Someoneelse 0 Posted ... Using win 7 and have been having some problems for months now with the client losing connection and trying to reconnect but it never does and I must restart the client. The log is below, any ideas? <Snipped many of the "Operation timed out" lines due to space. . 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:33 - OpenVPN > write UDPv4: Operation not permitted (code=1). 2015.08.18 22:42:34 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2015.08.18 22:42:34 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2015.08.18 22:42:34 - OpenVPN > Restart pause, 2 second(s)! 2015.08.18 22:42:34 - Disconnecting. 2015.08.18 22:42:34 - Management - Send 'signal SIGTERM'. 2015.08.18 22:42:34 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2015.08.18 22:42:34 - OpenVPN > MANAGEMENT: Client disconnected. 2015.08.18 22:42:34 - OpenVPN > Assertion failed at misc.c:785. 2015.08.18 22:42:34 - OpenVPN > Exiting due to fatal error. 2015.08.18 22:42:34 - Connection terminated.I 2015.08.18 22:42:44 - Checking authorization ...! 2015.08.18 22:42:44 - Connecting to Gienah (Netherlands, Alblasserdam). 2015.08.18 22:42:44 - SSH > OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014. 2015.08.18 22:42:44 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config. 2015.08.18 22:42:44 - SSH > debug1: /etc/ssh/ssh_config line 19: Applying options for *. 2015.08.18 22:42:44 - SSH > debug1: Connecting to 213.152.162.93 [213.152.162.93] port 22.. 2015.08.18 22:44:51 - SSH > debug1: connect to address 213.152.162.93 port 22: Connection timed out. 2015.08.18 22:44:51 - SSH > ssh: connect to host 213.152.162.93 port 22: Connection timed out! 2015.08.18 22:44:51 - Disconnecting. 2015.08.18 22:44:51 - Connection terminated.I 2015.08.18 22:44:54 - Checking authorization ...! 2015.08.18 22:44:55 - Connecting to Gienah (Netherlands, Alblasserdam). 2015.08.18 22:44:55 - SSH > OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014. 2015.08.18 22:44:55 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config. 2015.08.18 22:44:55 - SSH > debug1: /etc/ssh/ssh_config line 19: Applying options for *. 2015.08.18 22:44:55 - SSH > debug1: Connecting to 213.152.162.93 [213.152.162.93] port 22.. 2015.08.18 22:47:02 - SSH > debug1: connect to address 213.152.162.93 port 22: Connection timed out. 2015.08.18 22:47:02 - SSH > ssh: connect to host 213.152.162.93 port 22: Connection timed out! 2015.08.18 22:47:02 - Disconnecting. 2015.08.18 22:47:02 - Connection terminated.I 2015.08.18 22:47:05 - Checking authorization ...! 2015.08.18 22:47:05 - Connecting to Gienah (Netherlands, Alblasserdam). 2015.08.18 22:47:06 - SSH > OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014. 2015.08.18 22:47:06 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config. 2015.08.18 22:47:06 - SSH > debug1: /etc/ssh/ssh_config line 19: Applying options for *. 2015.08.18 22:47:06 - SSH > debug1: Connecting to 213.152.162.93 [213.152.162.93] port 22.. 2015.08.18 22:49:13 - SSH > debug1: connect to address 213.152.162.93 port 22: Connection timed out. 2015.08.18 22:49:13 - SSH > ssh: connect to host 213.152.162.93 port 22: Connection timed out! 2015.08.18 22:49:13 - Disconnecting. 2015.08.18 22:49:13 - Connection terminated.I 2015.08.18 22:49:16 - Checking authorization ...! 2015.08.18 22:49:16 - Connecting to Gienah (Netherlands, Alblasserdam). 2015.08.18 22:49:16 - SSH > OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014. 2015.08.18 22:49:16 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config. 2015.08.18 22:49:16 - SSH > debug1: /etc/ssh/ssh_config line 19: Applying options for *. 2015.08.18 22:49:16 - SSH > debug1: Connecting to 213.152.162.93 [213.152.162.93] port 22.. 2015.08.18 22:51:24 - SSH > debug1: connect to address 213.152.162.93 port 22: Connection timed out. 2015.08.18 22:51:24 - SSH > ssh: connect to host 213.152.162.93 port 22: Connection timed out! 2015.08.18 22:51:24 - Disconnecting. 2015.08.18 22:51:24 - Connection terminated.I 2015.08.18 22:51:27 - Checking authorization ...! 2015.08.18 22:51:27 - Connecting to Gienah (Netherlands, Alblasserdam). 2015.08.18 22:51:27 - SSH > OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014. 2015.08.18 22:51:27 - SSH > debug1: Reading configuration data /etc/ssh/ssh_config. 2015.08.18 22:51:27 - SSH > debug1: /etc/ssh/ssh_config line 19: Applying options for *. 2015.08.18 22:51:27 - SSH > debug1: Connecting to 213.152.162.93 [213.152.162.93] port 22. Quote Share this post Link to post
Davidsafe 0 Posted ... I have been having the same problem all day Quote Share this post Link to post
s0b 0 Posted ... Same problem here, I just joined AirVPN and my connection doesnt last longer than 1 minute because of the "Inactivity timeout" error. Looks like I trust too much Reddit. Quote Share this post Link to post
Someoneelse 0 Posted ... So I have heard of this Airvpn tech support being very fast and helpful and I was like "That sounds like my kind of VPN!" So anyways.... where exactly is this vaunted tech support staff? I've seen neither hide nor hair of them since I started this thread. Quote Share this post Link to post
Staff 10394 Posted ... So I have heard of this Airvpn tech support being very fast and helpful and I was like "That sounds like my kind of VPN!" So anyways.... where exactly is this vaunted tech support staff? I've seen neither hide nor hair of them since I started this thread. Hi, this is one of the community forums, please open a ticket to reach the support team. Kind regards Quote Share this post Link to post
