LedHed
Simultaneous Connection Question
I read on the site a while back you are limited to 3 concurrent connections. However I am having an issue when I connect using the Eddie client where the two machines will both disconnect and reconnect repeatedly with both connected to the same physical server location.
Are we limited to a single connection per available server or should I be able to have two simultaneous connections on the same server location?
Thanks for any help!
each connection from the same account must go to a different server. If you don't need remote port forwarding, than you can connect different devices to the same VPN server from the same account but only to different ports/protocols.
AirVPN Support Team
Another workaround for this is using different protocols/ports. Works for me. Aslong as each connection is to a different server and/or protocol/port it works fine.
I always face the same problem of connecting with the same server using difference devices. It does not allow me
