 route_gateway_via_dhcp = DISABLED
2015-12-17 15:46:59 allow_pull_fqdn = DISABLED
2015-12-17 15:46:59 management_addr = '/data/data/de.blinkt.openvpn/cache/mgmtsocket'
2015-12-17 15:46:59 management_port = 'unix'
2015-12-17 15:46:59 management_user_pass = '[UNDEF]'
2015-12-17 15:46:59 management_log_history_cache = 250
2015-12-17 15:46:59 management_echo_buffer_size = 100
2015-12-17 15:46:59 management_write_peer_info_file = '[UNDEF]'
2015-12-17 15:46:59 management_client_user = '[UNDEF]'
2015-12-17 15:46:59 management_client_group = '[UNDEF]'
2015-12-17 15:46:59 management_flags = 4390
2015-12-17 15:46:59 shared_secret_file = '[UNDEF]'
2015-12-17 15:46:59 key_direction = 2
2015-12-17 15:46:59 ciphername_defined = ENABLED
2015-12-17 15:46:59 ciphername = 'AES-256-CBC'
2015-12-17 15:46:59 authname_defined = ENABLED
2015-12-17 15:46:59 authname = 'SHA1'
2015-12-17 15:46:59 prng_hash = 'SHA1'
2015-12-17 15:46:59 prng_nonce_secret_len = 16
2015-12-17 15:46:59 keysize = 0
2015-12-17 15:46:59 engine = DISABLED
2015-12-17 15:46:59 replay = ENABLED
2015-12-17 15:46:59 mute_replay_warnings = DISABLED
2015-12-17 15:46:59 replay_window = 64
2015-12-17 15:46:59 replay_time = 15
2015-12-17 15:46:59 packet_id_file = '[UNDEF]'
2015-12-17 15:46:59 use_iv = ENABLED
2015-12-17 15:46:59 test_crypto = DISABLED
2015-12-17 15:46:59 tls_server = DISABLED
2015-12-17 15:46:59 tls_client = ENABLED
2015-12-17 15:46:59 key_method = 2
2015-12-17 15:46:59 ca_file = '[[INLINE]]'
2015-12-17 15:46:59 ca_path = '[UNDEF]'
2015-12-17 15:46:59 dh_file = '[UNDEF]'
2015-12-17 15:46:59 cert_file = '[[INLINE]]'
2015-12-17 15:46:59 extra_certs_file = '[UNDEF]'
2015-12-17 15:46:59 priv_key_file = '[[INLINE]]'
2015-12-17 15:46:59 pkcs12_file = '[UNDEF]'
2015-12-17 15:46:59 cipher_list = '[UNDEF]'
2015-12-17 15:46:59 tls_verify = '[UNDEF]'
2015-12-17 15:46:59 tls_export_cert = '[UNDEF]'
2015-12-17 15:46:59 verify_x509_type = 0
2015-12-17 15:46:59 verify_x509_name = '[UNDEF]'
2015-12-17 15:46:59 crl_file = '[UNDEF]'
2015-12-17 15:46:59 ns_cert_type = 0
2015-12-17 15:46:59 remote_cert_ku[i] = 160
2015-12-17 15:46:59 remote_cert_ku[i] = 136
2015-12-17 15:46:59 remote_cert_ku[i] = 0
2015-12-17 15:46:59 remote_cert_eku = 'TLS Web Server Authentication'
2015-12-17 15:46:59 ssl_flags = 0
2015-12-17 15:46:59 tls_timeout = 2
2015-12-17 15:46:59 renegotiate_bytes = 0
2015-12-17 15:46:59 renegotiate_packets = 0
2015-12-17 15:46:59 renegotiate_seconds = 3600
2015-12-17 15:46:59 handshake_window = 60
2015-12-17 15:46:59 transition_window = 3600
2015-12-17 15:46:59 single_session = DISABLED
2015-12-17 15:46:59 push_peer_info = DISABLED
2015-12-17 15:46:59 tls_exit = DISABLED
2015-12-17 15:46:59 tls_auth_file = '[[INLINE]]'
2015-12-17 15:46:59 client = ENABLED
2015-12-17 15:46:59 pull = ENABLED
2015-12-17 15:46:59 auth_user_pass_file = '[UNDEF]'
2015-12-17 15:46:59 OpenVPN 2.4-icsopenvpn [git:icsopenvpn_645-e6b5e62e37c02d5b] android-14-armeabi-v7a [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH] [IPv6] built on Dec 8 2015
2015-12-17 15:46:59 library versions: OpenSSL 1.0.2e 3 Dec 2015, LZO 2.09
2015-12-17 15:46:59 MANAGEMENT: Connected to management server at /data/data/de.blinkt.openvpn/cache/mgmtsocket
2015-12-17 15:46:59 MANAGEMENT: CMD 'hold release'
2015-12-17 15:46:59 MANAGEMENT: CMD 'bytecount 2'
2015-12-17 15:46:59 MANAGEMENT: CMD 'proxy NONE'
2015-12-17 15:46:59 MANAGEMENT: CMD 'state on'
2015-12-17 15:46:59 Netzwerkstatus: CONNECTED to WIFI "STBWLAN"
2015-12-17 15:47:00 Control Channel Authentication: tls-auth using INLINE static key file
2015-12-17 15:47:00 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:47:00 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:47:00 LZO compression initializing
2015-12-17 15:47:00 Control Channel MTU parms [ L:1558 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2015-12-17 15:47:00 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:395 ET:0 EL:3 ]
2015-12-17 15:47:00 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2015-12-17 15:47:00 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2015-12-17 15:47:00 TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.132:443
