19990909jp 0 Posted ... Hi Guys Not sure why I am getting error 403 forbidden (win7, premium, firefox)? Not sure what I am doing wrong. 99 Quote Share this post Link to post
Staff 10488 Posted ... Hi GuysNot sure why I am getting error 403 forbidden (win7, premium, firefox)?Not sure what I am doing wrong.99Hello!Can you please tell us where and when you obtain this error? If possible, could you please describe all the steps you perform to cause the error?We're looking forward to hearing from you.Kind regards Quote Share this post Link to post
19990909jp 0 Posted ... hi there I get this in the Air login screen. The one with Free access option on left and member access option on right. as soon as I have entered my uid and pwd I get a popup saying "The remote server returned an error (403): Forbidden" Thanks Quote Share this post Link to post
Staff 10488 Posted ... hi thereI get this in the Air login screen. The one with Free access option on left and member access option on right. as soon as I have entered my uid and pwd I get a popup saying "The remote server returned an error (403): Forbidden"ThanksHello!We have checked that you account is authorized to access all the VPN servers (it is on premium status).Make sure that on the Air client login screen you select "Member Access".If the remote server still give you the error 403, please try a connection directly with OpenVPN. Please follow the instructions in the "Enter"->"Windows" page (direct link https://airvpn.org/windows).After that, try a connection with the OpenVPN GUI and please send us the connection logs (they are in C:\Program Files(x86)\OpenVPN\log).We're looking forward to hearing from you.Kind regards Quote Share this post Link to post
19990909jp 0 Posted ... Hi Guys Tried connecting without the client, and not sure whats happening really. OpenVPN says "connected to Air", however neither any of your web pages (the sign at the bottom says not connected) or my account says that I have been connected at all, and whoami returns my real address not air's There are no log files at all in OpenVPN despite disconnecting and reconnecting numerous times. However, when I right click and select 'show status' I can copy this info which may help? (dont like the numerous 'access is denied' messages Thanks Show Status window text ---------------------------------------------------------------------------------------------------------------------- Wed Feb 29 23:22:27 2012 OpenVPN 2.2.1 Win32-MSVC++ [sSL] [LZO2] built on Jul 1 2011 Wed Feb 29 23:22:27 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Wed Feb 29 23:22:27 2012 LZO compression initialized Wed Feb 29 23:22:27 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Wed Feb 29 23:22:27 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Wed Feb 29 23:22:27 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Wed Feb 29 23:22:27 2012 Local Options hash (VER=V4): '22188c5b' Wed Feb 29 23:22:27 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Wed Feb 29 23:22:27 2012 UDPv4 link local: [undef] Wed Feb 29 23:22:27 2012 UDPv4 link remote: 178.248.29.132:443 Wed Feb 29 23:22:27 2012 TLS: Initial packet from 178.248.29.132:443, sid=c291efca 94d4801f Wed Feb 29 23:22:28 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Wed Feb 29 23:22:28 2012 VERIFY OK: nsCertType=SERVER Wed Feb 29 23:22:28 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Wed Feb 29 23:22:29 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Feb 29 23:22:29 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Feb 29 23:22:29 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Feb 29 23:22:29 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Feb 29 23:22:29 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Wed Feb 29 23:22:29 2012 [server] Peer Connection Initiated with 178.248.29.132:443 Wed Feb 29 23:22:32 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Feb 29 23:22:32 2012 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.4.22 10.4.4.21' Wed Feb 29 23:22:32 2012 OPTIONS IMPORT: timers and/or timeouts modified Wed Feb 29 23:22:32 2012 OPTIONS IMPORT: LZO parms modified Wed Feb 29 23:22:32 2012 OPTIONS IMPORT: --ifconfig/up options modified Wed Feb 29 23:22:32 2012 OPTIONS IMPORT: route options modified Wed Feb 29 23:22:32 2012 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Wed