sods69
Automatic changing if ISPs
Hi
I have a newbie question. I'd like to know if there is a way to set AIR VPN to automatically change servers so that I don't have to worry about that. And if I can choose the length it stays on any given server.
Best
No, but you can achieve it manually.
Just make a small script that will close the openvpn client, then put something like earth.airvpn.org in the "remote" line.
This should connect you to the current best server at the moment of connection. They change pretty often.
Thanks. That's way over my head but if they change often anyway, it sounds like it may not be too necessary.
