anon000000
TAP Adapter won't let me connect to internet - please help!
Dear friends and VPN staff, please help.
My VPN was working then when I restart my router AirVPN won't connect to internet using browser.
I can torrent OK, DL and UL, but some reason when I start VPN I can't get interent through any browser.
I use Windows 7, 32bit, upgraded to Eddie client 2.10
My network connections are free (see first photo) then when VPN start it change to big red cross (see second photo).
I tried to change the DNS settings in the adapter properties to "obtain DNS address automatically" for both TAP and my normal Broadcom adapter but this don't help me.  Without VPN running the internet access is OK.
I have attached third photo of my client settings.
I don't know what else I can do!!!
Can anybody help me????
Every time I see big red cross I want to die......well, maybe no die but cry alot!
Thankyou if can help.
Please check the status of the TAP adapter although it has a 10.x.x.x ip address and DNS servers the gateway address is usually missing. Manually putting it in to the DNS server address should work.
Thanks Zaroad.....I try to find it but TAP Adapter don't have gateway address.  My Broadcom does but not TAP - see photos.
Is crazy.....was working this morning....suddenly no working and headache.
Where can I find it?
I can use OpenVPN program to make AirVPN go through TOR as socks proxy but connection is very slow.  Here AirVPN is connect to internet.
Still no Default Gateway IP address of TAP Adapter.
I think it is something very simple I miss    but where is it????
