Testedone420
Netgear WNDR4300 dd-wrt not connecting
I am using Netgear WNDR4300 with firmware v24-sp2 (03/25/13). I have followed the guide but it will not connect. here is the log:
Serverlog Clientlog 20151026 21:52:00 I OpenVPN 2.3.0 mips-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Mar 25 2013
20151026 21:52:00 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16
20151026 21:52:00 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20151026 21:52:00 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20151026 21:52:00 W WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible
20151026 21:52:00 I Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file
20151026 21:52:00 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20151026 21:52:00 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20151026 21:52:00 Socket Buffers: R=[172032->131072] S=[172032->131072]
20151026 21:52:00 I UDPv4 link local: [undef]
20151026 21:52:00 I UDPv4 link remote: [AF_INET]10.4.0.1:443
20151026 21:52:04 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20151026 21:52:04 D MANAGEMENT: CMD 'state'
20151026 21:52:04 MANAGEMENT: Client disconnected
20151026 21:52:04 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
does anyone have any ideas?
