Keaton
Unique situation of "checking route" failure
I installed the AirVPN 64 bit .deb package on Kali Linux, and everything was working solid until I attempted to tunnel the connection through tor. When it tried connecting it failed and repeated in a very glitchy way(it connected and failed multiple times per second) so i canceled it and set the preferences back to automatic connection. Now whenever I try to connect it gets stuck at "checking route" and times out and restarts infinitely. I tried what some said, which was to disable "check if tunnel is working effectively" and it still didnt work, it just went past that step and decided to get stuck at the checking DNS settings.
I would not like to disable safety measures, for it was working perfectly before i tried using tor. I even uninstalled the package and dependencies and deleted the .xml configuration file so i could install from scratch, but the problem persists.
Any help?
