Not connected, Your IP: 216.73.216.190
Rem1061
Really need some help Cannot connect with VPN
I have had this problem for 3-5 days now, and while the support has tried a few things they seem to have given up. The software goes through all tests/Latency checks etc, then tries to connect to the best location. Everything looks great then right before it should finish connection I get a "Not Found" in the log, systems resets and tries again. I have uninstalled all software, reinstalled. Unistalled Realtek Controllers/ reinstalled. I can get on Internet fine using standard IP connection. Really would like to get this fixed. Here is the "short" version of the log with the problem part at the bottom. Thanks
. 2015.09.12 15:13:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.09.12 15:13:09 - OpenVPN > F:\WINDOWS\system32\route.exe ADD 104.254.90.244 MASK 255.255.255.255 192.168.1.1
. 2015.09.12 15:13:09 - Starting Management Interface
. 2015.09.12 15:13:09 - OpenVPN > Initialization Sequence Completed
I 2015.09.12 15:13:09 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller - Packet Scheduler Miniport)
I 2015.09.12 15:13:09 - DNS of a network adapter forced (TAP-Windows Adapter V9 - Packet Scheduler Miniport)
W 2015.09.12 15:13:09 - Not found
! 2015.09.12 15:13:09 - Disconnecting
I can post the rest of the log, but this is the final portion where it all goes to crud. The support said they would foward it to the "eddie" developer and that was the last response I have had. Everything was working "okay" and now suddenly this.
