peteronn
anyone could help. trouble connecting via DD wrt (e1200)
Any idea, what I could do?
Serverlog Clientlog 20150722 08:29:28 I OpenVPN 2.3.0 mipsel-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Mar 25 2013
20150722 08:29:28 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16
20150722 08:29:28 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20150722 08:29:28 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible
20150722 08:29:28 W WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible
20150722 08:29:28 I Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file
20150722 08:29:28 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20150722 08:29:28 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
20150722 08:29:28 Socket Buffers: R=[114688->131072] S=[114688->131072]
20150722 08:29:28 I UDPv4 link local: [undef]
20150722 08:29:28 I UDPv4 link remote: [AF_INET]10.4.0.1:443
20150722 08:29:29 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20150722 08:29:29 D MANAGEMENT: CMD 'state'
20150722 08:29:29 MANAGEMENT: Client disconnected
20150722 08:29:30 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20150722 08:29:30 D MANAGEMENT: CMD 'log 500'
20150722 08:29:30 MANAGEMENT: Client disconnected
20150722 08:30:29 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20150722 08:30:29 N TLS Error: TLS handshake failed
20150722 08:30:29 I SIGUSR1[soft tls-error] received process restarting
20150722 08:30:29 Restart pause 2 second(s)
20150722 08:30:31 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20150722 08:30:31 Socket Buffers: R=[114688->131072] S=[114688->131072]
20150722 08:30:31 I UDPv4 link local: [undef]
20150722 08:30:31 I UDPv4 link remote: [AF_INET]10.4.0.1:443
20150722 08:31:31 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20150722 08:31:31 N TLS Error: TLS handshake failed
20150722 08:31:31 I SIGUSR1[soft tls-error] received process restarting
20150722 08:31:31 Restart pause 2 second(s)
20150722 08:31:33 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20150722 08:31:33 Socket Buffers: R=[114688->131072] S=[114688->131072]
20150722 08:31:33 I UDPv4 link local: [undef]
20150722 08:31:33 I UDPv4 link remote: [AF_INET]10.4.0.1:443
20150722 08:32:33 N TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
20150722 08:32:33 N TLS Error: TLS handshake failed
20150722 08:32:33 I SIGUSR1[soft tls-error] received process restarting
20150722 08:32:33 Restart pause 2 second(s)
20150722 08:32:35 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20150722 08:32:35 Socket Buffers: R=[114688->131072] S=[114688->131072]
20150722 08:32:35 I UDPv4 link local: [undef]
20150722 08:32:35 I UDPv4 link remote: [AF_INET]10.4.0.1:443
20150722 08:33:30 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20150722 08:33:30 D MANAGEMENT: CMD 'state'
20150722 08:33:30 MANAGEMENT: Client disconnected
20150722 08:33:30 D MANAGEMENT: CMD 'log 500'
19700101 00:00:00
Cheers
Peter
