HanoiLeRock12
Can't reconnect with out restarting DHCP-Client
I can't connect to a different server after I have closed an AirVPN connection. Error is ​"Waiting for TUN/TAP interface to come up...". If I restart the DHCP-Client service I am able to connect once again.​
I'm on Win-8 64 bit using the AirVPN Client (2.10.3) to connect. Windows Firewall is disabled. Comodo Firewall is set to "Allow UDP Out From MAC Any to MAC Any Where Source Port is Any And Destination Is 443". No difference if I completely disable Comodo completely.
​I have tried a Winsock sockets and TCP/IP stack reset as described here but it didn't help.
Any I ideas what I could try to fix this? I'd love to use AirVPN but this is quite annoying.
I 2015.10.30 21:34:02 - Checking authorization ...
! 2015.10.30 21:34:03 - Connecting to Alcyone (Netherlands, Alblasserdam)
. 2015.10.30 21:34:03 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.10.30 21:34:03 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.10.30 21:34:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.10.30 21:34:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.10.30 21:34:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:03 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.10.30 21:34:03 - OpenVPN > UDPv4 link local: [undef]
. 2015.10.30 21:34:03 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443
. 2015.10.30 21:34:03 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=6b710a1f f2112f46
. 2015.10.30 21:34:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.10.30 21:34:03 - OpenVPN > Validating certificate key usage
. 2015.10.30 21:34:03 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.10.30 21:34:03 - OpenVPN > VERIFY KU OK
. 2015.10.30 21:34:03 - OpenVPN > Validating certificate extended key usage
. 2015.10.30 21:34:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.10.30 21:34:03 - OpenVPN > VERIFY EKU OK
. 2015.10.30 21:34:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.10.30 21:34:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.10.30 21:34:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.10.30 21:34:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:04 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.10.30 21:34:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443
. 2015.10.30 21:34:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.10.30 21:34:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.29.79 255.255.0.0'
. 2015.10.30 21:34:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.10.30 21:34:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.10.30 21:34:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.10.30 21:34:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.10.30 21:34:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.10.30 21:34:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.10.30 21:34:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.10.30 21:34:06 - OpenVPN > open_tun, tt->ipv6=0
. 2015.10.30 21:34:06 - OpenVPN > TAP-WIN32 device [LAN-Verbindung] opened: \\.\Global\{3ADDE9CE-1F59-478C-A941-D7E5D57B1360}.tap
. 2015.10.30 21:34:06 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.10.30 21:34:06 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.29.79/255.255.0.0 [sUCCEEDED]
. 2015.10.30 21:34:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.29.79/255.255.0.0 on interface {3ADDE9CE-1F59-478C-A941-D7E5D57B1360} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.10.30 21:34:06 - OpenVPN > Successful ARP Flush on interface [7] {3ADDE9CE-1F59-478C-A941-D7E5D57B1360}
. 2015.10.30 21:34:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:11 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:16 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:18 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:19 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:20 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:21 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:22 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:24 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:25 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:26 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:27 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:28 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:29 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:30 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:31 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:32 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:34 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:35 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:36 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:37 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:38 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:39 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:34:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:41 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.178.1
