brettanw
Connection unusable after disconnecting airvpn
Hello everyone,
i am having issues with quitting airvpn.
i select "disconnect", then i disable the network lock and quit the app. For some reason i have no net connection. I have tried enabling/disabling windows firewall etc but nothing works. If I want to access the internet without airvpn i have to uninstall
help would be appreciated.
After disconnecting and then exiting (which will disable network lock too) your network settings should be restored to what they were previously but this can get messed up. Try looking through this, it might be that you just need to reset the DNS to auto in the IPv4 settings in your network adaptor.