2015-12-17 15:47:00 Socket Buffers: R=[163840->163840] S=[163840->163840]
2015-12-17 15:47:00 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-12-17 15:47:00 UDP link local: (not bound)
2015-12-17 15:47:00 UDP link remote: [AF_INET]62.102.148.132:443
2015-12-17 15:47:00 MANAGEMENT: >STATE:1450363620,WAIT,,,,,,
2015-12-17 15:48:00 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2015-12-17 15:48:00 TLS Error: TLS handshake failed
2015-12-17 15:48:00 TCP/UDP: Closing socket
2015-12-17 15:48:00 SIGUSR1[soft,tls-error] received, process restarting
2015-12-17 15:48:00 MANAGEMENT: >STATE:1450363680,RECONNECTING,tls-error,,,,,
2015-12-17 15:48:00 MANAGEMENT: CMD 'hold release'
2015-12-17 15:48:00 MANAGEMENT: CMD 'bytecount 2'
2015-12-17 15:48:00 MANAGEMENT: CMD 'state on'
2015-12-17 15:48:00 MANAGEMENT: CMD 'proxy NONE'
2015-12-17 15:48:01 Control Channel Authentication: tls-auth using INLINE static key file
2015-12-17 15:48:01 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:48:01 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:48:01 LZO compression initializing
2015-12-17 15:48:01 Control Channel MTU parms [ L:1558 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2015-12-17 15:48:01 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:395 ET:0 EL:3 ]
2015-12-17 15:48:01 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2015-12-17 15:48:01 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2015-12-17 15:48:01 TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.132:443
2015-12-17 15:48:01 Socket Buffers: R=[163840->163840] S=[163840->163840]
2015-12-17 15:48:01 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-12-17 15:48:01 UDP link local: (not bound)
2015-12-17 15:48:01 UDP link remote: [AF_INET]62.102.148.132:443
2015-12-17 15:48:01 MANAGEMENT: >STATE:1450363681,WAIT,,,,,,
2015-12-17 15:49:01 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2015-12-17 15:49:01 TLS Error: TLS handshake failed
2015-12-17 15:49:01 TCP/UDP: Closing socket
2015-12-17 15:49:01 SIGUSR1[soft,tls-error] received, process restarting
2015-12-17 15:49:01 MANAGEMENT: >STATE:1450363741,RECONNECTING,tls-error,,,,,
2015-12-17 15:49:01 MANAGEMENT: CMD 'hold release'
2015-12-17 15:49:01 MANAGEMENT: CMD 'bytecount 2'
2015-12-17 15:49:01 MANAGEMENT: CMD 'state on'
2015-12-17 15:49:01 MANAGEMENT: CMD 'proxy NONE'
2015-12-17 15:49:02 Control Channel Authentication: tls-auth using INLINE static key file
2015-12-17 15:49:02 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:49:02 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:49:02 LZO compression initializing
2015-12-17 15:49:02 Control Channel MTU parms [ L:1558 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2015-12-17 15:49:02 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:395 ET:0 EL:3 ]
2015-12-17 15:49:02 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2015-12-17 15:49:02 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2015-12-17 15:49:02 TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.132:443
2015-12-17 15:49:02 Socket Buffers: R=[163840->163840] S=[163840->163840]
2015-12-17 15:49:02 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-12-17 15:49:02 UDP link local: (not bound)
2015-12-17 15:49:02 UDP link remote: [AF_INET]62.102.148.132:443
2015-12-17 15:49:02 MANAGEMENT: >STATE:1450363742,WAIT,,,,,,
2015-12-17 15:50:02 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2015-12-17 15:50:02 TLS Error: TLS handshake failed
2015-12-17 15:50:02 TCP/UDP: Closing socket
2015-12-17 15:50:02 SIGUSR1[soft,tls-error] received, process restarting
2015-12-17 15:50:02 MANAGEMENT: >STATE:1450363802,RECONNECTING,tls-error,,,,,
2015-12-17 15:50:02 MANAGEMENT: CMD 'hold release'
2015-12-17 15:50:02 MANAGEMENT: CMD 'bytecount 2'
2015-12-17 15:50:02 MANAGEMENT: CMD 'state on'
2015-12-17 15:50:02 MANAGEMENT: CMD 'proxy NONE'
2015-12-17 15:50:03 Control Channel Authentication: tls-auth using INLINE static key file