. 2015.10.30 21:34:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.10.30 21:34:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.10.30 21:34:41 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 8
. 2015.10.30 21:34:41 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:34:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.10.30 21:34:41 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:34:41 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.10.30 21:34:41 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.178.1 p=0 i=8 t=4 pr=3 a=103 h=0 m=10/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=7 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.3.165 p=0 i=7 t=3 pr=2 a=86 h=0 m=276/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 10.4.3.165 255.255.255.255 10.4.3.165 p=0 i=7 t=3 pr=2 a=86 h=0 m=276/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.3.165 p=0 i=7 t=3 pr=2 a=86 h=0 m=276/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4133 h=0 m=306/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4133 h=0 m=306/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4133 h=0 m=306/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=7 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 192.168.178.0 255.255.255.0 192.168.178.66 p=0 i=8 t=3 pr=2 a=103 h=0 m=266/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 192.168.178.1 255.255.255.255 192.168.178.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 192.168.178.66 255.255.255.255 192.168.178.66 p=0 i=8 t=3 pr=2 a=103 h=0 m=266/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 192.168.178.255 255.255.255.255 192.168.178.66 p=0 i=8 t=3 pr=2 a=103 h=0 m=266/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 213.152.161.116 255.255.255.255 192.168.178.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4133 h=0 m=306/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.3.165 p=0 i=7 t=3 pr=2 a=4109 h=0 m=276/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.178.66 p=0 i=8 t=3 pr=2 a=4108 h=0 m=266/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4133 h=0 m=306/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.3.165 p=0 i=7 t=3 pr=2 a=4109 h=0 m=276/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.178.66 p=0 i=8 t=3 pr=2 a=4108 h=0 m=266/0/0/0/0
. 2015.10.30 21:34:41 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.10.30 21:34:41 - OpenVPN > Realtek PCIe GBE Family Controller
. 2015.10.30 21:34:41 - OpenVPN >   Index = 8
. 2015.10.30 21:34:41 - OpenVPN >   GUID = {B72198D8-0FD0-4762-A121-2660BA8F31D2}
. 2015.10.30 21:34:41 - OpenVPN >   IP = 192.168.178.66/255.255.255.0
. 2015.10.30 21:34:41 - OpenVPN >   MAC = 44:8a:5b:a0:7c:5c
. 2015.10.30 21:34:41 - OpenVPN >   GATEWAY = 192.168.178.1/255.255.255.255
. 2015.10.30 21:34:41 - OpenVPN >   DHCP SERV = 192.168.178.1/255.255.255.255
. 2015.10.30 21:34:41 - OpenVPN >   DHCP LEASE OBTAINED = Fri Oct 30 21:33:59 2015
. 2015.10.30 21:34:41 - OpenVPN >   DHCP LEASE EXPIRES  = Mon Nov 09 21:33:59 2015
. 2015.10.30 21:34:41 - OpenVPN >   DNS SERV = 192.168.178.1/255.255.255.255
. 2015.10.30 21:34:41 - OpenVPN > TAP-Windows Adapter V9
. 2015.10.30 21:34:41 - OpenVPN >   Index = 7
. 2015.10.30 21:34:41 - OpenVPN >   GUID = {3ADDE9CE-1F59-478C-A941-D7E5D57B1360}
. 2015.10.30 21:34:41 - OpenVPN >   IP = 10.4.3.165/255.255.0.0
. 2015.10.30 21:34:41 - OpenVPN >   MAC = 00:ff:3a:dd:e9:ce
. 2015.10.30 21:34:41 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.10.30 21:34:41 - OpenVPN >   DHCP SERV = 10.4.255.254/255.255.255.255
. 2015.10.30 21:34:41 - OpenVPN >   DHCP LEASE OBTAINED = Fri Oct 30 21:33:21 2015
. 2015.10.30 21:34:41 - OpenVPN >   DHCP LEASE EXPIRES  = Sat Oct 29 22:33:21 2016
. 2015.10.30 21:34:41 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2015.10.30 21:34:41 - Starting Management Interface
. 2015.10.30 21:34:41 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2015.10.30 21:34:41 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
! 2015.10.30 21:34:41 - Disconnecting
. 2015.10.30 21:34:41 - Management - Send 'signal SIGTERM'
. 2015.10.30 21:34:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2015.10.30 21:34:41 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.10.30 21:34:42 - Flushing DNS
. 2015.10.30 21:34:42 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.10.30 21:34:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.10.30 21:34:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.10.30 21:34:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.116 MASK 255.255.255.255 192.168.178.1
. 2015.10.30 21:34:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.10.30 21:34:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1
. 2015.10.30 21:34:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:34:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:34:46 - OpenVPN > Closing TUN/TAP interface
. 2015.10.30 21:34:46 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.10.30 21:34:46 - Connection terminated.
