Not connected, Your IP: 216.73.216.167
rwestland
Am I connected?
I just installed everything. I'm using Windows XP.
When connecting with Air VPN it says that I'm connected, but when I go to https://airvpn.org, it says at the bottom of the page that I'm not connected.
When I go to http://www.whatismyip.com, I still see my IP-adres as if I am not connected.
Is there some setting I have to do?
Rob
Can you please send us the connection logs?
Strange, I changed the login mode from 443 TCP to 53 and then back again and now it works fine...
Glad to know the issue is fixed. For a while, check whether you're really connected for additional security, and feel free to send us the connection logs.
