So, I'm running Ubuntu 14.04 and I'm having a problem with setting up itables to shutdown traffic in case the vpn goes down. I do want my LAN to have access if the vpn goes down, though.
I'm connecting to anser. Once I run these iptables, my torrent client is no longer able to connect to anyone.
sudo iptables -A INPUT -i tun0 -j ACCEPT
sudo iptables -A OUTPUT -o tun0 -j ACCEPT
sudo iptables -A INPUT -s 127.0.0.1 -j ACCEPT
sudo iptables -A INPUT -s 109.202.103.169  -j ACCEPT
sudo iptables -A INPUT -s 10.4.19.221/16 -j ACCEPT
sudo iptables -A INPUT -s 192.168.1.1/24 -j ACCEPT
sudo iptables -A INPUT -s 10.4.255.255 -j ACCEPT
sudo iptables -A OUTPUT -d 10.4.255.255 -j ACCEPT
sudo iptables -A OUTPUT -d 192.168.1.1/24 -j ACCEPT
sudo iptables -A OUTPUT -d 10.4.19.221/16 -j ACCEPT
sudo iptables -A OUTPUT -d 109.202.103.169  -j ACCEPT
sudo iptables -A OUTPUT -d 127.0.0.1 -j ACCEPT
sudo iptables -A INPUT -j DROP
sudo iptables -A OUTPUT -j DROP
Where am I messing up?
Option A: use the AirVPN Eddie client and its network lock
Option B: compare your rules to Eddie's network lock documentation, section "Mode 'iptables' in depth"
You're missing these three rules:
iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
iptables -A FORWARD -i tun+ -j ACCEPT
iptables -A FORWARD -j DROP
you don't need these two at all:
i would also replace these two of your rules:
with:
iptables -A INPUT -i lo -j ACCEPT
iptables -A OUTPUT -o lo -j ACCEPT
to allow all DHCP, you might also to replace:
with:
iptables -A INPUT -s 255.255.255.255 -j ACCEPT
iptables -A OUTPUT -d 255.255.255.255 -j ACCEPT
Thanks for the reply.
 I tried this as my rules:
iptables -A INPUT -s 10.4.0.1 -j ACCEPT
iptables -A INPUT -s 128.0.0.0/24 -j ACCEPT
iptables -A INPUT -s 0.0.0.0/24 -j ACCEPT
iptables -A OUTPUT -d 128.0.0.0/24 -j ACCEPT
iptables -A OUTPUT -d 0.0.0.0/24 -j ACCEPT
iptables -A OUTPUT -d 10.4.0.1 -j ACCEPT
my Torrenting client was still not able communicate after I run that. It's incoming port is set a port that I have forwarded on the vpn. It works fine before I run iptables
I also read that page and tried running the rules that were listed, with
iptables -I OUTPUT 1 -d 109.202.103.169 -j ACCEPT
iptables -D OUTPUT -d 109.202.103.169 -j ACCEPT
added
When I try to connect to the vpn after, I get
Sat Jul 25 13:08:33 2015 UDPv4 link remote: [AF_INET]109.202.103.169:443
Sat Jul 25 13:08:33 2015 write UDPv4: Operation not permitted (code=1)