Feb 29 23:22:32 2012 ROUTE default_gateway=192.168.1.1 Wed Feb 29 23:22:32 2012 TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{825B04EE-6883-48B0-A4DA-D81BB2AD32CF}.tap Wed Feb 29 23:22:32 2012 TAP-Win32 Driver Version 9.8 Wed Feb 29 23:22:32 2012 TAP-Win32 MTU=1500 Wed Feb 29 23:22:32 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.4.22/255.255.255.252 on interface {825B04EE-6883-48B0-A4DA-D81BB2AD32CF} [DHCP-serv: 10.4.4.21, lease-time: 31536000] Wed Feb 29 23:22:32 2012 NOTE: FlushIpNetTable failed on interface [16] {825B04EE-6883-48B0-A4DA-D81BB2AD32CF} (status=5) : Access is denied. Wed Feb 29 23:22:37 2012 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up Wed Feb 29 23:22:37 2012 C:\WINDOWS\system32\route.exe ADD 178.248.29.132 MASK 255.255.255.255 192.168.1.1 Wed Feb 29 23:22:37 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=10] Wed Feb 29 23:22:37 2012 Route addition via IPAPI failed [adaptive] Wed Feb 29 23:22:37 2012 Route addition fallback to route.exe The requested operation requires elevation. Wed Feb 29 23:22:37 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Wed Feb 29 23:22:37 2012 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.4.21 Wed Feb 29 23:22:37 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=16] Wed Feb 29 23:22:37 2012 Route addition via IPAPI failed [adaptive] Wed Feb 29 23:22:37 2012 Route addition fallback to route.exe The requested operation requires elevation. Wed Feb 29 23:22:37 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Wed Feb 29 23:22:37 2012 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.4.21 Wed Feb 29 23:22:37 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=16] Wed Feb 29 23:22:37 2012 Route addition via IPAPI failed [adaptive] Wed Feb 29 23:22:37 2012 Route addition fallback to route.exe The requested operation requires elevation. Wed Feb 29 23:22:37 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Wed Feb 29 23:22:37 2012 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.4.21 Wed Feb 29 23:22:37 2012 ROUTE: route addition failed using CreateIpForwardEntry: Access is denied. [status=5 if_index=16] Wed Feb 29 23:22:37 2012 Route addition via IPAPI failed [adaptive] Wed Feb 29 23:22:37 2012 Route addition fallback to route.exe The requested operation requires elevation. Wed Feb 29 23:22:37 2012 ERROR: Windows route add command failed [adaptive]: returned error code 1 Wed Feb 29 23:22:37 2012 Initialization Sequence Completed Quote Share this post Link to post
19990909jp 0 Posted ... Guys, sorted the openVPN issue. I had to go into control panel -> services and set it to start automatically, then after a reboot the service is working, whoamI is returning a 178.... address which isnt me! Cant get the client working though. I don't care so long as I am anonymous, but if you want me to perform any extra tests for you for debugging purposes, just let me know. Thanks Quote Share this post Link to post
Staff 10488 Posted ... Guys, sorted the openVPN issue.I had to go into control panel -> services and set it to start automatically, then after a reboot the service is working, whoamI is returning a 178.... address which isnt me! Cant get the client working though. I don't care so long as I am anonymous, but if you want me to perform any extra tests for you for debugging purposes, just let me know.ThanksHello!The first log suggested that OpenVPN had no privileges to modify the routing table. Since the table could not be modified, your traffic was routed into the encrypted tunnel.On Win7 and a standard installation, OpenVPN logs can be found in C:\Program Files(x86)\OpenVPN\logUsually the issue can be solved by launching OpenVPN (or the OpenVPN GUI) with administrator privileges (right-click and then select "Run as administrator").Anyway, you solved that issue. About the Air client, can you describe step by step what happens? Also, the logs can be accessed in the Air client by right-clicking on its dock icon and selecting "Logs". A window will pop-up. Click on "Copy to clibpboard" and then please paste and send to us, they may be helpful for troublshooting.We're looking forward to hearing from you.Kind regards Quote Share this post Link to post
