chuckhammerberry
PFSense Port Forwarding & Plex
I read the other postings and followed the instructions but cannot get Plex to be reachable online
Here is what i have
Airvpn
Port 14041 Protocol TCP/UDP to Local port 32400
in Pfsense
under firewall Rules
AIRVPN_WAN
ID Proto Source Port Destination Port Gateway Queue Schedule Description icon_plus.gif icon_pass.gif   IPv4 TCP/UDP AIRVPN_WAN address 32400 192.168.0.20 32400 * none   plex
Under NAT Port Forward
If Proto Src. addr Src. ports Dest. addr Dest. ports NAT IP NAT Ports Description icon_plus.gif icon_chain.pngWAN TCP/UDP * * * 14041 192.168.0.20 32400 plex_32400
Plex is set to 32400 but still unreachable
just noticed also that utorrent speeds are slow. I forwarded a adifferent port , didnt use local port, enetered the port into uTorrent which shows its reachable but speeds are nothing more than 1Mbps
Here my working Plex configuration
Sent from my iPad using Tapatalk
- Router/Firewall pfSense 25.11.1 (11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz)
- Switch Cisco SG350-10 /Zyxel XGS1210-12
- AP Netgear RAX200 (Stock FW)
- NAS Synology DS1621+ (5 x 8TB WD Red)
- ISP: Fiber 1000/300 (PPPoE)
Hi wolf666,
I have that exact same setup... Not working though... No outside connection in Plex. I've set the port in Plex manual and used the port from airvpn....
Some help please?
Best regards,
KniCKER
Was having the same issues with port forwarding within pfSense for Plex. I have the exact same configuration you guys referenced and found that the one thing that made it all work .. make sure to put 32400 inside the airvpn local port that you have set up as well. Maybe you are doing that and it still doesn't work, just thought I'd add that here. Hope it continues to work, lol. I don't want to toil for hours trying to figure it out again.
