sheppy
Unable to connect Synology to AirVPN
I just set-up AirVPN on my Synoly, using this guide:
https://airvpn.org/topic/2487-how-to-configure-a-synology-device/
Straightforward, not that difficult...
However, my DiskStation refuses to connect:
Mon Aug 24 22:51:51 2015 RESOLVE: Cannot resolve host address: nl.vpn.airdns.org: Name or service not known
Looking at the log-file, all seems okay though.
I've tried attaching the set-up and log files, but I'm not permitted to do that...
This is my set-up (between ###, without the ### of course...):
# Air VPN | https://airvpn.org | Monday 24th of August 2015 11:39:26 AM
# OpenVPN Client Configuration
# AirVPN_Netherlands_UDP-53
client
dev tun
proto udp
remote nl.vpn.airdns.org 53
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
cipher AES-256-CBC
comp-lzo no
route-delay 5
verb 3
explicit-exit-notify 5
ca "ca.crt"
cert "user.crt"
key "user.key"
tls-auth "ta.key" 1
float
reneg-sec 0
plugin /lib/openvpn/openvpn-down-root.so /usr/syno/etc.defaults/synovpnclient/scripts/ip-down
log-append /volume1/homes/admin/AirVPN.log
And the log:
Mon Aug 24 22:21:10 2015 OpenVPN 2.3.6 i686-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Jun 13 2015
Mon Aug 24 22:21:10 2015 library versions: OpenSSL 1.0.1p-fips 9 Jul 2015, LZO 2.08
Mon Aug 24 22:21:10 2015 PLUGIN_INIT: POST /lib/openvpn/openvpn-down-root.so '[/lib/openvpn/openvpn-down-root.so] [/usr/syno/etc.defaults/synovpnclient/scripts/ip-down]' intercepted=PLUGIN_UP|PLUGIN_DOWN
Mon Aug 24 22:21:10 2015 WARNING: file 'user.key' is group or others accessible
Mon Aug 24 22:21:10 2015 WARNING: file 'ta.key' is group or others accessible
Mon Aug 24 22:21:10 2015 Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
Mon Aug 24 22:21:10 2015 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Aug 24 22:21:10 2015 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Aug 24 22:21:10 2015 Socket Buffers: R=[212992->131072] S=[212992->131072]
Mon Aug 24 22:21:10 2015 UDPv4 link local: [undef]
Mon Aug 24 22:21:10 2015 UDPv4 link remote: [AF_INET]213.152.161.44:53
Mon Aug 24 22:21:10 2015 TLS: Initial packet from [AF_INET]213.152.161.44:53, sid=0554d615 61d29c8f
Mon Aug 24 22:21:12 2015 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Mon Aug 24 22:21:12 2015 Validating certificate key usage
Mon Aug 24 22:21:12 2015 ++ Certificate has key usage  00a0, expects 00a0
Mon Aug 24 22:21:12 2015 VERIFY KU OK
Mon Aug 24 22:21:12 2015 Validating certificate extended key usage
Mon Aug 24 22:21:12 2015 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Mon Aug 24 22:21:12 2015 VERIFY EKU OK
Mon Aug 24 22:21:12 2015 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Mon Aug 24 22:21:18 2015 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Aug 24 22:21:18 2015 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Aug 24 22:21:18 2015 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Aug 24 22:21:18 2015 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Aug 24 22:21:18 2015 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Mon Aug 24 22:21:18 2015 [server] Peer Connection Initiated with [AF_INET]213.152.161.44:53
Mon Aug 24 22:21:21 2015 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Mon Aug 24 22:21:21 2015 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,comp-lzo no,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.8.0.45 255.255.0.0'
Mon Aug 24 22:21:21 2015 OPTIONS IMPORT: timers and/or timeouts modified
Mon Aug 24 22:21:21 2015 OPTIONS IMPORT: LZO parms modified
Mon Aug 24 22:21:21 2015 OPTIONS IMPORT: --ifconfig/up options modified
Mon Aug 24 22:21:21 2015 OPTIONS IMPORT: route options modified
Mon Aug 24 22:21:21 2015 OPTIONS IMPORT: route-related options modified
Mon Aug 24 22:21:21 2015 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Aug 24 22:21:21 2015 ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eth0 HWADDR=00:11:32:19:e6:71
Mon Aug 24 22:21:21 2015 TUN/TAP device tun0 opened
Mon Aug 24 22:21:21 2015 TUN/TAP TX queue length set to 100
Mon Aug 24 22:21:21 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Aug 24 22:21:21 2015 /sbin/ifconfig tun0 10.8.0.45 netmask 255.255.0.0 mtu 1500 broadcast 10.8.255.255
Mon Aug 24 22:21:21 2015 PLUGIN_CALL: POST /lib/openvpn/openvpn-down-root.so/PLUGIN_UP status=0
Mon Aug 24 22:21:26 2015 /sbin/route add -net 213.152.161.44 netmask 255.255.255.255 gw 192.168.0.1
Mon Aug 24 22:21:26 2015 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.8.0.1
Mon Aug 24 22:21:26 2015 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.8.0.1
Mon Aug 24 22:21:26 2015 Initialization Sequence Completed
Mon Aug 24 22:24:12 2015 [server] Inactivity timeout (--ping-restart), restarting
Mon Aug 24 22:24:12 2015 SIGUSR1[soft,ping-restart] received, process restarting
Mon Aug 24 22:24:12 2015 Restart pause, 2 second(s)
Mon Aug 24 22:24:14 2015 Socket Buffers: R=[212992->131072] S=[212992->131072]
Mon Aug 24 22:24:54 2015 RESOLVE: Cannot resolve host address: nl.vpn.airdns.org: Name or service not known
Mon Aug 24 22:25:34 2015 RESOLVE: Cannot resolve host address: nl.vpn.airdns.org: Name or service not known
Mon Aug 24 22:26:19 2015 RESOLVE: Cannot resolve host address: nl.vpn.airdns.org: Name or service not known
What could I be doing wrong???
Any help is appreciated.
Thanks in advance.