19990909jp 0 Posted ... Hi Guys Here is the log from Air.. 01/03/2012 - 22:43 AirVPN client version: 1.6 01/03/2012 - 22:43 OpenVPN bundle version: OpenVPN 2.2.1 01/03/2012 - 22:43 OpenVPN current version: OpenVPN 2.2.1 01/03/2012 - 22:43 Ready. However, when I try to login using member access and my account info, I immediately get a popup window as described saying error 403. Its immediate, like 0.01 of a second every time. thanks Quote Share this post Link to post
19990909jp 0 Posted ... Guys, having more trouble. Air client has never worked, still get the '403 permission denied as soon as I click on the Login', and now neither is openvpn Here is the log file... Sun Apr 15 21:37:56 2012 OpenVPN 2.2.1 Win32-MSVC++ [sSL] [LZO2] built on Jul 1 2011 Sun Apr 15 21:37:56 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Sun Apr 15 21:37:57 2012 LZO compression initialized Sun Apr 15 21:37:57 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Sun Apr 15 21:37:57 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Sun Apr 15 21:37:57 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Sun Apr 15 21:37:57 2012 Local Options hash (VER=V4): '22188c5b' Sun Apr 15 21:37:57 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Sun Apr 15 21:37:57 2012 UDPv4 link local: [undef] Sun Apr 15 21:37:57 2012 UDPv4 link remote: 178.248.29.132:443 Sun Apr 15 21:37:57 2012 TLS: Initial packet from 178.248.29.132:443, sid=c967dfdd 4bcee48c Sun Apr 15 21:38:04 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Sun Apr 15 21:38:04 2012 VERIFY OK: nsCertType=SERVER Sun Apr 15 21:38:04 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Sun Apr 15 21:38:12 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Sun Apr 15 21:38:12 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Sun Apr 15 21:38:12 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Sun Apr 15 21:38:12 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Sun Apr 15 21:38:12 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Sun Apr 15 21:38:12 2012 [server] Peer Connection Initiated with 178.248.29.132:443 Sun Apr 15 21:38:14 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sun Apr 15 21:38:14 2012 AUTH: Received AUTH_FAILED control message Sun Apr 15 21:38:14 2012 SIGTERM received, sending exit notification to peer Sun Apr 15 21:38:19 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Sun Apr 15 21:38:19 2012 TCP/UDP: Closing socket Sun Apr 15 21:38:19 2012 SIGTERM[soft,exit-with-notification] received, process exiting Please can you help? Ta Quote Share this post Link to post
Staff 10488 Posted ... Guys, having more trouble. Air client has never worked, still get the '403 permission denied as soon as I click on the Login', and now neither is openvpnHello!We can see that you have solved the problem, anyway we recommend that you upgrade to OpenVPN 2.2.2 and Air client 1.7 at your earliest convenience.Kind regards Quote Share this post Link to post
19990909jp 0 Posted ... Hi guys Have upgraded but again struggling to get a secure connection because of 'auth_failed'?? heres the transcript from the log file. Please Help. Wed Apr 18 20:39:31 2012 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 Wed Apr 18 20:39:31 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Wed Apr 18 20:39:32 2012 LZO compression initialized Wed Apr 18 20:39:32 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Wed Apr 18 20:39:32 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Wed Apr 18 20:39:32 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Wed Apr 18 20:39:32 2012 Local Options hash (VER=V4): '22188c5b' Wed Apr 18 20:39:32 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Wed Apr 18 20:39:32 2012 UDPv4 link local: [undef] Wed Apr 18 20:39:32 2012 UDPv4 link remote: 178.248.29.132:443 Wed Apr 18 20:39:32 2012 TLS: Initial packet from 178.248.29.132:443, sid=d8ccaf44 72568bf6 Wed Apr 18 20:39:34 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Wed Apr 18 20:39:34 2012 VERIFY OK: nsCertType=SERVER Wed Apr 18 20:39:34 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Wed Apr 18 20:39:38 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Apr 18 20:39:38 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Apr 18 20:39:38 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Apr 18 20:39:38 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Apr 18 20:39:38 