moffa
Possible to port forward with bash scripts
Hello, I am not currently using AirVPN but I had a few questions before I signed up.
Is it possible to get a dynamic port using a bash script?
With one VPN I am using, they use a https url that returns a port.  Another uses a hash function of your local IP address.
From reading the FAQs it appears you must re-confirm the port every 24 hours which is far too much work for me.
Is it possible to get a port dynamically using a script and renew it the same way?
Thanks,
You do not need to renew ports here.
Once you "have" a port, it is yours until you stop being a customer or you remove it from your account - and you are allowed 20 of these.
You can configure ports for your account here: https://airvpn.org/ports/
If you need any more help or you don't understand anything then please say.
