lucky72
no connection with my AIR VPN
I 2015.09.03 10:34:02 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2015.09.03 10:34:02 - Reading options from C:\Users\pc\AppData\Local\AirVPN\AirVPN.xml
. 2015.09.03 10:34:02 - Data Path: C:\Users\pc\AppData\Local\AirVPN
. 2015.09.03 10:34:02 - App Path: C:\Program Files\AirVPN
. 2015.09.03 10:34:02 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.09.03 10:34:02 - Command line arguments (1): path="home"
. 2015.09.03 10:34:02 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2015.09.03 10:34:02 - Updating systems & servers data ...
I 2015.09.03 10:34:02 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.09.03 10:34:02 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.09.03 10:34:02 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.09.03 10:34:02 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.09.03 10:34:02 - Ready
. 2015.09.03 10:34:05 - Systems & servers data update completed
I 2015.09.03 10:35:20 - Session starting.
I 2015.09.03 10:35:20 - IPv6 disabled.
I 2015.09.03 10:35:20 - Checking authorization ...
! 2015.09.03 10:35:23 - Connecting to Carinae (United Kingdom, Maidenhead)
. 2015.09.03 10:35:23 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.03 10:35:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.03 10:35:26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.03 10:35:26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.03 10:35:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:35:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:35:26 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.03 10:35:26 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.03 10:35:26 - OpenVPN > UDPv4 link remote: [AF_INET]94.229.74.90:443
. 2015.09.03 10:35:26 - OpenVPN > TLS: Initial packet from [AF_INET]94.229.74.90:443, sid=11275f58 c87901d2
. 2015.09.03 10:35:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.09.03 10:35:31 - OpenVPN > Validating certificate key usage
. 2015.09.03 10:35:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.09.03 10:35:31 - OpenVPN > VERIFY KU OK
. 2015.09.03 10:35:31 - OpenVPN > Validating certificate extended key usage
. 2015.09.03 10:35:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.09.03 10:35:31 - OpenVPN > VERIFY EKU OK
. 2015.09.03 10:35:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.09.03 10:35:34 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.03 10:35:34 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:35:34 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.03 10:35:34 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:35:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.09.03 10:35:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]94.229.74.90:443
. 2015.09.03 10:35:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.09.03 10:35:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.16.119 255.255.0.0'
. 2015.09.03 10:35:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.09.03 10:35:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.09.03 10:35:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.09.03 10:35:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.09.03 10:35:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.09.03 10:35:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.09.03 10:35:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.09.03 10:35:36 - OpenVPN > open_tun, tt->ipv6=0
. 2015.09.03 10:35:37 - OpenVPN > TAP-WIN32 device [Connexion au réseau local 3] opened: \\.\Global\{364D32C9-0F4E-4743-B0D9-1B311A4FE3AD}.tap
. 2015.09.03 10:35:37 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.09.03 10:35:37 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.16.119/255.255.0.0 [sUCCEEDED]
. 2015.09.03 10:35:37 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.16.119/255.255.0.0 on interface {364D32C9-0F4E-4743-B0D9-1B311A4FE3AD} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.09.03 10:35:37 - OpenVPN > Successful ARP Flush on interface [23] {364D32C9-0F4E-4743-B0D9-1B311A4FE3AD}
. 2015.09.03 10:35:42 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.09.03 10:35:42 - OpenVPN > C:\Windows\system32\route.exe ADD 94.229.74.90 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:35:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2015.09.03 10:35:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.09.03 10:35:42 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 14
. 2015.09.03 10:35:42 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:35:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.09.03 10:35:42 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:35:42 - Starting Management Interface
. 2015.09.03 10:35:42 - OpenVPN > Initialization Sequence Completed
I 2015.09.03 10:35:42 - DNS of a network adapter forced (Intel® Centrino® Wireless-N 2230)
I 2015.09.03 10:35:51 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.09.03 10:36:03 - Flushing DNS
I 2015.09.03 10:36:05 - Checking route
W 2015.09.03 10:36:55 - Le délai d'attente de l'opération a expiré.
! 2015.09.03 10:36:55 - Disconnecting
. 2015.09.03 10:36:55 - Management - Send 'signal SIGTERM'
. 2015.09.03 10:36:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.09.03 10:36:55 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.09.03 10:36:55 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.09.03 10:37:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 94.229.74.90 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:37:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.09.03 10:37:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:37:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:37:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:37:00 - OpenVPN > Closing TUN/TAP interface
. 2015.09.03 10:37:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.09.03 10:37:00 - Connection terminated.
I 2015.09.03 10:37:00 - DNS of a network adapter restored to original settings (Intel® Centrino® Wireless-N 2230)
I 2015.09.03 10:37:00 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.09.03 10:37:03 - Checking authorization ...