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Wed Apr 18 20:39:38 2012 [server] Peer Connection Initiated with 178.248.29.132:443 Wed Apr 18 20:39:41 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Apr 18 20:39:41 2012 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.4.22 10.4.4.21' Wed Apr 18 20:39:41 2012 OPTIONS IMPORT: timers and/or timeouts modified Wed Apr 18 20:39:41 2012 OPTIONS IMPORT: LZO parms modified Wed Apr 18 20:39:41 2012 OPTIONS IMPORT: --ifconfig/up options modified Wed Apr 18 20:39:41 2012 OPTIONS IMPORT: route options modified Wed Apr 18 20:39:41 2012 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Wed Apr 18 20:39:41 2012 ROUTE default_gateway=192.168.1.1 Wed Apr 18 20:39:43 2012 TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{825B04EE-6883-48B0-A4DA-D81BB2AD32CF}.tap Wed Apr 18 20:39:43 2012 TAP-Win32 Driver Version 9.9 Wed Apr 18 20:39:43 2012 TAP-Win32 MTU=1500 Wed Apr 18 20:39:43 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.4.22/255.255.255.252 on interface {825B04EE-6883-48B0-A4DA-D81BB2AD32CF} [DHCP-serv: 10.4.4.21, lease-time: 31536000] Wed Apr 18 20:39:43 2012 Successful ARP Flush on interface [16] {825B04EE-6883-48B0-A4DA-D81BB2AD32CF} Wed Apr 18 20:39:48 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:48 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:53 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:53 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:54 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:54 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:55 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:55 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:56 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:56 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:57 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:57 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:58 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:58 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:39:59 2012 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down Wed Apr 18 20:39:59 2012 Route: Waiting for TUN/TAP interface to come up... Wed Apr 18 20:40:00 2012 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up Wed Apr 18 20:40:00 2012 C:\WINDOWS\system32\route.exe ADD 178.248.29.132 MASK 255.255.255.255 192.168.1.1 Wed Apr 18 20:40:00 2012 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 Wed Apr 18 20:40:00 2012 Route addition via IPAPI succeeded [adaptive] Wed Apr 18 20:40:00 2012 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.4.21 Wed Apr 18 20:40:00 2012 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 Wed Apr 18 20:40:00 2012 Route addition via IPAPI succeeded [adaptive] Wed Apr 18 20:40:00 2012 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.4.21 Wed Apr 18 20:40:00 2012 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 Wed Apr 18 20:40:00 2012 Route addition via IPAPI succeeded [adaptive] Wed Apr 18 20:40:00 2012 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.4.21 Wed Apr 18 20:40:00 2012 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 Wed Apr 18 20:40:00 2012 Route addition via IPAPI succeeded [adaptive] Wed Apr 18 20:40:00 2012 Initialization Sequence Completed Wed Apr 18 20:41:17 2012 Replay-window backtrack occurred [1] Wed Apr 18 20:46:43 2012 [server] Inactivity timeout (--ping-restart), restarting Wed Apr 18 20:46:43 2012 TCP/UDP: Closing socket Wed Apr 18 20:46:43 2012 C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.4.21 Wed Apr 18 20:46:44 2012 Route deletion via IPAPI succeeded [adaptive] Wed Apr 18 20:46:44 2012 C:\WINDOWS\system32\route.exe DELETE 178.248.29.132 MASK 255.255.255.255 192.168.1.1 Wed Apr 18 20:46:44 2012 Route deletion via IPAPI succeeded [adaptive] Wed Apr 18 20:46:44 2012 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.4.21 Wed Apr 18 20:46:44 2012 Route deletion via IPAPI succeeded [adaptive] Wed Apr 18 20:46:44 2012 C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.4.21 Wed Apr 18 20:46:44 2012 Route deletion via IPAPI succeeded [adaptive] Wed Apr 18 20:46:44 2012 Closing TUN/TAP interface Wed Apr 18 20:46:44 2012 SIGUSR1[soft,ping-restart] received, process restarting Wed Apr 18 20:46:44 2012 Restart pause, 2 second(s) Wed Apr 18 20:46:46 