I 2015.10.30 21:34:46 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2015.10.30 21:34:46 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.10.30 21:34:49 - Checking authorization ...
! 2015.10.30 21:34:49 - Connecting to Alcyone (Netherlands, Alblasserdam)
. 2015.10.30 21:34:49 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.10.30 21:34:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.10.30 21:34:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.10.30 21:34:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.10.30 21:34:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:49 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.10.30 21:34:49 - OpenVPN > UDPv4 link local: [undef]
. 2015.10.30 21:34:49 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443
. 2015.10.30 21:34:49 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=424c5a41 45fcb2d4
. 2015.10.30 21:34:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.10.30 21:34:50 - OpenVPN > Validating certificate key usage
. 2015.10.30 21:34:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.10.30 21:34:50 - OpenVPN > VERIFY KU OK
. 2015.10.30 21:34:50 - OpenVPN > Validating certificate extended key usage
. 2015.10.30 21:34:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.10.30 21:34:50 - OpenVPN > VERIFY EKU OK
. 2015.10.30 21:34:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.10.30 21:34:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.10.30 21:34:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.10.30 21:34:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.10.30 21:34:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.10.30 21:34:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443
. 2015.10.30 21:34:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.10.30 21:34:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.29.79 255.255.0.0'
. 2015.10.30 21:34:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.10.30 21:34:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.10.30 21:34:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.10.30 21:34:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.10.30 21:34:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.10.30 21:34:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.10.30 21:34:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.10.30 21:34:52 - OpenVPN > open_tun, tt->ipv6=0
. 2015.10.30 21:34:52 - OpenVPN > TAP-WIN32 device [LAN-Verbindung] opened: \\.\Global\{3ADDE9CE-1F59-478C-A941-D7E5D57B1360}.tap
. 2015.10.30 21:34:52 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.10.30 21:34:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.29.79/255.255.0.0 [sUCCEEDED]
. 2015.10.30 21:34:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.29.79/255.255.0.0 on interface {3ADDE9CE-1F59-478C-A941-D7E5D57B1360} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.10.30 21:34:52 - OpenVPN > Successful ARP Flush on interface [7] {3ADDE9CE-1F59-478C-A941-D7E5D57B1360}
. 2015.10.30 21:34:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:34:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:34:57 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:02 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:04 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:05 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:06 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:07 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:08 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:09 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:10 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:11 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:12 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:14 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:15 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:16 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:17 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:18 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:20 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:21 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:22 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:23 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:24 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.10.30 21:35:26 - AirVPN Windows Interface Hack executed (LAN-Verbindung)
. 2015.10.30 21:35:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.10.30 21:35:27 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.178.1
. 2015.10.30 21:35:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.10.30 21:35:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.10.30 21:35:27 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.178.1 MASK 255.255.255.255 192.168.178.1 IF 8
