rog 0 Posted ... new to vpn but thought i should try when my country decided to ban pirate bay.i got an issue about that when i close my router, airvpn shows 20-30 megabytes pr second upload.when i check kaspersky it shows that openvpn.exe is the culprit. is there something i can do to remedy this or is this an issue with airvpn ? Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... Try another server, maybe another port. (Sent via Tapatalk - this generally means I'm not sitting in front of my PC) Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
rog 0 Posted ... the serverside is not the issue..i lean towards that it must be an glitch in the programmingin airvpn or openvpn. Quote Share this post Link to post
eyes878 43 Posted ... This usually occurs when the connection is lost unexpectedly. Try entirely killing AirVPN/OpenVPN by: Trying to exit the AirVPN Client normally - if this works, then stop here.If it does not, then open a cmd window as admin (start --> type "cmd" --> right click and click "Run as Administrator")and type (or copy and paste): taskkill /f /im airvpn.exetaskkill /f /im openvpn.exe Then restart the AirVPN client. If the problem persists, try using TCP if you are using UDP, or UDP if you are using TCP - it may possibly hold connections better. Without the OpenVPN logs, I can't help you more. Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... lean towards that it must be an glitch in the programmingin airvpn or openvpn.Almost definitely not the case. Airvpn's 'Eddie' software is a wrapper for openvpn. Try different connection options with 'Eddie' as eyes wrote. Quote Share this post Link to post
YLwpLUbcf77U 32 Posted ... Happening to me (for months+) and other users. See here: https://airvpn.org/topic/15334-airvpn-client-shows-huge-upload-speed-drops-all-connections/ Major pain in the ass. However, some servers I don't have the problem with such as Heze. I can connect to Heze w/o the upload issue, but if I try Alkes or Peacock for example, it will happen. Same connection settings. Quote Share this post Link to post