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Wed Apr 18 20:46:47 2012 LZO compression initialized Wed Apr 18 20:46:47 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Wed Apr 18 20:46:47 2012 Socket Buffers: R=[8192->8192] S=[8192->8192] Wed Apr 18 20:46:47 2012 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Wed Apr 18 20:46:47 2012 Local Options hash (VER=V4): '22188c5b' Wed Apr 18 20:46:47 2012 Expected Remote Options hash (VER=V4): 'a8f55717' Wed Apr 18 20:46:47 2012 UDPv4 link local: [undef] Wed Apr 18 20:46:47 2012 UDPv4 link remote: 178.248.29.132:443 Wed Apr 18 20:46:47 2012 TLS: Initial packet from 178.248.29.132:443, sid=c9dee032 9379a62a Wed Apr 18 20:46:48 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org Wed Apr 18 20:46:48 2012 VERIFY OK: nsCertType=SERVER Wed Apr 18 20:46:48 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org Wed Apr 18 20:46:53 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Apr 18 20:46:53 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Apr 18 20:46:53 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key Wed Apr 18 20:46:53 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Wed Apr 18 20:46:53 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA Wed Apr 18 20:46:53 2012 [server] Peer Connection Initiated with 178.248.29.132:443 Wed Apr 18 20:46:56 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Apr 18 20:46:56 2012 AUTH: Received AUTH_FAILED control message Wed Apr 18 20:46:56 2012 SIGTERM received, sending exit notification to peer Wed Apr 18 20:47:01 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) Wed Apr 18 20:47:01 2012 TCP/UDP: Closing socket Wed Apr 18 20:47:01 2012 SIGTERM[soft,exit-with-notification] received, process exiting Quote Share this post Link to post
Staff 10488 Posted ... Hi guysHave upgraded but again struggling to get a secure connection because of 'auth_failed'?? heres the transcript from the log file.Please Help.Hello!It seems there are two problems. First, the TAP-Win32 adapter does not come up properly. This may due to improper installation, deactivation of the adapter or OpenVPN running without sufficient privileges. See here for details and how to fix:http://support.real-time.com/open-source/openvpn/index.htmlSecond, there might be high latency during the handshake, which causes the Replay Window Backtrack.http://openvpn.net/archive/openvpn-users/2004-09/msg00068.htmlThe AUTH_FAILED may be caused by this high latency. Try also to use a TCP port instead of UDP and to switch servers.Kind regards Quote Share this post Link to post
19990909jp 0 Posted ... ok, there was no TAP-Win 32 virtual port?!? Tried to install version 2.0 as per the link failed, sad incompatible, will retry version 2.22 ... Quote Share this post Link to post
Staff 10488 Posted ... ok, there was no TAP-Win 32 virtual port?!?Tried to install version 2.0 as per the link failed, sad incompatible, will retry version 2.21 ...Hello!Please check TAP-Win32 adapter, not virtual port. See also here, section "Troubleshooting":http://support.real-time.com/open-source/openvpn/index.htmlOpenVPN recommended version for Windows is 2.2.2. Version 2.0 for Windows is very old and had some rare but tedious bugs also related to the TUN/TAP adapter. A bug related to the adapter (in Windows systems only) was re-introduced in the 2.2.1 version, fixed with 2.2.2.http://openvpn.net/index.php/download/community-downloads.htmlKind regards Quote Share this post Link to post
19990909jp 0 Posted ... ok, connected again, but the AirVPN client still refuses to play!!! It ALWAYS comes up with Error 403 Its only by uninstalling, rebooting, reinstalling OpenVPN 2.2.2 as administrator, and then editing the services that I can get a connection. Thanks Quote Share this post Link to post
Staff 10488 Posted ... ok, connected again, but the AirVPN client still refuses to play!!!It ALWAYS comes up with Error 403 Its only by uninstalling, rebooting, reinstalling OpenVPN 2.2.2 as administrator, and then editing the services that I can get a connection.ThanksHello!Therefore it looks like something which is probably running with administrator privileges modifies your configuration. You should check Windows setup and applications like antivirus, firewall, "security" monitors, malware etc.Kind regards Quote Share this post Link to post
