Yes that is what I said!
It seems that a troll is using Air and rarbg are detecting and blocking then releasing a week or more later with a result that around a dozen exits are blocked at any one time and it is following the troll around.
For more than a week now their trackers have been blocked: currently only the NL redirect exit is blocked for tracker.trackerfix.com - not possible to check their udp trackers with the available tools though any I try in the same list are also blocked.  So NL redirect blocked means more than half Air exits are blocked, as all of NL US and DE exits are routed thru the NL redirect. All the rest, direct are fine.