2015-12-17 15:50:03 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:50:03 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:50:03 LZO compression initializing
2015-12-17 15:50:03 Control Channel MTU parms [ L:1558 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2015-12-17 15:50:03 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:395 ET:0 EL:3 ]
2015-12-17 15:50:03 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2015-12-17 15:50:03 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2015-12-17 15:50:03 TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.132:443
2015-12-17 15:50:03 Socket Buffers: R=[163840->163840] S=[163840->163840]
2015-12-17 15:50:03 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-12-17 15:50:04 UDP link local: (not bound)
2015-12-17 15:50:04 UDP link remote: [AF_INET]62.102.148.132:443
2015-12-17 15:50:04 MANAGEMENT: >STATE:1450363803,WAIT,,,,,,
2015-12-17 15:51:03 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2015-12-17 15:51:03 TLS Error: TLS handshake failed
2015-12-17 15:51:03 TCP/UDP: Closing socket
2015-12-17 15:51:03 SIGUSR1[soft,tls-error] received, process restarting
2015-12-17 15:51:03 MANAGEMENT: >STATE:1450363863,RECONNECTING,tls-error,,,,,
2015-12-17 15:51:03 MANAGEMENT: CMD 'hold release'
2015-12-17 15:51:03 MANAGEMENT: CMD 'bytecount 2'
2015-12-17 15:51:03 MANAGEMENT: CMD 'state on'
2015-12-17 15:51:03 MANAGEMENT: CMD 'proxy NONE'
2015-12-17 15:51:04 Control Channel Authentication: tls-auth using INLINE static key file
2015-12-17 15:51:04 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:51:04 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
2015-12-17 15:51:04 LZO compression initializing
2015-12-17 15:51:04 Control Channel MTU parms [ L:1558 D:1184 EF:66 EB:0 ET:0 EL:3 ]
2015-12-17 15:51:04 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:395 ET:0 EL:3 ]
2015-12-17 15:51:05 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
2015-12-17 15:51:05 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
2015-12-17 15:51:05 TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.132:443
2015-12-17 15:51:05 Socket Buffers: R=[163840->163840] S=[163840->163840]
2015-12-17 15:51:05 MANAGEMENT: CMD 'needok 'PROTECTFD' ok'
2015-12-17 15:51:05 UDP link local: (not bound)
2015-12-17 15:51:05 UDP link remote: [AF_INET]62.102.148.132:443
2015-12-17 15:51:05 MANAGEMENT: >STATE:1450363864,WAIT,,,,,,
2015-12-17 15:52:04 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2015-12-17 15:52:04 TLS Error: TLS handshake failed
2015-12-17 15:52:04 TCP/UDP: Closing socket
2015-12-17 15:52:04 SIGUSR1[soft,tls-error] received, process restarting
2015-12-17 15:52:04 MANAGEMENT: >STATE:1450363924,RECONNECTING,tls-error,,,,,
2015-12-17 15:52:04 MANAGEMENT: CMD 'hold release'
2015-12-17 15:52:04 MANAGEMENT: CMD 'bytecount 2'
2015-12-17 15:52:04 MANAGEMENT: CMD 'state on'
2015-12-17 15:52:04 MANAGEMENT: CMD 'proxy NONE'
2015-12-17 15:52:05 MANAGEMENT: Client disconnected
2015-12-17 15:52:05 All connections have been connect-retry-max (5) times unsuccessful, exiting
2015-12-17 15:52:05 MGMT: Got unrecognized command>FATAL:All connections have been connect-retry-max (5) times unsuccessful, exiting
2015-12-17 15:52:05 Exiting due to fatal error
2015-12-17 15:52:05 Process exited with exit value 1
I only skimmed it, but looks like their wifi is blocking the port you are trying to connect through.
You can try all of them.
Is it possible that vpns are blocked in your library?
I don't know if vpn is blocked there.
From which port do I start?
And till what port can I choose?
Sorry for the questions but I am new to vpn.
Thanks in advance
In Airvpn client click on Preferences and then on Protocols. Here you can select which one and then i believe you should disconnect and reconnect again to test it.
But there is no AirVpn client on Android.
I am using OpenVPN
My apologies, i replied thinking about the client version, not android.
You can do it in your Client area in Config Generator, on the bottom of the page under Connection Modes, click the box Advanced mode, here you can try a different port but i do not know if that applies for an android too.
