manjake
Custom firewall rules with Network Lock enabled
I've been very impressed with the AirVPN client so far but if possible I'd like to block outgoing traffic from certain executable files. Network Lock is an excellent feature but I understand that it backs up and deletes all Windows firewall rules on start-up then enforces it's own strict rules to only allow traffic through the VPN connection. If I add a custom firewall rule after Network Lock is enabled it gets removed on exit, If I add the firewall rule before it's enabled it just gets removed when Network Lock turns on. Is it possible to change the firewall rules that the client enforces when Network Lock is enabled?
Edit: Please ignore, I just realised that I can just copy the settings it applies and disable Network Lock altogether which will allow me to add my own rules