. 2015.10.30 21:35:27 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:35:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.10.30 21:35:27 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:35:27 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.10.30 21:35:27 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.178.1 p=0 i=8 t=4 pr=3 a=149 h=0 m=10/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=7 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.3.165 p=0 i=7 t=3 pr=2 a=132 h=0 m=276/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 10.4.3.165 255.255.255.255 10.4.3.165 p=0 i=7 t=3 pr=2 a=132 h=0 m=276/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.3.165 p=0 i=7 t=3 pr=2 a=132 h=0 m=276/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4179 h=0 m=306/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4179 h=0 m=306/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4179 h=0 m=306/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=7 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 192.168.178.0 255.255.255.0 192.168.178.66 p=0 i=8 t=3 pr=2 a=149 h=0 m=266/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 192.168.178.1 255.255.255.255 192.168.178.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 192.168.178.66 255.255.255.255 192.168.178.66 p=0 i=8 t=3 pr=2 a=149 h=0 m=266/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 192.168.178.255 255.255.255.255 192.168.178.66 p=0 i=8 t=3 pr=2 a=149 h=0 m=266/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 213.152.161.116 255.255.255.255 192.168.178.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=4179 h=0 m=306/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.3.165 p=0 i=7 t=3 pr=2 a=4155 h=0 m=276/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.178.66 p=0 i=8 t=3 pr=2 a=4154 h=0 m=266/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=4179 h=0 m=306/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.3.165 p=0 i=7 t=3 pr=2 a=4155 h=0 m=276/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.178.66 p=0 i=8 t=3 pr=2 a=4154 h=0 m=266/0/0/0/0
. 2015.10.30 21:35:27 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.10.30 21:35:27 - OpenVPN > Realtek PCIe GBE Family Controller
. 2015.10.30 21:35:27 - OpenVPN >   Index = 8
. 2015.10.30 21:35:27 - OpenVPN >   GUID = {B72198D8-0FD0-4762-A121-2660BA8F31D2}
. 2015.10.30 21:35:27 - OpenVPN >   IP = 192.168.178.66/255.255.255.0
. 2015.10.30 21:35:27 - OpenVPN >   MAC = 44:8a:5b:a0:7c:5c
. 2015.10.30 21:35:27 - OpenVPN >   GATEWAY = 192.168.178.1/255.255.255.255
. 2015.10.30 21:35:27 - OpenVPN >   DHCP SERV = 192.168.178.1/255.255.255.255
. 2015.10.30 21:35:27 - OpenVPN >   DHCP LEASE OBTAINED = Fri Oct 30 21:34:46 2015
. 2015.10.30 21:35:27 - OpenVPN >   DHCP LEASE EXPIRES  = Mon Nov 09 21:34:46 2015
. 2015.10.30 21:35:27 - OpenVPN >   DNS SERV = 192.168.178.1/255.255.255.255
. 2015.10.30 21:35:27 - OpenVPN > TAP-Windows Adapter V9
. 2015.10.30 21:35:27 - OpenVPN >   Index = 7
. 2015.10.30 21:35:27 - OpenVPN >   GUID = {3ADDE9CE-1F59-478C-A941-D7E5D57B1360}
. 2015.10.30 21:35:27 - OpenVPN >   IP = 10.4.3.165/255.255.0.0
. 2015.10.30 21:35:27 - OpenVPN >   MAC = 00:ff:3a:dd:e9:ce
. 2015.10.30 21:35:27 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.10.30 21:35:27 - OpenVPN >   DHCP SERV = 10.4.255.254/255.255.255.255
. 2015.10.30 21:35:27 - OpenVPN >   DHCP LEASE OBTAINED = Fri Oct 30 21:33:21 2015
. 2015.10.30 21:35:27 - OpenVPN >   DHCP LEASE EXPIRES  = Sat Oct 29 22:33:21 2016
. 2015.10.30 21:35:27 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2015.10.30 21:35:27 - Starting Management Interface
. 2015.10.30 21:35:27 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2015.10.30 21:35:27 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2015.10.30 21:35:27 - DNS of a network adapter forced (TAP-Windows Adapter V9)
! 2015.10.30 21:35:27 - Disconnecting
. 2015.10.30 21:35:27 - Management - Send 'signal SIGTERM'
. 2015.10.30 21:35:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2015.10.30 21:35:28 - Flushing DNS
. 2015.10.30 21:35:28 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.10.30 21:35:28 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.10.30 21:35:28 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.10.30 21:35:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.116 MASK 255.255.255.255 192.168.178.1
. 2015.10.30 21:35:32 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.10.30 21:35:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.178.1 MASK 255.255.255.255 192.168.178.1
. 2015.10.30 21:35:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:35:32 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.10.30 21:35:32 - OpenVPN > Closing TUN/TAP interface
. 2015.10.30 21:35:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.10.30 21:35:32 - Connection terminated.
I 2015.10.30 21:35:32 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2015.10.30 21:35:32 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.10.30 21:35:32 - IPv6 restored.
! 2015.10.30 21:35:32 - Session terminated.
