JuanClaude
No connection without AirVpn on, even if i uninstall it
I've recently buy an account and it works great but i can't connect without the app. It's very disturbing if i want to connect to a restricted wi-fi or on a slow connection.
I've tried to uninstall it but it doesn't work.
i will try to uninstall and Ccleaner or search how to make it work more longer than i did but it still a problem to solve.
SFMBE (Sorry For My Bad English), i'm not a native speaker.
Thanks in advance
windows key+r -> ncpa.cpl -> right click Local area conection -> properties -> click Internet protocol version 4 -> select Obtain DNS server address automatically -> click ok
Thanks a lot !
I've made a "doubloon" of this post, i will erase it.
My problem is solved, it wasn't linked with Network lock.
Thank you very much. Spot on, sorted the issue out for me.
Also your IPV4 DNS settings may need resetting back to automatic or whatever they were before being set to AirVPN's internal DNS address (10.4.0.1)
How are you supposed to switch between normal and VPN connection without repeatedly editing this setting..? I intend to keep using the software, only not 24/7.
