Nero
iOS unable to connect PolarSSL: SSL read error
Error just started yesterday, was working before that. Continuously tries to reconnect, I've tried other servers, ports and both udp and tcp with no luck.
Details:
iPad v1
OpenVPN 1.0.1 build 88 (iOS), unable to update to newer version as it is unsupported on the old iPad
OpenVPN Log:
2015-08-20 09:34:30 EVENT: RECONNECTING
2015-08-20 09:34:30 LZO-ASYM init swap=0 asym=1
2015-08-20 09:34:30 Comp-stub init swap=0
2015-08-20 09:34:30 EVENT: RESOLVE
2015-08-20 09:34:30 Contacting 198.203.28.42:443 via UDP
2015-08-20 09:34:30 EVENT: WAIT
2015-08-20 09:34:30 Connecting to 198.203.28.42:443 (198.203.28.42) via UDPv4
2015-08-20 09:34:30 EVENT: CONNECTING
2015-08-20 09:34:30 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
2015-08-20 09:34:30 Peer Info:
IV_VER=1.0
IV_PLAT=ios
IV_NCP=1
IV_SNAPPY=1
IV_LZO=1
IV_LZO_SWAP=1
IV_COMP_STUB=1
2015-08-20 09:34:31 VERIFY OK: depth=0
cert. version : 3
serial number : 47
issuer name   : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
subject name  : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
issued  on    : 2014-04-11 10:45:11
expires on    : 2024-04-08 10:45:11
signed using  : RSA+SHA1
RSA key size  : 4096 bits
2015-08-20 09:34:37 Client exception in transport_recv_excode: PolarSSL: SSL read error : SSL - Verification of the message MAC failed
2015-08-20 09:34:37 Client terminated, restarting in 2...
2015-08-20 09:34:39 EVENT: RECONNECTING
2015-08-20 09:34:39 LZO-ASYM init swap=0 asym=1
2015-08-20 09:34:39 Comp-stub init swap=0
2015-08-20 09:34:39 EVENT: RESOLVE
2015-08-20 09:34:39 Contacting 198.203.28.42:443 via UDP
2015-08-20 09:34:39 EVENT: WAIT
2015-08-20 09:34:39 Connecting to 198.203.28.42:443 (198.203.28.42) via UDPv4
2015-08-20 09:34:39 EVENT: CONNECTING
2015-08-20 09:34:39 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client
2015-08-20 09:34:39 Peer Info:
IV_VER=1.0
IV_PLAT=ios
IV_NCP=1
IV_SNAPPY=1
IV_LZO=1
IV_LZO_SWAP=1
IV_COMP_STUB=1
2015-08-20 09:34:39 VERIFY OK: depth=0
cert. version : 3
serial number : 47
2015-08-20 09:34:45 Client exception in transport_recv_excode: PolarSSL: SSL read error : SSL - Verification of the message MAC failed
2015-08-20 09:34:45 Client terminated, restarting in 2...
2015-08-20 09:34:46 EVENT: DISCONNECTED
2015-08-20 09:34:46 Raw stats on disconnect:
  BYTES_IN : 21682
  BYTES_OUT : 31512
  PACKETS_IN : 165
  PACKETS_OUT : 176
  SSL_ERROR : 4
  N_RECONNECT : 3
2015-08-20 09:34:46 Performance stats on disconnect:
  CPU usage (microseconds): 17179965
  Network bytes per CPU second: 3096
  Tunnel bytes per CPU second: 0
2015-08-20 09:34:46 ----- OpenVPN Stop -----
