eyes878
leakforums.net blocked
Leakforums.net appears to block most if not all of the VPN servers, I believe they use a very similar blocking system to hackforums.net.
The method you used for hackforums.net will quite likely fit here too.
EDIT: I knew I shouldn't have posted this at 2:25am.. I've posted this in the wrong section. If the staff could move this I would appreciate it.
Does anyone know a server that works with leakforums.net or hackforums.com ?
Interesting but no way I'm browsing them without my VPN
thanks
thanks
The problem has been fixed with both sites with so are working now
thanks
Hasn't worked with any of the servers I've tried so far
