Hi Everyone,
It seems like my connection is constantly dropping, reconnecting, or switching servers. Is this a common problem? I can't seem to stay connected to one server for more than 10-15 minutes tops without dropping the connection.
I kept having the exact same problem using the AirVPN program so I switched over to using OpenVPN GUI and generated a certificate through the site here.  It is very simple to use, I would check it out until we figure out what is causing this.
Instructions: https://airvpn.org/topic/11801-using-airvpn-with-windows-openvpn-gui/
Can anyone tell me if the .bat file I set up for locking my IP to static with the AirVPN program now has the wrong IP listed?  Here is the .bat file:
ECHO
netsh interface ip set dns "Local Area Connection" static 10.4.0.1
PAUSE
OpenVPN is showing my connected IP as 10.5.0.***
The "code" above was something I pulled off the AirVPN forums a year or two ago and I am just trying to make sure I am locking to the right IP.  I assume I am since it still connects when OpenVPN is connected.
