Not connected, Your IP: 216.73.216.147
richwilson
Split Tunnel Wireless networks
My goal:
One large 50mb+ download internet connection with two wireless networks connected to it.  The first wireless network with USA VPN and the second wireless network with UK VPN.
So the router would use split tunneling to divide the connection, and the separate AP's connected would use different VPN profiles.
Then any type of client (Windows, Mac, Ipad, Android, or HPC box) can connect to any network based upon the profile desired.
My Question:   I've found the guides for doing this on an application level, but can anybody tell if it's possible and how to do it on a port level (for all traffic going through that port).
I'm open to DD-WRT, PFSense, Tomato, etc
Thanks in advance,
Rich
