xOATTKXB
does AirVPN protect against SSL interception?
AirVPN tunnels the entire connection including all HTTP/HTTPS. This means that the only person that would ever be able to intercept your SSL is AirVPN, and they obviously do not. If you can successfully establish a connection to an AirVPN server you can usually assume your connection is safe and secure.
