Not connected, Your IP: 216.73.216.169
cdoyafei2006
how to install and use AirVPN with WinXP 32 bit
Go to https://airvpn.org/windows/
Select Windows XP and 64 or 32 bit (depending on what your system is) and run the installer it provides you.
It will install like any other program. After it has installed, start the program. Accept the terms and login, now you have full access. You can go to the "Servers" tab if you wish to choose a specific server, otherwise you can simply choose "Connect to the recommended server" and it will find the best server for you.
Please don't hesitate to ask for help if you don't understand anything or if you get stuck. The more specific you are, the more I and others can help.
