FunkyMunkey
Frequent disconnects using AirVPN
I've been having problems with AirVPN client disconnecting on my Windows 7 PC. It used to happen occasionally, then once every hour or so, now it'll happen at times after just a couple of minutes. Here is a copy of a typical log:
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28992 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28993 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28994 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28995 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28996 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28997 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28998 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #28999 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:02:36 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #29000 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
And on and on until...
. 2015.10.25 09:02:46 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #51335 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.10.25 09:06:58 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.10.25 09:06:58 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.10.25 09:06:58 - OpenVPN > Restart pause, 2 second(s)
! 2015.10.25 09:06:58 - Disconnecting
Any thoughts as to how to fix this would be very much appreciated.