! 2015.09.03 10:37:05 - Connecting to Dabih (United Kingdom, Manchester)
. 2015.09.03 10:37:05 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.03 10:37:05 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.03 10:37:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.03 10:37:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.03 10:37:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:37:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:37:05 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.03 10:37:05 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.03 10:37:05 - OpenVPN > UDPv4 link remote: [AF_INET]82.145.37.202:443
. 2015.09.03 10:37:05 - OpenVPN > TLS: Initial packet from [AF_INET]82.145.37.202:443, sid=74ddd126 ad62d1fd
. 2015.09.03 10:37:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.09.03 10:37:06 - OpenVPN > Validating certificate key usage
. 2015.09.03 10:37:06 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.09.03 10:37:06 - OpenVPN > VERIFY KU OK
. 2015.09.03 10:37:06 - OpenVPN > Validating certificate extended key usage
. 2015.09.03 10:37:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.09.03 10:37:06 - OpenVPN > VERIFY EKU OK
. 2015.09.03 10:37:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.09.03 10:37:13 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.03 10:37:13 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:37:13 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.03 10:37:13 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:37:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.09.03 10:37:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]82.145.37.202:443
. 2015.09.03 10:37:15 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.09.03 10:37:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.90 255.255.0.0'
. 2015.09.03 10:37:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.09.03 10:37:15 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.09.03 10:37:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.09.03 10:37:15 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.09.03 10:37:15 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.09.03 10:37:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.09.03 10:37:15 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.09.03 10:37:15 - OpenVPN > open_tun, tt->ipv6=0
. 2015.09.03 10:37:15 - OpenVPN > TAP-WIN32 device [Connexion au réseau local 3] opened: \\.\Global\{364D32C9-0F4E-4743-B0D9-1B311A4FE3AD}.tap
. 2015.09.03 10:37:15 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.09.03 10:37:15 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.90/255.255.0.0 [sUCCEEDED]
. 2015.09.03 10:37:15 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.90/255.255.0.0 on interface {364D32C9-0F4E-4743-B0D9-1B311A4FE3AD} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.09.03 10:37:15 - OpenVPN > Successful ARP Flush on interface [23] {364D32C9-0F4E-4743-B0D9-1B311A4FE3AD}
. 2015.09.03 10:37:20 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.09.03 10:37:20 - OpenVPN > C:\Windows\system32\route.exe ADD 82.145.37.202 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:37:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2015.09.03 10:37:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.09.03 10:37:20 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 14
. 2015.09.03 10:37:20 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:37:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.09.03 10:37:20 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:37:20 - Starting Management Interface
. 2015.09.03 10:37:20 - OpenVPN > Initialization Sequence Completed
I 2015.09.03 10:37:20 - DNS of a network adapter forced (Intel® Centrino® Wireless-N 2230)
I 2015.09.03 10:37:27 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.09.03 10:37:38 - Flushing DNS
I 2015.09.03 10:37:41 - Checking route
W 2015.09.03 10:38:31 - Le délai d'attente de l'opération a expiré.
! 2015.09.03 10:38:31 - Disconnecting
. 2015.09.03 10:38:31 - Management - Send 'signal SIGTERM'
. 2015.09.03 10:38:31 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.09.03 10:38:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.09.03 10:38:31 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.09.03 10:38:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 82.145.37.202 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:38:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.09.03 10:38:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:38:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:38:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:38:36 - OpenVPN > Closing TUN/TAP interface
. 2015.09.03 10:38:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.09.03 10:38:36 - Connection terminated.
I 2015.09.03 10:38:36 - DNS of a network adapter restored to original settings (Intel® Centrino® Wireless-N 2230)
I 2015.09.03 10:38:36 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.09.03 10:38:39 - Checking authorization ...
! 2015.09.03 10:38:41 - Connecting to Dabih (United Kingdom, Manchester)
. 2015.09.03 10:38:41 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.03 10:38:41 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.03 10:38:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.03 10:38:42 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.03 10:38:42 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:38:42 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:38:42 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.03 10:38:42 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.03 10:38:42 - OpenVPN > UDPv4 link remote: [AF_INET]82.145.37.202:443
. 2015.09.03 10:38:42 - OpenVPN > TLS: Initial packet from [AF_INET]82.145.37.202:443, sid=58eb4ded f431333b
. 2015.09.03 10:38:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.09.03 10:38:43 - OpenVPN > Validating certificate key usage
. 2015.09.03 10:38:43 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.09.03 10:38:43 - OpenVPN > VERIFY KU OK
. 2015.09.03 10:38:43 - OpenVPN > Validating certificate extended key usage
. 2015.09.03 10:38:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.09.03 10:38:43 - OpenVPN > VERIFY EKU OK
. 2015.09.03 10:38:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.09.03 10:38:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.03 10:38:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:38:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.03 10:38:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.03 10:38:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.09.03 10:38:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]82.145.37.202:443
. 2015.09.03 10:38:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.09.03 10:38:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.90 255.255.0.0'
. 2015.09.03 10:38:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.09.03 10:38:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.09.03 10:38:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.09.03 10:38:53 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.09.03 10:38:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.09.03 10:38:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.09.03 10:38:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.09.03 10:38:53 - OpenVPN > open_tun, tt->ipv6=0
. 2015.09.03 10:38:53 - OpenVPN > TAP-WIN32 device [Connexion au réseau local 3] opened: \\.\Global\{364D32C9-0F4E-4743-B0D9-1B311A4FE3AD}.tap
. 2015.09.03 10:38:53 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.09.03 10:38:53 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.90/255.255.0.0 [sUCCEEDED]
. 2015.09.03 10:38:53 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.90/255.255.0.0 on interface {364D32C9-0F4E-4743-B0D9-1B311A4FE3AD} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.09.03 10:38:53 - OpenVPN > Successful ARP Flush on interface [23] {364D32C9-0F4E-4743-B0D9-1B311A4FE3AD}
. 2015.09.03 10:38:58 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.09.03 10:38:58 - OpenVPN > C:\Windows\system32\route.exe ADD 82.145.37.202 MASK 255.255.255.255 192.168.1.1
. 2015.09.03 10:38:58 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2015.09.03 10:38:58 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.09.03 10:38:58 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 14
. 2015.09.03 10:38:58 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:38:58 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.09.03 10:38:58 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.09.03 10:38:58 - Starting Management Interface
. 2015.09.03 10:38:58 - OpenVPN > Initialization Sequence Completed
I 2015.09.03 10:38:58 - DNS of a network adapter forced (Intel® Centrino® Wireless-N 2230)
I 2015.09.03 10:39:05 - DNS of a network adapter forced (TAP-Windows Adapter V9)
please help me
