the-chumsters
Air VPN disconnects after "checking route"
Hi there
Can anyone help please as i have tried a few times to use air vpn. But always get to "checking route" then disconnects everytime.
thanks
I have the same problem, it's been happening for a couple of days now.
This is what it says in my log tab. Does anyone understand this problem?
I 2015.11.06 09:04:51 - Session starting.
I 2015.11.06 09:04:52 - IPv6 disabled.
I 2015.11.06 09:04:53 - Checking authorization ...
! 2015.11.06 09:04:53 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:04:53 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:04:53 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:04:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:04:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:04:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:04:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:04:54 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:04:54 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:04:54 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:04:54 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=91d745ac 4b2988c8
. 2015.11.06 09:04:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:04:54 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:04:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:04:54 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:04:54 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:04:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:04:54 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:04:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:04:54 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:04:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:04:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:04:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:04:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:04:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:04:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:04:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:04:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:04:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:04:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:04:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:04:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:04:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:04:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:04:56 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:04:56 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:04:56 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:04:56 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:04:56 - Disconnecting
. 2015.11.06 09:04:56 - Connection terminated.
I 2015.11.06 09:05:00 - Checking authorization ...
! 2015.11.06 09:05:00 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:05:01 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:05:01 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:05:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:05:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:05:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:01 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:05:01 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:05:01 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:01 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=8875566e 6aa29d5c
. 2015.11.06 09:05:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:05:01 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:05:01 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:05:01 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:05:01 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:05:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:05:01 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:05:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:05:02 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:02 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:02 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:02 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:02 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:05:02 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:05:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:05:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:05:04 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:05:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:05:04 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:05:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:05:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:05:04 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:05:04 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:05:04 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:05:04 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:05:04 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:05:04 - Disconnecting
. 2015.11.06 09:05:04 - Connection terminated.
I 2015.11.06 09:05:09 - Checking authorization ...
! 2015.11.06 09:05:09 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:05:11 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:05:11 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:05:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:05:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:05:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:12 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:05:12 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:05:12 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:12 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=ace8a384 038c9581
. 2015.11.06 09:05:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:05:12 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:05:12 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:05:12 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:05:12 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:05:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:05:12 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:05:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:05:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:05:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:15 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:05:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:05:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:05:15 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:05:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:05:15 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:05:15 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:05:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:05:15 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:05:15 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:05:15 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:05:15 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:05:15 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:05:15 - Disconnecting
. 2015.11.06 09:05:15 - Connection terminated.
I 2015.11.06 09:05:18 - Checking authorization ...
! 2015.11.06 09:05:19 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:05:20 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:05:20 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:05:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:05:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:05:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:20 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:05:20 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:05:20 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:20 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=2775a8ec 449c5b78
. 2015.11.06 09:05:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:05:20 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:05:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:05:20 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:05:20 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:05:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:05:20 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:05:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:05:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:05:20 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:23 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:05:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:05:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:05:23 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:05:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:05:23 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:05:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:05:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:05:23 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:05:23 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:05:23 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:05:23 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:05:23 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:05:23 - Disconnecting
. 2015.11.06 09:05:23 - Connection terminated.
I 2015.11.06 09:05:26 - Checking authorization ...
! 2015.11.06 09:05:27 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:05:27 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:05:27 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:05:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:05:28 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:05:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:28 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:05:28 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:05:28 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:28 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=28000758 b93d3963
. 2015.11.06 09:05:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:05:28 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:05:28 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:05:28 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:05:28 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:05:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:05:28 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:05:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:05:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:28 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:28 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:05:28 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:05:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:05:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:05:31 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:05:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:05:31 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:05:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:05:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:05:31 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:05:31 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:05:31 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:05:31 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:05:31 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:05:31 - Disconnecting
. 2015.11.06 09:05:31 - Connection terminated.
I 2015.11.06 09:05:35 - Checking authorization ...
! 2015.11.06 09:05:35 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:05:36 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:05:37 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:05:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:05:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:05:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:37 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:05:37 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:05:37 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:37 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=6f3e199d a0e01939
. 2015.11.06 09:05:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:05:37 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:05:37 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:05:37 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:05:37 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:05:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:05:37 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:05:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:05:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:05:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:39 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:05:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:05:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:05:39 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:05:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:05:39 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:05:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:05:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:05:39 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:05:39 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:05:39 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:05:39 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:05:39 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:05:39 - Disconnecting
. 2015.11.06 09:05:40 - Connection terminated.
I 2015.11.06 09:05:43 - Checking authorization ...
! 2015.11.06 09:05:43 - Connecting to Hyadum (Netherlands, Alblasserdam)
. 2015.11.06 09:05:44 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.06 09:05:44 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.06 09:05:44 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.06 09:05:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.06 09:05:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:45 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.06 09:05:45 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.06 09:05:45 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:45 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=9d29ebdd 42a2d187
. 2015.11.06 09:05:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.06 09:05:45 - OpenVPN > Validating certificate key usage
. 2015.11.06 09:05:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.06 09:05:45 - OpenVPN > VERIFY KU OK
. 2015.11.06 09:05:45 - OpenVPN > Validating certificate extended key usage
. 2015.11.06 09:05:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.06 09:05:45 - OpenVPN > VERIFY EKU OK
. 2015.11.06 09:05:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.06 09:05:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.06 09:05:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.06 09:05:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.06 09:05:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443
. 2015.11.06 09:05:47 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.06 09:05:47 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.246 255.255.0.0'
. 2015.11.06 09:05:47 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.06 09:05:47 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.06 09:05:47 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.06 09:05:47 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.06 09:05:47 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.06 09:05:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.06 09:05:47 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.06 09:05:47 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.06 09:05:47 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{ECF2BDC4-272E-4541-A653-C3A1D7A2A845}.tap
. 2015.11.06 09:05:47 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2015.11.06 09:05:47 - OpenVPN > Exiting due to fatal error
! 2015.11.06 09:05:47 - Disconnecting
. 2015.11.06 09:05:47 - Connection terminated.
I 2015.11.06 09:05:48 - Cancel requested.
I 2015.11.06 09:05:48 - IPv6 restored.
! 2015.11.06 09:05:49 - Session terminated.
If you notice these lines appear frequently, everything else in your logs seems in order it's this one that's the issue. For some reason your TAP driver is already being used so the Eddie client can't access it.
Try set your settings under advanced as mine http://i.imgur.com/Gm9TMQt.png if they already are, click Uninstall driver when that's done reboot your computer, then try again(Make sure the uninstall worked check in the Network Connections panel under your windows control panel, if the TAP-Windows Adapter is still in there, right click on it and click properties and then Configure and under driver tab uninstall it through there)
Thank you, I had the same issue. I thought it happened because I recently installed Bluetooth, and had WiFi, Bluetooth, and LAN all enabled. All is working now. I had to uninstall the driver, re-boot, and connect AirVpn. Thank you again ZeroMaki!
You're welcome glad I could help =)
